LCD 32 TV turns off by itself
  • Chandyman
    • Apr 2012
    • 19
    • England
    Model Technika LCD32-207
    TV turns itself off by itself into standby mode, LED is normal colour (blue) and does not flash, no unusual clicking, buzzing or popping sounds.
    I can turn the TV on again only for it turn off again, this may after 10 seconds or 20 mins.
    When working, the picture appears normal
    Is this likely to be a PSU failure or main board failure or both?
    On inspection:
    The PSU is 17PW20.1- 010507 possibly vestel
    The main board is 17MB12-3 possibly vestel
    (i say possibly as it does not have vestel printed on the board)
    There does not appear to be damage to either board, the capacitors do not appear to be blown, no bulging or leaking and no obvious discolouration to any.
    My knowledge of testing electronics is limited, i.e, no equipment other than a good soldering iron.
    Anybody any thoughts?
    Darren.
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: LCD 32 TV turns off by itself
    On inspection:
    Darren.
    this model suffers with bad caps,repaired one recently with same symptoms,heat up the capacitors with a hot hairdrier just to confirm,they dont fail bloated or leaky,panasonic fc are good for these ,the ones you have are gp caps
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      If that doesn't fix, 17PW20 supplies are often fixed by replacing them outright - they are about 20 quid on ebay for 17PW15-9 (which is compatible.)
      • Chandyman
        • Apr 2012
        • 19
        • England
        thanks for replying multimeter,
        OK, so the caps can still fail even if they look good, i guess this is where good testing equipment comes in.
        Is it likely to be the PCU?
        Does heating the capacitors solve/may solve the problem? how hot should i heat them? will i see something happen to the caps or is it just a case of putting it all back together after heating and trying it?
        Thanks Darren
        • Chandyman
          • Apr 2012
          • 19
          • England
          Thanks tom66,
          With your suggestion to possibly replace 17pw20, do you think its the PCU that's the problem?
          Darren
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            Thanks Darren
            heating the capacitors wont solve your problem,it will verify that they are faulty(sometimes),heating will drop the esr (resistance) of the caps enough to get them working again,you need to direct the hairdrier directly onto the caps on the power supply,you will proberly find that the output caps are high esr,which are failing,but not always these,could be others in the feedback circuit,or in the primary side,to be sure when you want to replace them, that you check the old ones against there respective datasheet just google it,and compare,esr,ripple,and voltage,the ones you most likely have wont show an esr reading on the datasheet beacause of being general purpose caps,but panasonic fc is a better than good choice for replacements,technika are profound lovers of crap caps,in fact technika is crap !
            • Chandyman
              • Apr 2012
              • 19
              • England
              Thanks multimeter,
              Yes, i have read today that technika is on the poorer side of poor, might have a go at testing and replacing the old caps with the better panasonic stuff. From what i've read, many knowledgeable folk on here recommend panasonic caps
              I assume then that panasonic is an all round better TV to purchase than most other brands.
              Darren
              • cashkennedy
                • Aug 2011
                • 668
                Panasonic makes many many items, capacitors, computers, nuclear power plants. Im sure they used some non panasonic parts in their computers lol.
                Just because a company makes 1 thing well doesnt mean they make everything well, or that they even use their own parts.
                Most obvious example : Samsung owns a very high quality LCD panel factory, but samsung uses cheaper chinese / chungwa panels in almost all of their products now, because consumers dont know better...
                Besides teknica probably isnt even a real brand, but just a brand that Funai corp markets. (they produce cheap electronics under almost 10 different names)
                Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                • Chandyman
                  • Apr 2012
                  • 19
                  • England
                  Thanks cashkennedy
                  I see your point, nicely put.
                  Darren
                  • selldoor
                    Slow Learner
                    • 7870
                    Hi - if you are going to try and fix this you will need a digital multimeter, if this is a one off venture into electronics you can probably get by with a one for a few pounds.
