Soniq (australian brand) 32" - screen doesn't always start up
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    #61
    Re: Soniq (australian brand) 32" - screen doesn't always start up
    Originally posted by psmedley
    Update: TV is still working fine.
    A question however - is it normal for capacitors to measure lower resistance once they're removed than in-circuit?
    Several caps I replaced on the main board measured significantly lower ESR once removed - ie they were close to 0.6 ohms in-circuit, but ~0.3 Ohms once removed.
    you will always get an accurate reading when they are out of circuit, as they wont be in series with any other parts.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • JohnML1975
      Soniq S55V14B-AU White vertical bar middle of screen
      by JohnML1975
      Hello Forum Team
      Have this issue
      Found signs of burning or some sort of build up of something on the flex cables that go between T-CON and screen buffer boards
      Tried cleaning the flex cables and the ports where they go in but the problem remains
      Swapped the flex cables but problem remains
      Cannot see anything burnt on the main board or the t-con board
      Checked for shorted capacitors on the buffer board and did not find anything
      Am going to try using sticky tape on one of the flex cables to and see if i can resolve
      09-27-2025, 02:55 PM
