samsung ln40b530p7fxza light up problem
  • gmzombie
    • Sep 2009
    • 83
    OK i received this TV and it only has sound. you can hear the system play anything as such i plugged in a Xbox to the hdmi and it was playing the game but it didn't have any back light. i checked the voltage to the man board from the all in 1 power supply inverter but im not sure where i should check for the backlight side. ive got the board out and everything looks good at least no burnt traces or anything. both fuses are fine it just seems like the high voltage side is not working? any suggestions?
  • PlainBill
    • Feb 2009
    • 7034
    Re: samsung ln40b530p7fxza light up problem
    Yes, quite a few.
    1. Review your composition classes. Proper capitalization and spelling structure assist in comprehension by the reader. Breaking it into short paragraphs also help.
    2. Pictures are a great help. I suggest starting with a single over-all picture of the back side of the TV (with back removed, of course). This allows identification of interconnections between various boards.
    3. When listing a model number, do so exactly as printed on the label. The base model number in this case is LN40B530. The service manual is here. Unfortunately, most service manuals do not include the inverter.
    PlainBill
    • fastvideo
      • Dec 2008
      • 55
      https://www.badcaps.net/forum/showthread.php?t=14644
      Check here, should be the same power and inverter circuit.
      • gmzombie
        • Sep 2009
        • 83
        OK to update here are some pics of the whole backside of the TV. Then i took 3 pics of the power supply board, A whole pic, a left half, and a right half. There is also a pic of the main board, and the tcon board.
        I have verified that if you put a flashlight behind the LCD it does in fact show a picture. I have checked all the diodes in the board and they all show a rating on one side and infinite on the other just as they should.
        I thought i had the right model code but it seems to be this Samsung ln40b530p7f. Hopefully this helps out so i can get this diagnosed and repaired.
        Also i tried to download the service manual but it wouldn't let me. it said 2 downloads per guest per day. I'm using Firefox so that isn't the issue.
        • truep
          • Aug 2010
          • 373
          Do you have 24V going to the inverter from the power supply?
          • gmzombie
            • Sep 2009
            • 83
            being that the inverter is on the power supply board im not quite sure where to check for the 24v.
            • PlainBill
              • Feb 2009
              • 7034
              Well, I've seen better pictures, but these give plenty of information. If you make them just under 2000 x 2000 pixels we can get more information. The design has gotten a lot simpler in the past 5 years.
              Points to check:
              1. It may be necessary to register on Elektrotanya. It's a free registration and I haven't been spammed as a result, so it should be safe.
              2. Refer to the last picture. Above and to the left of the bar code label is the pinout of the output connector. Check the voltages.
              3. Note the transformer bottom center of the same picture. Is that scorched or is that dust? If it's scorched, QGAH02095 is available on eBay.
              4. Pictures of the bottom of the inverter will help troubleshooting if the brown spot is dust.
              PlainBill
              • gmzombie
                • Sep 2009
                • 83
                1. i tried this and it said it was for invite only.
                2. i checked the pinout output voltages and they all seem to be in spec. 13v was at 13 5.3v was like 5.32v and whatnot.
                3. it is not dust that is for sure. so im assuming that it is scorched but is there a better way to tell.
                4. I will have to get you a picture of the back side of the power supply board tomorrow. its late now.
                • PlainBill
                  • Feb 2009
                  • 7034
                  1. I'll check that out.
                  2. Good
                  3. Compare the resistances of the secondaries
                  4. Whatever.
                  PlainBill
                  • gmzombie
                    • Sep 2009
                    • 83
                    ok i hope i did this correctly
                    i took measurements on both sides of those qgah02095 and on all 4 of them
                    first one closest to power plug
                    side of light plugs 3 is the scorched one
                    (1.)1.19k /1.18k (2.)1.19k/1.18k(3.) .955k /8.3mega (4.)o/l / 1.2k ohm
                    other side of qga's
                    (1.) .1/.1 (2.)1.8/1.9 (3.).1/1.9 (4.).1/1.9
                    Also did you figure out the register for that site?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      other side of qga's
                      I'm going to make an assumption here. I suspect there was flux or something else coating the pins of the transformer, that is why one end of 4 reads open. You might want to verify that. One secondary winding on transformer 3 is significantly (20%) lower than the others. Replace transformer 3. If you cannot get comparable readings (1.2K +- 3%) on transformer 4, replace it also.
                      No, I haven't. I've been goofing off.
                      PlainBill
                      • Village Electronics
                        OldPro
                        • 118
                        PlainBill
                        Don't sass the customers Bill or you're going to get a cut in pay.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          You can't cut my pay, I QUIT!!!!
                          PlainBill
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Well, sort of. I haven't figured out how to issue an invitation, but an invitation isn't necessary.
                            Here's what you or anyone else must do.
                            1. Go to Elektrotanya.
                            2. In the left hand Navigation menu click on About Site
                            3. Click on fill up an electricity test.
                            4. On the next page enter your email address
                            5. Then answer 5 simple electronics questions.
                            PlainBill
                            • Dgtech
                              E. Technician
                              • Apr 2009
                              • 1462
                              • Steeler
                              PlainBill
                              Step #6. Insert five euro's into the slot.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                That's only required of smart alecs.
                                PlainBill
                                • gmzombie
                                  • Sep 2009
                                  • 83
                                  just to update replacing both inverter transformers fixed the tv. it now turns on and i can see it again.. thanks for your help.
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Glad to hear you have it working.
                                    PlainBill
                                    • cre3
                                      • Aug 2011
                                      • 1
                                      Thanks for sharing and your help.
                                      I had the same problem on the same tv. Screen turns off and on. No problem with the sound.
                                      So I saw this forum and dissassemble my tv and have seen the damaged transformer.
                                      First I bring the board only to a "tv repair". They wanted to have the all tv and replaced the entire board for 250$ and keep the old one. They cannot put a new transformer.
                                      I said no and order a new part on ebay (+ a soldering iron in my city) and put the new transformer.
                                      The tv works now pretty well like before. Good for watching "rugby world cup"
                                      sorry for my english and thanks again!
                                      • Horty24
                                        • Oct 2011
                                        • 54
                                        I also have a burned transformer. Is there any thing I should be careful so I dont get shocked? My tv turns for 2 seconds and off for 4 seconds.
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • totof
                                          Samsung UE55JS9000 backlight issue
                                          by totof
                                          Hello.
                                          I'm sharing with those in the know a problem I'm having with my Samsung UE55JS9000T TV, which has a backlight fault with halos of light on the sides (see my photos). This is a model with LED strip backlighting on the sides.
                                          I took the TV apart to remove the panel and noticed that the "yellowish" film on the Plexiglas light diffusion plate was stuck to the LEDs. When I peeled it off, it left marks on the Plexiglas plate, which I cleaned as best I could with rubbing alcohol (see photo).
                                          The result isn't perfect, but it still seems pretty good to me.
                                          10-05-2025, 08:27 AM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
