Samsung PN50C550G1F black horizontal lines
  • fhost
    • Apr 2012
    • US
    Hello guys, first post.
    I searched and didn't see this specific problem yet posted.
    I have a samsung 50 inch plasma which has been gradually been developing black, 1 pixel thin, black horizontal lines. It started with 1 line and has, over the course of 9 months, grown to 100 or so. sometimes I'll even see one pop up before my eyes.
    I've searched everywhere and have found others who have the same issue with samsung plasmas. Some forums suggested making sure that the ribbon cables were properly inserted into the y board. I've done this with no success. I've ordered a new y board for 30 bucks with hopes that this will solve the problem.
    I wondered if anyone had any advice on the subject or had run into the same problem. did I waste money on this new board? The tv is less than 3 years old and I'll be so insanely pissed if I have to spend much more than a couple hundred to fix it.
    Cheers,
    fhost
    Re: Samsung PN50C550G1F black horizontal lines
    From top to bottom: Unrepairable panel fault. (Blame cost saving, unrepairable X buffer drivers.)
    From left to right: Y buffer fault.
    • Stevieo
      • Northern ireland
      Hi, I have the same problem, 7 fine lines. Is There anyway to repair it without replacing the board? Thanks Stevieo
      • Mt.Man
        • 53
        If the y-drive board does not correct the problem, the panel is bad.
        • electronicsurplus
          • 210
          I would try replacing the Upper Y-Buffer ASAP
          Sometimes, one or more of the Surface moounted IC's fail and cause this problem before it fails completely
          Because, the Y-Buffers not only light up the screen but, they also stream the data to the panel
          IF this does not work you may have a bad panel
          It might be worth the try by buying a Y-Buffer for approx $50-$75 anywhere.
          Http://www.retechtv.com should have them in stock or Shopjimmy.com
          Jon
          Jon
          This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
          Help keep these from the landfills
          • ppham
            • Oct 2012
            • 6
            • canada
            hi Tom66.
            can u send me the manual for samsung 50 inch plasma seriel 5 model pn50c550G1FXZC
            Thank you very much for your help my email.pivipi@hotmail.com
            • freakaftr8
              • Oct 2012
              • 3743
              Hey guys bad news. At least on this one I have same model number. Y board replaced but lines are still there. It's panel failure but how? It's a direct ribbon right to the horizontal pixels. No tape carrier package.
              • drpj23
                • May 2012
                • 528
                I am at a misunderstanding too how horizontal lines could be panel...unless ribbons are damaged. If the lines are evenly displayed (or have a pattern) CTRL board is a possibility.
                Vertical is 99% unrepairable......but there is a possibility of CTRL board or any bottom buffer boards. But most of time it is the driver ICs that are built within the panel that fail.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Right you are, these panels are Samsung 1080p panels and for some reason what I have read on the internet that when one line fails, more are to come rather quickly. I dont get it. unless you have a blown out pixel on the beginning pixel from y ribbon, that is the only way for the rest of the line to go out as the pixels are in series. I have gone and disected a y ribbon connector on a panel doing this, and cannot find a failure within the connector or clip, this really has to be a breach underneath the glasswhere the ribbon fuses to the data lines.
                  • drpj23
                    • May 2012
                    • 528
                    The only way I see the panel itself fail is if the electrodes short out. I have seen this happen on a Panasonic but it always blows out the upper Y buffers (or corresponding thereof). It did look cool though when it tried to cut on....it was like red lightning.
                    Anyways, I am suspicious of CTRL board.
                    I have also read the Y sustain can be at fault but should be considered when horizontal blocks are out not really lines.
                    I guess I should also note, a lot of my information is from Panasonic PDP literature.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Yes but in my dealings with t sustain symptoms I'm not sure if it can Lose data to just one line. That's odd. Usually if the data is not fed you will have a grey screen unless the logic is suspected then it will kill off drive signals thus shutting down vscan and no picture.
                        Y-sustain just lights up panel.
