Baier 27" lcd screen keeps turning on and off
  • maz
    • Nov 2011
    • 17
    Re: Baier 27" lcd screen keeps turning on and off
    No Problem at least we are both clear what happened, i think i selected it when i was posting thread to receive emails. Thanks
    • selldoor
      Slow Learner
      • 7870
      Is this abandoned -were you waiting for some input?
      I think we are waiting for the results of the Torch Test and the pinpoint of which board (part of board) responds to heat.
      • maz
        • Nov 2011
        • 17
        Thank you selldoor,
        I have been busy at work and at home and tried testing some components on the power board they were ok. only i could not figure out was the connector coming from power board to the main board is label for some pins to have 18V but i only get about the 4.3 or 5 volts, the rest of the pins have exact same volts as labeled.
        Thank you again for your input any ideas.
        sorry i have not been able to test the torch trick.
        • selldoor
          Slow Learner
          • 7870
          Hi - presumably the 18v was low when the tv was in error state.
          Can you test again when it is working. I really think you need to persevere with
          with the systematic hairdryer test and also the torch test as these will hopefully lead us to where the fault is based.
          • maz
            • Nov 2011
            • 17
            Hi selldoor
            you were right i tried the torch and i could see the faded picture on the screen, so the picture is on the screen but there is no light, what do you think is bad invertor board or something else.
            • selldoor
              Slow Learner
              • 7870
              #26
              It seems like inverter board but could still be power supply.
              Did you say when you first switch on it takes up to 20 minutes to come on?
              If so please try the hairdryer again but only on the power supply and see if it comes on quicker.
              Have a video connected and playing so you know when it comes on.
              • maz
                • Nov 2011
                • 17
                Hi Selldoor
                open to inverter board and used hair dryer on it and it is working ok without go off I think it is fixed will update if there is any problem I think there was a dry point on the inverter board, checked the voltage going to inverter board with screen on and off and they were stable there is a small cap on the board (SMD) I have a doubt about that but will see if problem occurs again thank you once again.
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Ok - good luck - you know where we are if needed.
                  • maz
                    • Nov 2011
                    • 17
                    Thank you selldoor
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
                    • ipatch
                      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                      by ipatch
                      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                      08-24-2024, 02:36 PM
