lg rz_42py10x
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    lg rz_42py10x
    just been offered the above plasma set it has 2 coloured lines on the right side of the screen any ideas what the fault could be before i make him a offer on it. reading on line makes me think it maybe the control board at fault also could these lines being on the screen for a long time burnt into the plasma screen? so even if i fix the line fault the burnt area maybe visable?
    Re: lg rz_42py10x
    Could be panel, but I've seen loose driver connectors cause the same.
    Yes, those lines could be burned in. I have seen it before.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Re: lg rz_42py10x
      cheers tom decided to give it a miss he would not budge from £60.00 looked for the main control board even on ebay well over £80.00 and reading this site looks like it was the board at fault.http://greenrenovation.wordpress.com...stripe-repair/
      just been offered a Luxor 22 inch LCD TV / DVD with remote stand power lead etc it has a fault as when its on for over 15 mins the screen goes overbright if you turn if of and back on its fine for 20 mins any ideas?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Re: lg rz_42py10x
        the model number on the luxor is LUX-22-822-COB they say the pics ok for 10 mins or so then goes overbright/out of focus but if you turn if of its ok for a few minutes then goes bright/out of focus any ideas?
          Re: lg rz_42py10x
          No idea... maybe bad connection/solder joint... just guessing here.
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • jeyoung12
            Samsung QN50Q60t lines on screen
            by jeyoung12
            Hi all
            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
            So....i don't know what end of the C ribbon to work with...
            02-26-2024, 10:38 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • kdaniel
            Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
            by kdaniel
            As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
            There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
            After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
            Left...
            11-16-2022, 09:23 AM
          • Chrissygizmo
            Sony KD-55XG9505 lines on screen problem
            by Chrissygizmo
            Hello again everyone,
            This is my latest mission, to try getting this Sony tv back to normal working order…
            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
            02-19-2025, 11:31 AM