                        It can never cause individual lines to fail.
                        Only the buffer, digital board or panel can.
                        • ppham
                          • Oct 2012
                          • 6
                          • canada
                          which one should i replace first ?
                          y buffer/ or y main / panel???
                          • drpj23
                            • May 2012
                            • 528
                            If you have lines y buffers. Y SUS, as tom66 said, will not cause lines to fail.
                            Two, I wouldn't advise replacing the panel for they are very expensive unless you have a valuable resource somehow, in which case, clue me in
                            But Y buffers if you have horizontal lines. It'll be the upper or lower depending which half of the screen the problem exists at.
                            • ppham
                              • Oct 2012
                              • 6
                              • canada
                              i ask the sale tech .
                              he says . i should replace y buffer and y main as a set.
                              Notice. . Almost all plasma manufacturers highly recommend replacing the Y Main and Y buffer (or buffers) when replacing any one of the set. If a good Y-Main is connected to a faulty buffer, there is a high degree of likelihood that damage will occur to your new Y-Main, and the opposite often holds true if a bad main is connected to good buffers. Just a word of caution.
                              so in this case should i replace them as a set
                              • ppham
                                • Oct 2012
                                • 6
                                • canada
                                do any one in here fixed this problem succes? after replaced those board. The horizontal thin black line gone. pls let me know. I want to fix my tv with this problem . thanks for any advices
                                • ppham
                                  • Oct 2012
                                  • 6
                                  • canada
                                  Cheers,
                                  fhost
                                  hi
                                  after u replaced the new y board. is the problem fixed? pls let me know my tv have same problem
                                  • drpj23
                                    • May 2012
                                    • 528
                                    This is only if you have no image i.e. the buffer ICs shorted out or something went bad on the SUS or furthermore, the set won't cut on because of Y section.
                                    You have lines (as I still am assuming) therefore the Y SUS working properly due to the image you still have.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Just to add some more confusion the 50" panasonic TV I just fixed was Full HD and wow, how finicky those Y buffer ribbons were to seat absolutely correct so I did not have thin horizontal lines every where.
                                      This was not the original fault but I had removed the buffers and the re-install introduced 100's of thin lines.
                                      maybe post a picture and try reseating the connectors which match the lines.
                                      I'd go with buffer issue first. I don't think panel or YSUS either.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        True. Panasonics y ribbon attachments are finicky. So are hitachis. But these samsung a clip in. Yes the only way you can have one line out is either panel failure of some type or if one pin on the ic for the corresponding line is making a bad connection under the silicone n
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • CyberNinja
                                          Samsung plasma 50" TV, model PN50C540G3F, has black horizontal lines
                                          by CyberNinja
                                          First, the black horizontal lines even overlay the TV's menu. Does this behavior indicate that it's the plasma panel that's defective? If not for the black lines, the TV works just fine. I've cleaned the 6 connectors between the panel and the Y-buffer board, causing no change in the black lines. Visually, the 12 ICs on the Y-buffer look brand new (no holes, etc.). I put my fluke meter in continuity mode and tried to perform the "short" test on the 6 panel ports and found many shorts. But I don't think I'm doing the "short" test correctly and I'm hoping someone can provide guidance....
                                          01-10-2021, 09:38 PM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                          by x_orange90_x
                                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                          09-04-2023, 12:09 PM
                                        • Wf789
                                          Pioneer PDP-V402 - Black Horizontal Lines
                                          by Wf789
                                          Hi, I'm new around here and hoping that there may still be some people on here that are knowledgable about plasma display repair, as some of the old badcaps forum posts have been pretty useful to me so far.
                                          For any regular plasma TV I probably wouldn't bother to go through this effort, but I have a pro-grade Pioneer plasma which I really want to use and it would be a shame to throw it out since there's not many of them still around these days. The plasma has the typical black horizontal lines that seem plague plasma displays. I've counted 3 lines on top of the screen and 4 at the...
                                          04-10-2022, 06:31 PM
