Samsung TV still doesn't work after replacing capacitors twice.
  • viper92283
    • Mar 2012
    • usa
    A couple of weeks ago my parents Samsung Ln46a630 TV began clicking On/Off. Apparently this is a common issue and was so suggested to replace the capacitors. It worked for one week, and the clicking started again. The power light flashes with no clicking, but still no picture.
    Any idea was this may be caused by?
    Any help will be very much appreciated!!!
    Re: Samsung TV still doesn't work after replacing capacitors twice.
    Where did you get your replacement capacitors?
    Did you use low ESR high reliability types, or "RadioShack specials"?
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Welcome to the forum Please post a bit of information about yourself in the new members thread.
      Who replaced the caps- What caps did you/they use. Which caps were replaced.
      We need pictures of both sides of the boards - clear so we can read the legends
      straight on , no flash jpgs no bigger than 2mb file size and 2000*2000. Post them using
      Manage Attachments which is found by using the go advanced button below quick reply.
      • retiredcaps
        • Apr 2010
        • 9271
        Your TV is not listed, but see
        http://www.samsung.com/us/capacitorsettlement/
        --- begin sig file ---
        --- end sig file ---
        • viper92283
          • Mar 2012
          • usa
          Thanks for your replies!
          I ordered these capacitors from amazon.com/ Parts Express. (The originals were in visibly good condition, but like I mentioned the repair did work for a week.
          2x http://www.amazon.com/gp/product/B00...00_i00_details
          2x http://www.amazon.com/gp/product/B00...00_i02_details
          This is an image prior to repair:
          http://*************/photo/my-images...apacitors.jpg/
          • severach
            • Aug 2007
            • 1055
            It doesn't say low ESR so it probably isn't. GP caps can't take the ripple so they don't last long if they even work at all. Do you still have the old caps so we can pick some better matches.
            sig files are for morons
              They are Lelon - stay away from them. They may work but they are even worse that the original Samwha WB or XC caps.
              • viper92283
                • Mar 2012
                • usa
                I just found an image of one original cap. They are made by Sanwha.
                http://*************/photo/my-images/406/badcap.jpg/
                2x 16v
                2x 25v
                If needed I'd like to up them to 25v & 35v. Any recommendations? I'm thinking of these:
                http://www.mcmelectronics.com/product/31-5590
                  I don't trust caps that are just labelled low ESR since anyone can do that. Cheaper brands also haven't quite worked out how to make a reliable capacitor. Or they have, but they cut costs in order to sell them cheap.
                  Try these:
                  http://search.digikey.com/us/en/prod...1203-ND/356107
                  http://search.digikey.com/us/en/prod...1223-ND/356126
                  +$2.75 shipping in USA
                  There is this myth going around the internet that Samsung overvolted these capacitors. They did many things bad but not that. If they had overvolted them, they would have popped in a couple of days, not 13 months. No need to increase the voltage rating beyond what the originals were.
                  The failure of the originals is probably due to a bad batch as some TVs have Samwha WB working fine after a couple years. I've also pulled about 9 Samwha caps from an LG Plasma and 4 from an LG LCD, so it affected both major Korean brands (using Korean capacitors of poor quality.)
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    FM has lower ESR and more ripple than FC.
                    http://search.digikey.com/us/en/prod...2366-ND/613727
                    http://search.digikey.com/us/en/prod...2379-ND/613740
                    FC is Panasonic's "entry level" low ESR cap series. Panasonic FM/FR are their "better" grade in terms of ESR and ripple.
                    Choosing between FR/FM and FC all depends on what the original series of caps are. More details at
                    https://www.badcaps.net/forum/showpo...4&postcount=19
                    • viper92283
                      • Mar 2012
                      • usa
                      I am currently discussing the matter with BestBuy. They are agreeing to work it out. Will otherwise keep you guys posted. Thanks again for all your help.
                      There are hundreds of thousands of people who will also benefit from this as well.
                        That's nice. Generally with a big box retailer they'll let you keep the broken one, so you can try and fix it and have two TVs.
                        • johnnyM
                          • Aug 2013
                          Hi there,
                          I'm having the same problem.
                          I have the model LNS4041DX and I opened it up and replaced what seemed like two bad capacitors with 25V 1000uF Nichicon capacitors. Nothing on them said ESR, so I have no idea if they're any good or not, but the TV did not turn on and the clicking continued. I had never soldered before.
                          I'm in Canada and Samsung will not replace or help even though this model is under the class action lawsuit in the USA.
                          The power supply is: BN44-00134A and looks like:
                          Thanks!
                          Johnny
                          • Caleb
                            Smokin IC's
                            • Feb 2013
                            • 645
                            Suspect all the caps in the upper right corner of your picture, as I recall 2 2200 uf, 2 1000 uf were bad on mine, replaced with rubycon and nichinon and been happily using my tv for 6 months now
                            Liberating magic smoke one part at a time
                            • jose6326
                              • May 2013
                              • 707
                              order caps from digikey
                              its recommended that you replace with panasonic fr,fc,fm series
                              thats what i have been using since i signed up on this site and they have worked great
                              i always follow suggested recomemndations from the members on here because they know their stuff
                              i have also used rubicon caps if the panasonic caps are not available in the size i need
                              not sure what the opinions are on rubicon caps.
                              • truep
                                • Aug 2010
                                • 373
                                I also use mostly FM, FC panasonics or Nichicons with excellent results.
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 06:20 PM
