Insignia NS L42Q 10A
  • alecjahn
    Dumb enthusiast
    • Feb 2012
    • 77
    Re: Insignia NS L42Q 10A
    I see, budm. Makes sense. Thanks for the info, I didn't think about cross-model board usage with component differences.
    tom66, yeah, I wouldn't feel super comfortable trusting a "working pull" like those unless it was dirt cheap.
      Make sure they have a good returns policy. Most boards from broken screen TVs are usually good.
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        With my multimeter at 200 ohms setting, a handful of random MLCCs look to be "shorted".
        What is the actual reading? The definition of shorted could mean something different to various people.
        The lcd computer monitor I'm using right now had a shorted (1.5 ohm) ceramic cap on the logic board. See
        https://www.badcaps.net/forum/showpo...1&postcount=23
        --- begin sig file ---
        --- end sig file ---
        • alecjahn
          Dumb enthusiast
          • Feb 2012
          • 77
          I need to locate my better multimeter, or go borrow one of my father's many. I just don't trust this one I have here.
          • alecjahn
            Dumb enthusiast
            • Feb 2012
            • 77
            New T-CON board arrived while I was on vacation. Check it out!
              Great job and thank you for the feedback.
              • alecjahn
                Dumb enthusiast
                • Feb 2012
                • 77
                I couldn't have done it without all your help. Thanks again!
                • MrChazz
                  • Oct 2010
                  #48
                  Hey this thread was very insightful, I just picked a this model up off of craigslist for FREE and knew I could find something here on badcaps, I'm going to test the fuse and the two caps (are they filter caps?) on the t con, I think the t con in this unit may be newer? i'm not sure, but some of the chips look a bit different, I'll post some picure of it later on.
                  • MrChazz
                    • Oct 2010
                    #49
                    the board in my insignia is a v420h1-ch5
                      Post the pictures first. Does your TV have the same symptom?
                      • kevinm34232
                        • May 2012
                        • 1884
                        Bud regarding your Insignia fix where exactly are you checking for short to ground?? And can board be removed from chassis to do this?
                          Are you talking about the T-CON board?
                          • kevinm34232
                            • May 2012
                            • 1884
                            Yes. Sometimes I have the time and want to start t/s'ing those..
                              Yes, you can look for shorts uisng the Ground plane of the board for the meter probe and just move the red probe around the board start with the caps, especially the MLCC type.
                              • playab0yyy
                                • 37
                                "When you say the back light comes on does it stay on so you have a totally white screen?"
                                Selldoor, I'm waiting for pictures, but I believe I have this model tv that is turning on, but with a very bright white screen. Apparently, you can still see the picture on the tv, but with a very bright white screen and limited color. Any thoughts?
                                  @playa: It sounds like bad GAMMA Voltage problem on the T-CON board, will need to see the screen shot and the pictures of the T-CON board.
                                  If this is your T-CON board, then more thane likely to have bad GAMMA V ref IC AS15.
                                  http://assets.shopjimmy.com/media/ca...5542t06c07.jpg
                                  • playab0yyy
                                    • 37
                                    @budm Thanks! Unfortunately, you lost me on the "more thane likely to have bad GAMMA V ref IC AS15". lol I don't know anything about these things. I'm curious if this problem is a simple fix (ie. maybe just needing to swap a board). Not sure if I'll be able to get access to the board (the tv isn't mine, at least not yet). I should be able to get you a picture of the screen, though. If all I need to do is swap the T-Con board, is that basically just a plug and play (just the 3 ribbons)?
                                      "If all I need to do is swap the T-Con board, is that basically just a plug and play (just the 3 ribbons)?" Yes.
                                      • playab0yyy
                                        • 37
                                        Cool. Thanks for your help. I really appreciate it. I'll still try to get a picture for you. Thanks!!
                                        • playab0yyy
                                          • 37
                                          @budm - I tried to upload the video of the white screen in a zip file here, but I didn't have any luck. Not very familiar with this site. Sorry. But I did upload it to my OneDrive. Here's a link to the video... http://1drv.ms/1rZ7eWo
                                          • AdrenalinTL
                                            Macbook Pro A1707 - Dead - Battery 'popped'
                                            by AdrenalinTL
                                            Hi Peeps.
                                            Just a quick question please as I am by no means an Apple fundi at all.
                                            Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                                            Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                                            Don't want to go buy a battery for no reason.
                                            Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                                            07-18-2024, 09:52 AM
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • bohaboha
                                            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                            by bohaboha
                                            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                            anyhow i couldn't t read anything else
                                            the backlight is on strong and the screen does not get dark or very dark but no pictures
                                            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                            01-02-2025, 08:04 PM
                                          • valvashon
                                            LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                            by valvashon
                                            The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                            Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                            11-24-2024, 12:08 PM
                                          • 2elw
                                            SVOD4 PCB pictures + parts
                                            by 2elw
                                            Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                            STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                            GW1N-UV9UG169C6/I5 FPGA - Its a...
                                            07-04-2025, 12:23 PM
