Hanspree "Unknown Model" 32" LCD: No picture or sound, power LED
    Re: Hanspree "Unknown Model" 32" LCD: No picture or sound, power LED
    Originally posted by shepp
    might work out cheaper to find a replacement board, what is the number on the transformers, i have a invertor here that may have the same transformers
    Mine are 6800 series
    6800 M B 0714G-
      I have never seen the inverter transformer with that high DC resistance (~9K).
      The pin out should be the same as yours transformer.
      http://lcdparts.net/TransformerDetai...ProductID=2772
        I've seen up to 6.5k on a 26" Samsung, but 9k is very high, I agree. In addition, there are only 7 transformers, meaning 7 tubes, which is a small number for a 32" (the 26" Samsung I serviced had 8 transformers, a 37" Philips had 12.)
          If I am correct, one transformer drives two lamps, as you can see, there are two high voltage windings on the transformer.
            Okay - that makes a bit more sense. So I might have been checking them in series, but I get >66Megohm resistance (OL on my meter) between any other pins.
              The two pins on each end are for the each winding as shown in the link. You can take one out a nd you can easily see what I am talking about.
              By the way, is the board made by DARFON?
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Got the inverter in front of me right now. The transformer wiring from budm's post (the lcdparts.net link) doesn't match. If I go by that, all primaries (on all transformers) measure open.
                Transformers on mine are labelled "6800 M 0722G-"
                Not quite sure wtf is going on with the results, but this inverter was working fine. Before disassembling the TV (cracked panel, only 1/3rd still visible) it ran through a 7 hour nonstop test without any hiccups.
                edit: Inverter is a DAC-24T042 Rev. 05A by Delta Electronics (?)
                  That's similar to my results, except the outer transformers measure 90k each on all secondaries. (One measures 98k, which is suspect.)
                  I will check later for drive waveforms... I have a feeling the inverter controller IC is dead.
                    Hi Scenic, are those the resistance reading on your transformers also, seems to match what TOM is seeing. Look like we need to remove the transformer from the board and see how they are wired up.
                    • shepp
                      • Mar 2012
                      • 377
                      • England
                      #30
                      this is what you should be measuring from budm's link, make sure your meter is set to the lowest range for 0.8 ohm tho, i did mine in circuit so as long as there not well out and all connectors are off the board you should be able to get the correct or there abouts readings, they may appear to be short if your meter is set to the wrong range because 0.8 ohms is nothing some meters might not measure this depends how good your meter is.
                      how are you measuring to get 90k-98k?
                      hope this helps
                        Makes more sense, thanks. Now getting consistent ~700 ohm (+/-1%) readings.
                        I can only find one primary on each transformer, they all test 0.3-0.4 ohms.
                          Shepp's picture is the same as the one in the link, now I am confused! It has only one primary windings, and two high voltage windings, two MOSFET's for the two primaries of the transformers in series driven by half bridge setup. All the readings are in DC resistance, the impedance will be higher, and you need the ringer tester to find out if it has shorted turn or not.
                          • shepp
                            • Mar 2012
                            • 377
                            • England
                            #33
                            p1 and p2 are first primary, p3 and p4 are second primary, and s1 to s2 and s3 to s4 for secondary windings in respect to 1st primary and 2nd primary
                            what do you mean by dc resistance? resistance is ohms? there is no dc or ac in resistance measurement? thats why you never check resistance when power is on...you will blow your meter
                              This why I am confused:
                              "Got the inverter in front of me right now. The transformer wiring from budm's post (the lcdparts.net link) doesn't match. If I go by that, all primaries (on all transformers) measure open." per post 27. I think we still need to see the actual pictures of the transformer in question.
                              • shepp
                                • Mar 2012
                                • 377
                                • England
                                #35
                                thats not what you should be measuring as in attached picture on post above^^
                                • shepp
                                  • Mar 2012
                                  • 377
                                  • England
                                  #36
                                  all the primarys should be roughly the same and all the secondarys should be roughly the same, ive only marked one side but the other side should be mirror image for readings, they should all be slightly differant by a fraction, but look for any that are well out compared to the others
                                  picture as per SCENICs upload
                                    One thing is that you are looking at the bottom view of the transformer, when you look at the top view as it is mounted on the PCB, then you can see that the Primary pins are connected to the traces close to the MOSFET's. the other two top pins will read zero. And that is why there is marking for pin 1 on the PCB for proper mounting of the transfromer.
                                    • shepp
                                      • Mar 2012
                                      • 377
                                      • England
                                      #38
                                      thats irrelevent, because your still measuring top to bottom pins not left to right etc, so you should still get correct readings across the correct pins, even if 2 primarys are connected you are still only measuring 1 winding so should still get the reading
                                        Okay, so I checked the waveform at the transformer primary pins using a scope.
                                        Completely dead, nothing, zip, nil, nada.
                                        Fuses are good, so controller's probably shot. I'll have to replace the heating element in my Aoyue 968 before replacing that IC. Unless anyone has an inverter going spare (Scenic ...?)
                                          But there are no wires attach to the P2 and P4, you can see the wire wrapped around P1 and P3. I look at my similar transformers I have, only one primary winding and two secondary winding, you can also see the white triangle marking on the footprint of the transformer. Unless my transformers are not the same setup as his, that is why we need to see the bottom side of the transformer.
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                            I ordered a supposedly β€˜new' Tcon board this time, and
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
