Samsung LN40A650A1F, no backlight
+ More Options
Posts
  • CraigParton
    • Feb 2012
    • 21
    Hello everyone! I'm a little new to TV repair and I was looking for a little help with this Samsung LCD TV. It will power up (red LED goes out) and you hear the startup sound as well as sound from the HDMI input I had connected to it. But the LCD screen stays dark. I opened it and noticed a blown 3.15A fuse on the power supply board (BN44-00198A). It wasn't the main fuse (obviously) but after looking over the board a bit I saw it protected the control circuitry for the high voltage transformer that powers the inverter board.
    After a little testing I found two MOSFET transistors (FQPF9N50C) that were shorted source-gate-drain. I replaced these and the fuse and powered the TV up. Fuse stayed intact but still no backlight.
    Now to show my newbiness. I'm an automotive tech with 13 years of experience troubleshooting and testing low voltage DC circuits. I have some understanding of how electronics work and I have a DSO and know how to use it. But I'm not exactly sure what I'm looking for. I did test the power source for the fuse that was blown. It comes directly off the bridge rectifier and the two 450V 2200uF filtering caps. I was reading close to 400V but it seemed to have a lot of AC riding on top of it. Again this may be normal I'm not sure.
    I diagrammed the main circuit for the two mosfets (minus the small SMD control circuitry) but I'm still a little unsure what they do. From the diagram and what I've read it looks like they convert the DC into a high frequency AC for the transformer. There's also a small SMD 30K resistor and a zener across the gate and source. Any information on how this works or how to test it would be much appreciated. Unfortunately I don't have a high voltage probe to test the transformer output directly.
    Thanks in advance!
    Re: Samsung LN40A650A1F, no backlight
    Please post good clear pictures both sides of the boards you are trying to fix using "attachment" in the advance posting.
    This will help us a lot to guide you, thanks.
    • CraigParton
      • Feb 2012
      • 21
      Here are the pics. Sorry I should have done this in the first post...
        OK, when the that high voltage MOSFET's shorted out like that, more likely it will take out the Gate resistor and Gate draining diode (there should be a low Ohm resistor in parallel with the diode which will be connected to the Gate of the MOSFET) for each of the MOSFET and it more likely taken out the SMPS IC output sections that drive the MOSFET also. If you travs out the gate conections, it should be connected to that 20-pin surface mounted IC on the bottom of the board.
        • CraigParton
          • Feb 2012
          • 21
          Thanks for the info Budm! The marking on that small surface mount resistor connected to the gate of the mosfet is 3002. Would that be 30,000 ohms? Also is the small diode is marked WL. Is it a regular diode or a zener and do I need to test it live? Can I use the scope to check the gate of the MOSFET to see if it's being controlled? If so what should the waveform look like?
            That does not sound right, it should be a lot lower than that, see example of how the MOSFET is being driven (single end setup), in you case it is a push-pull type setup so it needs two MOSFET's. See attached PDF.
            I cannot find any SCH for this power supply yet.
            • CraigParton
              • Feb 2012
              • 21
              Thank you for the schematic I'm trying to decipher it and understand what's going on. I'll try to diagram the circuit tomorrow and trace it back to the ic. Any tips on identifying those small smd components?
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Go by the silkscreen markings
                • C - capacitor
                • D - diode
                • F - fuse
                • IC - integrated circuit / controller
                • J(P) - jumper wire
                • L - inductor
                • LED - duh..
                • Q - transistor
                • R - resistor
                • S(W) - switch
                • TP - testpoint
                • U - packaged integrated circuit (for example linear voltage regulators)
                • Z(D) - zener diode
                This wikipedia article has a bunch more of those..
                edit: lookie what I found in my Samsung I/P-Board archive
                It's pretty sparse-looking, but better than nothing I guess..
                This I/P board looks one heck of a lot like the BN44-00199A I recapped for my LE40A536. Shopjimmy even lists the 199A as a substitute for the 198A
                I've attached the 199A pdf too, just in case.
                • CraigParton
                  • Feb 2012
                  • 21
                  Lemme just say, you are THE MAN! Thank you so much. That's going to help tremendously. I'll check it this afternoon and post results.
                    I look at the diagram, this is Power supply/Inverter combo board. The 30k and the ZENER are for the Gate protection.
                      By the way, Scenic, where did you manage to find all these SAMSUNG SCH from? Thanks.
                      • CraigParton
                        • Feb 2012
                        • 21
                        Now I see what blew the fuse. When the MOSFETs shorted it gave diodes DI221 & DI223 a straight path from ground to power. I did notice the solder trace on one of those had been hot. I forgot to mention that I tested the larger power diodes DI221, DI222, DI223, and DI224 with one leg unsoldered and they tested fine with the diode test funtion on my multimeter. I'm wondering if they're failing under power.
