Vizio GV42L Power supply board question
  • Bmyers21
    • Mar 2012
    • 4
    • United States of America
    Hello I am new here and have a question. I am not a pro by any stretch, but I've done some repairs in the past. I have a vizio 42" LCD that I got for free. The guy says it just went dead one day. I pulled it apart and found 3 or 4 places on the bottom of the power supply board that indicate burned or bad components. I have found replacement boards, but would like to know what may have caused the issue. The caps look fine, but I have not tested. The burnt components look to be small components, not near caps. I will add some photos when I get to my pc.
    Any help or things to check would be greatly appreciated!!
    Ben
  • Bmyers21
    • Mar 2012
    • 4
    Re: Vizio GV42L Power supply board question
    No help at all here? I am considering just replacing the board and seeing what happens.
    • realdeelz
      • Mar 2012
      • 6
      • usa
      go ahead post a few good pics of the problem area and we will see what can be done.
      • realdeelz
        • Mar 2012
        • 6
        • usa
        Ben, you also got to try to do your homework...there is plenty of info here...just gotta look around. I am new here as well..and I must tell you, its a great place to learn...welcome!
        • cashkennedy
          • Aug 2011
          • 668
          Yep without pictures we wont really be able to say anything. Are the burned parts on the primary or secondary side of the power supply? (Theres usually a thick white line deviding both sides, the primary is where the big fuse and power cable run to.
          Many things can damage the power supply : Poor design (if thats the case the used one could be close to burning out too), lightning, water, overheating from poor ventilation ...
          Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
