LG 60PY3DF shuts off
  • brentkhack
    • Mar 2012
    • 57
    • US
    When you press the power button you can hear and see everything "boot up". But after 5-7 seconds you hear a click and it shuts down. Now there is still power because you can still see the power butting lit up from the front. I did unhook the Z-sustain and it still did the same thing. I did look for bad caps but didn't see anything bad (I am just learning this stuff). From what I have read it seems to be the main power supply that is bad. So would you agree to change the EAY32929201 board? I just don't want to start throwing money into this thanks.
  • brentkhack
    • Mar 2012
    • 57
    • US
    Re: LG 60PY3DF shuts off
    any idea?
      Pics of PSU?
      • brentkhack
        • Mar 2012
        • 57
        • US
        Here you go :-)
          This is a 60" model? Is there only one PSU? I'm a little surprised at how small that is... it's smaller than the one in my 42" plasma!
          Check the Vs and Va voltage using a multimeter. Set your meter to 500V, 600V or 1000V DC. Check it while it clicks on.
          If it's zero or nearly zero.
          - Disconnect mains power
          - Unplug Y board (left hand side of TV, from back)
          - Check again with mains power
          - Unplug Z board (right hand side of TV, from back)
          • brentkhack
            • Mar 2012
            • 57
            • US
            I see one main psu and two (i think) sub psu.
              That looks more reasonable; I was noticing the tiny 390uF capacitor primary, but it looks like it's got another board for more power supply stuff so that makes sense. I'd expect a 60" plasma to draw maybe 500-600W, so a bigger power supply is expected.
              Second pic is the Z board, it generates the voltages to drive the plasma display in conjunction with the Y board.
              • brentkhack
                • Mar 2012
                • 57
                • US
                Yes I just saw that. The other psu is to the right of the Z board. I will take a pic when I get home. sorry for the confusion.
                  There's one PSU on this model which is split into two boards. I'm guessing they use a different smaller board for different TVs, so they can produce multiple models and only change one part.
                  The Y board opposite to the Z board and connects through the buffers (usually... sometimes the buffers are integrated on the Y board.)
                  • brentkhack
                    • Mar 2012
                    • 57
                    • US
                    This is part EAY32929901 plus it's pic.
                      That board likely produces the clicking sound, but it's unlikely to cause the problem. Try my suggestion of unplugging the Y and Z boards first.
                      • brentkhack
                        • Mar 2012
                        • 57
                        • US
                        I unplugged both boards then plugged in the power cord. There is no power going to the tv. The power button does not glow.
                          Try plugging in the Y board then. I had an LG which would shut down when both boards were unplugged. (Bad for troubleshooting.)
                          • brentkhack
                            • Mar 2012
                            • 57
                            • US
                            Things would do the normal boot process and then shut off. I did notice it got to the point where it showed av1 then shuts off in case that matters.
                              Yes that's very important! The fact that the screen lights up and shows a picture (even if just "AV1") is a clue: the plasma drive boards are probably okay, it's probably a main board problem or a power supply problem.
                              Before you try this, remove the button board if it has one. (The board with on/off, volume, channel etc. on it.) Check for stuck buttons etc. If the button gets stuck the TV may turn off as soon as it turns on.
                              • brentkhack
                                • Mar 2012
                                • 57
                                • US
                                The tv buttons are touch sensetive. It says av1 at the scrolling marquee below the main display. I do see just faintly where on the main screen where the input info would show.
                                  Oh okay. If you turn the lights out in the room, any light from screen? I assume you mean the indicators on the side of some LGs which tell you which input the TV is on? (I've got one of those for parts at the moment.)
                                  • brentkhack
                                    • Mar 2012
                                    • 57
                                    • US
                                    I plugged back in the Z board and I can fully see on the main screen where it says av1 and vcr right below before it shuts off. The button you mention like power and volume are below the main screen and are touch sensative. So if there is no power to the tv you cannot see those power, volume, or input buttons. No traditional buttons for that. The only things on the side will be for usb, composite, and s video.
                                      Those buttons can still get "stuck" although it's usually caused by dust or something building up on the board. If it's possible, remove the board and clean it; a user on this forum had a similar problem with an LCD monitor a while back.
                                      • brentkhack
                                        • Mar 2012
                                        • 57
                                        • US
                                        I want to make sure we are talking about the same thing. From the pic you can see the "buttons" from the flash of my camera. From what I see nothing can get stuck since the "buttons" are on a smooth surface so you cannot feel them. Without the flash that section looks like part of the bezel. Thanks
                                        • huzo
                                          HP Omen shuts down when loading OS
                                          by huzo
                                          The model is 15ec-1061nm
                                          Board number is DAG3EDMB8D0​
                                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                          10-29-2024, 12:05 AM
                                        • Giggle2562
                                          Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
                                          by Giggle2562
                                          I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
                                          The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
                                          Here's what I've tried so far:
                                          • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
                                          • The laptop shows an image on the internal display for a few seconds before it shuts down.
                                          • I tried swapping the LCD panel with a known good one.
                                          • I tried swapping the LCD cable
                                          11-06-2025, 12:36 PM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • brav1ez
                                          ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
                                          by brav1ez
                                          I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
                                          I’ve tried:
                                          - CMOS reset
                                          - Removing the SSD/HDD
                                          - Reseating RAM (removing each stick individually stops boot completely)
                                          - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
                                          With...
                                          09-07-2025, 10:47 AM
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
