Panasonic TX-43P15H Projection Television
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    I was given this with no sound problem after the owner had connected extra speakers after looking at the schematic I have established that ic2301 TA8200AH has been damaged or power rail is missing, found it on ebay will order once I have confirmed R880 tsf19632 Protector is open/closed or that the 35v rail is up.
    Pictures to come.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Panasonic TX-43P15H Projection Television
    Well I looked at it today and found protector
    R880 TSF19632 is open,
    and IC2301 TA8200AH is shorted.
    The only problem is what to replace the protector with.
    My pc
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      FUSE PROTECTOR,90V 6.3A
      Order Code: K5G6323A0003
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Thank you very much
        Will it be safe to use a standard fuse with same current rating?
        My pc
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          I will solder a slow blow 6A 250v fuse in with heatsrink on it
          My pc
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • jaroslav.psenicka
            Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
            by jaroslav.psenicka
            I have a Lenovo Yoga 13 Panasonic here, when powered
            • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
            • most voltage rails seem OK (see image below, red labels)
            • resistnace to ground mostly seem OK as well (blue labels)
            the only suspicious is the 0.0V rail (2nd from left, top row)
            • the resistance to ground is rather low (1.9ohm)
            • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
            also tried new BIOS, no change
            I can't find a schematics for the board - can some of you gurus look at the voltages?...
            05-02-2024, 05:59 AM
          • renech
            panasonic TH-42PC77U plasma television half screen problem
            by renech
            hello,
            I hope someone on this forum can assist me.
            I have a panasonic TH-42PC77U plasma television.
            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
            I have read some posts that suggest the problem is related to the boards on the left...
            12-12-2022, 06:53 PM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