                    We can help a lot more if you post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                    Example
                    https://www.badcaps.net/forum/attach...1&d=1290283049
                    • Chandyman
                      • Apr 2012
                      • 19
                      • England
                      Example
                      Thanks selldoor,
                      Not completely a one off venture, although my knowledge is currently very basic, i am very intrigued by the whole electronics thing. Recently purchased a soldering iron with different sized tips and a good practice using it. Managed to resolder a new jack plug on to my laptop which had been playing up for some time. That left me very pleased with myself and eager to learn more. It wont be long before i'm looking at purchasing a multimeter.
                      Thanks for the advice on the pics, i will sort some out as soon i can work out how to, lol.
                      Darren
                      • radioredcat
                        • Nov 2008
                        • 8
                        I have just repaired a goodmans 22" TV/DVD combi (vestel) that would take a few mins before the set would come on and looking at the caps on the PSU they looked ok but there were some G-LUXON caps.
                        I decided to replace all the caps on the board and that cured the fault so for the sake of a few £'s it's worth replacing them.
                        Andy
                        • Chandyman
                          • Apr 2012
                          • 19
                          • England
                          Andy
                          Hi Andy
                          Great stuff!
                          Are G-LUXON caps rubbish?
                          What make did you replace them with?
                          Darren
                          • selldoor
                            Slow Learner
                            • 7870
                            In a word yes (At least on a power suppy board)
                            If you go to this page there are a couple of threads a bit down the page give good advice.
                            https://www.badcaps.net/forum/forumd...aysprune=&f=24
                            Most electronic outlets wont have them, eg maplins wont but in mcr there might be somewhere.
                            cpc in preston carry most requirements or Farnells in leeds
                            you can also digikey and mouser who have uk presence/websites.
                            All down to who has what and postage.
                            • Chandyman
                              • Apr 2012
                              • 19
                              • England
                              Example
                              hi selldoor,
                              Just tried taking pics of all the stuff you advised, however, the pics have not come out that clear. will try again tomorrow morning when theres more light.
                              Darren
                              • Chandyman
                                • Apr 2012
                                • 19
                                • England
                                Hi selldoor,
                                I live in Chorley, so not too far away from CPC in preston, although it might be cheaper to pay post than travel. Force of habit having my profile as manchester as i work in there. Thanks for the thread advice.
                                Darren
                                • Chandyman
                                  • Apr 2012
                                  • 19
                                  • England
                                  Thanks.
                                  Thats a very informative thread!
                                  • radioredcat
                                    • Nov 2008
                                    • 8
                                    Hi Chandyman I used panasonic and rubycon from CPC and s for G-luxon caps I have seen a lot of these caps go bad so yes i would describe them as rubbish.
                                    Andy
                                    • Chandyman
                                      • Apr 2012
                                      • 19
                                      • England
                                      Andy
                                      Thanks Andy,
                                      Mine are G-LUXON and SAMXON (which i assume are just as bad)
                                      Do you replace them like for like, i.e same voltage and uf or can there be a little difference
                                      Darren
                                      • Chandyman
                                        • Apr 2012
                                        • 19
                                        • England
                                        Example
                                        Hi selldoor,
                                        Here are the pics of the chassis, front and back of the power unit with close up on the connectors and front and back of the main board.
                                        Darren
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • andrhouseolly
                                          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                          by andrhouseolly
                                          Hi.
                                          I kindly ask you to help me solve the problem.
                                          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                          The board turns on, there is no image.
                                          Read more. When the power supply is connected, the front panel indicators light up briefly.
                                          When you press the power button, the button indicator lights up. The board works
                                          there is no image, there is no matrix initialization, there is no image on HDMI.
                                          When turned on, the fans do not spin, but when they warm up they start spinning.
                                          When you turn off the button, the fans spin up to full speed for a short...
                                          05-11-2024, 03:14 PM
                                        • Egidio85
                                          Samsung UE55F8000SZ Turns on and off immediately
                                          by Egidio85
                                          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                          This defect happens continuously, hearing the classic click of the relay every time.
                                          Power supply board BN44-00636B
                                          disconnecting the mains and lamps from the power board always causes the same problem.
                                          Is it normal that without anything connected this power supply turns on and off cyclically?
                                          any suggestions on what to check?
                                          thanks in advance
                                          03-11-2025, 12:45 PM
