Fix for the Vizio VW26L power supply good but tv unresponsive
  • slimbobaggins
    • Feb 2012
    • 6
    Hey guys,
    Over the last few weeks, I've started buying broke LCD's off craigslist and fixing them to resell. As a result I found this forum, and have been lurking, getting tidbits of info from the different threads.
    Well, I wanted to give back a little.
    I recently picked up a Vizio VW26L...I don't know the history of the tv, as the guy I bought it off wasn't the original owner, he bought it to broke himself intending to fix it... sympton was the tv was completely unresponsive when plugged in, not even standby lights.
    I opened the TV up, the main AC fuse was blown, so I replaced that. Once the fuse was replaced, I had the 5V standby, but curiously I was also reading the 15V and 24V as hot at all times. Still no standby lights, and pushing the power button had no effect.
    Long story short, it looks as though the heat sink to the processor on the main board must have been shorting out a couple pins, causing the tv to be unresponsive.
    I had removed all the boards, inspecting for damage, and had removed the heatsink to inspect the processor. Finding nothing, I reassembled the tv and was shocked when I plugged it in and it came to life.
    Thinking that there had been a loose pin somewhere that I had reseated when I reassembled the tv, I slapped the heatsink on with some artic silver and high temp rtv, and was disappointed when plugging in to see that the tv had gone back to its previous unresponsive self.
    Realizing that the only thing that had changed was the heat sink, I inspected it, and sure enough, some Artic Silver had blobbed onto a couple pins. I cleaned it off with a Q tip and alcohol, and the TV is back to working fine. The heat sink had previously been held on with an adhesive pad, so I'm not sure how it had shorted the pins, but the heatsink is so large that it's right at the edges of the chip. I'm going to pull it back off and put a bevel on the edges to make sure that it doesn't touch or blob out the artic silver again.
    Hope this helps someone else out. I'll be around on the forums every now and then, as I just picked up a 44 inch the other day for $25, and will keep trying to do this just to make some extra cash.
    -Jim
  • slimbobaggins
    • Feb 2012
    • 6
    Re: Fix for the Vizio VW26L power supply good but tv unresponsive
    Well, I haven't pulled the heatsink back off to modify it yet, but I've been using the TV to test it out, and it's started having an issue with horizontal lines and the image not being correct... the image will move up or down or become "smushed." I don't know if this is due to the processor/heatsink issue, or another problem that needs diagnosed. I won't have time until later this week to modify the heatsink and seal it all up, so I'll report back then.
    • southboundsuarez
      • Oct 2012
      • usa
      And ???? What did ya find out? I also have a troubled vw26l.
      • slimbobaggins
        • Feb 2012
        • 6
        Sorry, just seeing this now years later. I ended up replacing the main board of the tv.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • harp
          Metod for removing glued heatsink from fragile component
          by harp
          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
          06-23-2025, 02:01 PM
        • Ven
          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
          by Ven
          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
          07-08-2024, 09:32 AM