                        So from what I can see (with my limited knowledge) it appears that UI101 uses the AOUT and BOUT terminals to control the transformer TI202 through a series of mosfet and bipolar transistors. I'm assuming those are used to step up current. The transformer amplifies the voltage of the control signal (AC at this point?) into the MOSFETS I replaced (QI201 & QI202). These MOSFETS control the high voltage transformer TI201 that powers the inverter backlights.
                        So now for more newby questions. Will the transformer isolate the damage from the shorted mosfets to DI103, DI104, DI110, DI111, QI101, and QI202? I'd like to check these control signals with my scope, so if anyone could give me a little operational theory on what's going on here it would help me a lot. For example, what is the whole circuit trying to accomplish? I know the high voltage transformer is stepping up the voltage to light off the backlights, but is the control circuitry amplifing the frequency as well? Any idea which components might be damaged?
                        I have to leave for a couple hours but I'll test this stuff when I get back. Again, thank you budm and scenic for the excellent info.
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          @ budm: They're from all over the place. Most of them came from some russian website, hosting the files on a russian filelocker (sort of like Rapidshare etc.)
                          Was pretty tricky to get them, as the websites were completely in Cyrillic and I couldn't use google translator on the download page (told me it already was in english for some reason), so I had to figure out where to click to start the download by randomly clicking almost every link
                          I've re-uploaded a bunch of those to a filehoster, but they're censoring the search results, so the files don't show up when you search for them
                          • CraigParton
                            • Feb 2012
                            • 21
                            Scenic I found a service manual for the european version of this tv on a similar site. I had to manually dump the text into google translator to figure out how to register and download. No schematic for the power board in that manual, but I really don't need it now do I?
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              I just took a look and found the service manual for the A65x series (LE__A65_) LCD TV's (the LE indicating it's the european model)
                              It's probably the same thing you found, except I didn't have to register to download it.. instead I had to deal with a shitton of popups -.-
                              It's a ~30MB zip with the SM split up into several PDF's
                                One caution, when work on the Line (hot side) of the circuits, make sure to use Isolation transformer to power up the board and the whole thing should be powered through the GFCI outlet to protect yourself.
                                • CraigParton
                                  • Feb 2012
                                  • 21
                                  One question on that isolation transformer: The scope I'm using is battery operated and doesn't plug into the wall at all. Will I still need that?
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    You can observe waveforms, but be very careful. I wouldn't even touch the scope when the TV power supply is getting AC voltage. The voltage on the scope is potentially as high as 400 volts.
                                    PlainBill
                                      Well the scope will become part of the Line side of the AC, if you touch the metal part of the scope, the AC current will flow through your body to ground, it will be hard not to accidentally touch the high side of the circuits, especially when you have have to attach the ground side of the scope probe to circuits. I deal with line voltage circuits everyday, you only get to it wrong once.
                                      These are part of my main tools:
                                      http://s807.photobucket.com/albums/yy352/budm/Tools/
                                      • CraigParton
                                        • Feb 2012
                                        • 21
                                        Sorry I should have specified which scope I was using. It's an automotive scope/scan tool. Its a Snapon MODIS. It's handheld 4 channel scope and the entire case is plastic. No exposed metal. I checked the voltage rating and it's rated at 400V AC/DC. The highest voltage I've seen on this supply (except the HVT) is 380V. Close but just inside the limit.
                                        But I may not even need to test it live. Not that I could, most everything I need to test is on the bottom of the board. I checked between the gate and source of QI201 and the resistance is 9 ohms. There's a definite short somewhere. Gate-source resistance of QI202 is 30K (the gate protection resistor). These use identical control circuits so something is definitely shorted. It has to be either the MOSFET itself (QI201, but its new), the zener diode (ZI101) or QI101. RI130 tested 68 ohms and the resistance between the base of QI101 and ground was 235 ohms (parallel resistance of both 470 ohm resistors). My guess is ZI101 but I'll desolder and test these and post the results.
                                          09-07-2024, 05:50 AM
                                        • Attila Jamilov
                                          Which fuse is responsible for backlight on Lenovo Thinkpad T14 Gen 3
                                          by Attila Jamilov
                                          I upgraded display from HD to UHD recently, and I think I did everything right, battery was disabled in BIOS, and removed, yet the screen has no backlight. Both the old and new display behave the same way. I checked the motherboard and I see the fv1 fuse, and a fv2 spot for a fuse, but it's missing. Does anyone have any information on whether fv2 is responsible for backlight, or why it's missing? There's a schematic posted somewhere on this forum, but I can't view it as I don't have the hardware right now, since the laptop screen is broken and I run Linux.
                                          Also from further search...
                                          04-20-2025, 10:02 PM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
