Samsung LN40B530...Power on and off problem.
  • dbtsat
    • Apr 2012
    • 13
    • canada
    Hi to everybody...i have a tv Samsung LN40B530 with on and off problem,when you turn on the tv it will turn on for 3-4 seconds and then it shut down.I inspect all capacitors no sign of bad caps, the only thing i notice is the transformer location TI802 it looks like burn on top. How to check if this component is good or bad...Please help.
    Thanks in advance for help/advice.
    dbtsat
  • dbtsat
    • Apr 2012
    • 13
    • canada
    Re: Samsung LN40B530...Power on and off problem.
    here is the picture of the transformer.
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      Hi 90% chance of bad transformer.
      Can you take a picture of the underside of the board under the transformer.
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • dbtsat
        • Apr 2012
        • 13
        • canada
        here are the pictures.
        Thanks....
        • retiredcaps
          • Apr 2010
          • 9271
          See
          https://www.badcaps.net/forum/showthread.php?t=15304
          for transformer readings.
          If bad, then you can find it on ebay for $12.99 + free shipping
          http://www.ebay.com/itm/160790571433
          --- begin sig file ---
          --- end sig file ---
          • dbtsat
            • Apr 2012
            • 13
            • canada
            Originally posted by retiredcaps
            See
            Thanks a lot...i will order the part.
            • dbtsat
              • Apr 2012
              • 13
              • canada
              i got the new transformer...solder it ...and boom! it works like a brand new tv...this is my 11th samsung tv that i fix...i love this hobby.
                You'll find that although Samsung TVs are expensive, they use poor quality components so they don't last. My repair count is 4 Samsung LCD TVs (one 26" and three 40") and 1 Samsung plasma (42".)
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Wow, that is quick shipping from Hong Kong to Canada.
                  • dbtsat
                    • Apr 2012
                    • 13
                    • canada
                    sorry the part, i got it from KLCDparts, San Francisco ,California.
                    • selldoor
                      Slow Learner
                      • 7870
                      Whilst it was the transformer that blew you might want to consider checking changing the capacitors that filter the supply to it.
                      • dbtsat
                        • Apr 2012
                        • 13
                        • canada
                        Thanks selldor for the advice....are you familiar with the capacitors location? because another transformer burn...
                        please i need an advice/help what causing the transformer burn.
                        Thank you very much in advance.
                        • melmc323
                          • Nov 2012
                          I am having the same issue!! How do I take off my transformer???
                          • randtek
                            • Oct 2011
                            • 280
                            • US
                            Use a soldering iron and solder wick to remove the solder from the connections of the transformer leads. The transformer should then come out of the board easily.
                            • Vontsik
                              • Aug 2013
                              This helps me a lot co'z I have same problem with my Samsung tv with same model. Thank you very much!
                              • brucetv
                                • May 2015
                                • 281
                                • united states
                                I also have this model in my shop today and it had a faint solarization. I turned the gamma setting down and it helped with the solarization but I noticed whatever channel you turn it to it shows NBC's logo faintly on the bottom right and you see trails behind people as they walk. Power supply voltages look good. VS and VA fine. Does it on DVD too but menu looks fine, no solarization on menu. So now I'm leaning towards the main board. My first thought was the Gamma chip on T-con. Any suggestions?
                                  09-07-2024, 05:50 AM
                                • howardc64
                                  Samsung UN55JU650DF network/streaming problem
                                  by howardc64
                                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                  07-09-2025, 12:44 PM
                                • alro7779
                                  Samsung UN55MU6103F video problem; has colored stripes on the display
                                  by alro7779
                                  Hello, everyone!
                                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                  09-27-2025, 11:29 PM
                                  09-06-2024, 11:40 PM
