Samsung PS50C91HD - No picture, not sure which board is faulty
  • Amraks
    • Nov 2011
    • 725
    Re: Samsung PS50C91HD - No picture, not sure which board is faulty
    Nope I have been meaning to go shopping for one.
      You can spend $50 (USD) and get a decent analog scope these days, on the used market.
      • Amraks
        • Nov 2011
        • 725
        yeah I will have to grab one.
        I wonder what else needs replacing. would caps cause this?
        I haven't yet got the 3 caps tw2005 suggested.
          I've had caps trigger protect fault on the 42" panel, so I suppose it's not impossible... in that case though the cap was bloated completely.
          • Amraks
            • Nov 2011
            • 725
            if them fets blew again nothing would come up on the screen right?
              Yes and no, certain shorts could trigger protection after the panel initialises...
              • Amraks
                • Nov 2011
                • 725
                I can always get this flash when turned on.
                • Amraks
                  • Nov 2011
                  • 725
                  disconnecting the upper buffer board I get half the screen flash then it goes into protection mode.
                  Can this tv run with out upper buffer board, if not could this possible be my buffer repair?
                  Removing the chip would I'd expect the tv to turn on with chip removed?
                  • Amraks
                    • Nov 2011
                    • 725
                    nevermind I have found the answer to that.
                    you can run it. Would it be possible the voltages aren't being regulated properly and the y-sus is going into protection mode.
                    • Amraks
                      • Nov 2011
                      • 725
                      just tested the old mosfets from the top they tested good so I have a few spares.
                      • Amraks
                        • Nov 2011
                        • 725
                        Testing new 2SK2837 N channel fresh from packet.
                        a) black on pin 1- red on pin 2 - O.L
                        b) black on pin 1- red on pin 3 - O.L
                        c) black on pin 2- red on pin 3 - 2,732 kohms
                        One of the old ones from the bottom heat sink.
                        c) black on pin 2- red on pin 3 - 0.741 mohms
                        just testing them to verify that they are working correctly.
                        Plus still trying to get my head around this testing mosfets.
                        • Amraks
                          • Nov 2011
                          • 725
                          Originally posted by Amraks
                          Q5500 - k2837 - bad
                          Q5304 - 88n30w - bad
                          Q5303 - 88n30w - bad
                          Q5302 - 88n30w - bad
                          Q5306 - 88n30w - stuck on
                          I hope I tested right.
                          red probe on drain and black probe on source in beep mode on diode test on my digital multimeter.
                          after touching the gate with red while keeping black on the source, then touching back to drain with red probe.
                          Just learned something. only one was bad that was 88n30w location Q5306.
                          Needing some resistors that come in the kits and the zenor diode.
                          • tw2005
                            • Oct 2011
                            • 6458
                            I have no suggestions because all I've ever been faced with are the 88n30w fets and an upper buffer. At this time I'm not over interested in the dead samsung I have which needs a lot of work except I am interested in how the repaired buffer you did turns out.
                            • Amraks
                              • Nov 2011
                              • 725
                              Yeah me too I wanna see if I done a good job or not on it. I have no ESR meter to test the caps but I will chuck some new ones in.
                              if that don't work, I will replace the resistors and zenor diode. then if that don't work I will order a new Y-Sus.
                              The breif flash I am getting seems like the set sensors there is no control of the voltages and probably shuts off to the y-sus to protect the pannel.
                              • Amraks
                                • Nov 2011
                                • 725
                                fired it up with some new 25v caps replacing them 3.
                                with out buffer boards protection light was off not sure if this was fluke on a cold start or what.
                                installed buffer boards protection light on still. removed buffer boards protection light on still.
                                Cold solder?
                                I could hear power running threw it with out the buffer installed.
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  I think I am up for testing them mosfets again as I think the buffer chip blew them again.
                                  I have some new buffer chips coming as the ones i ordered were not in there correct packaging.
                                  they were taped to a bit of foam and I done my best to work with them but the chip did not line up correctly.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1195
                                    • Hellas ( Greece )
                                    #117
                                    Hello all.
                                    i have the same problem like many others in here, i have a ps-50c91h and i get sound but no picture / backlight at all.
                                    Facts : The Vs and Va voltages on the PSU sockets are ok (206 for Vs and 63 for Va), the LED5800 on the Y-Board doesn't light, not sure if it must be ON but it's not.
                                    Question : Service manual troubleshooting advises replacement of Y Board in this case (blank screen). Should i get this as a fact and check only the Y board for defect component(s) or not?
                                    • spippolone
                                      • Jun 2013
                                      • dark sky
                                      #118
                                      I take the opportunity to follow up on the first part of this question The problem it similar for my TV.
                                      I have a Philips 50PFP5532D. Sometimes the TV goin on and it work fine, someone you can see with horizontal line, someone it don't start, but if you go in off and on again start fine.
                                      I found some caps fault on power board, and une on X-main Board and I replace it.
                                      After the replace, the TV never goin on.
                                      The power supply it's OK all voltage there are.
                                      When I turn on the TV you can see the back led this video https://youtu.be/zDLEUFdOK7E. When the led on the board blinking you can a little buzz from X-Main and Y-Main, all the panel goin on 1 second, the VS go to 215V for a second and after VS go down and the panel switch off. The screen in this video https://youtu.be/QY_vWkm3YBg
                                      The front led is OFF when the TV is in Stand-by and fixed RED when the TV is ON
                                      X-Main is 50HD W2 PLUS X-MAIN
                                      Y-Main is 50HD W2 PLUS Y-MAIN
                                        09-07-2024, 05:50 AM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • JJAAMM
                                        by JJAAMM
                                        Problem
                                        07-06-2023, 06:01 AM
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Dodgethis
                                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                        by Dodgethis
                                        Hello all,
                                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                        09-11-2024, 07:39 AM
