smatvision 9005l-td
  • sbd
    • Mar 2012
    • 5
    • israel
    smatvision 9005l-td
    smatvision 9005l-td
    hi
    i have a problem the vga monitor work good but the tv and video input not work . thank you
  • selldoor
    Slow Learner
    • 7870
    Re: smatvision 9005l-td
    You will need to take it apart and provide photos of the Boards inside.
    Take one of the overall set up then one of each side of each board.You will also need to have a soldering iron and multimeter and be able to use them.
    Have you had the set some time and it has stopped working or have you just got it?
    It looks similar to one I have seen and the TV section is plug in module.
    Have you just tried it with the TV aerial or have you tried other inputs into the box
    video, svideo. composite?
    If it is a box take it out clean up the contacts, replace and try.
    • keepread
      Dell monitor PSU vs Dell laptop PSU
      by keepread
      Hi there!
      Someone gave me their old monitor, it's Dell S2715ht.
      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
      10-30-2025, 04:45 PM
    • wattage
      AOC AG493UCX 49-inch monitor - Firmware request
      by wattage
      Hello Badcaps Community,
      The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
      07-13-2025, 04:41 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
    • Rick_1234
      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
      by Rick_1234
      Good evening, gentlemen.
      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
      https://drive.google.com/file/d/1L6S...ew?usp=sharing
      Things I tried
      - Bought a new AC adapter thinking that was the problem but the problem...
      06-22-2024, 04:44 PM
      Wise Wing F199 19'' LCD monitor - recapped
      by momaka
      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
      When I saw the Craigslist post, I wasn't...
      08-24-2020, 10:58 AM
