Re: Philips 42PFL5432D/37 I May Have Made my Problem Worse
THANKS EVERYBODY!! got the parts in soldered them in an tv has been on for about two hours now. the only thing is the power mosfet that came in was smaller than the original so i had to bend the pins like a pitch fork. now i officially brought my first tv back from the dead. 32 inch proview might be next.
(parts, didn't know my links were broken)
RGP10M-E3/73GICT-ND --diode
497-5972-5-ND--mosfet
here is what i came up with for replacements what do you guys think
http://search.digikey.com/scripts/Dk...83558489434679
http://search.digikey.com/scripts/Dk...83558489434679Leave a comment:
D912 is bad. Remove from the board to verify.
As for the mosfet, some of the values are a little higher (drain voltage) and (drain current) but if digikeys tech claims the mosfet are a cross then chances are it will work. That mosfet would definatly pop a fuse as soon as the tv is powered on. How many fuses do you have left? I'm thinking of you replace that mosfet and diode you should be back in business.Leave a comment:
diode readings all "in-board"
BLACK DIODES IN PIC
zd 904 .638 reverse no change or 1.
zd 902 .638 reverse 1.
d 907 .555 reverse 1.
d 925 .533 reverse 1.
fb 918 .000 reverse .000 ??
D 912 .000 reverse .000 ??
d 911 .564 reverse 1.Leave a comment:
the setting i use is the 2k setting it has the " -->l-- " symbol on it i posted a pic of it on post #14. i tested the bad mosfet under 2m, 200k, 20k and all pin combinatons tested .000. i tested good mosfet got no change or 1. on all pin combos. (under 2m, 200k, 20k) so now i searched for the replacement and found that it is an obsolete part (http://search.digikey.com/scripts/Dk...Words=W18NK80z). i got on help chat with them and they recomend this (http://search.digikey.com/scripts/Dk...-5-ND&x=7&y=11) do you guys think the specs are close enough?
then on the pfc, with red on pin6 (gnd) to pin 7 (gd) i get reading .115 then i switch red to pin 5 then back to six the reading changes to .026 (under 30 ohms .030 indicates short right?) should i just desolder and test out of circuit? sucks cause digikey says this part is also Non-Stock. http://search.digikey.com/scripts/Dk...Words=sg6961sz i am alsso thinking some other diodes went bad causing the mosfet to go bad or does the pfc control the mosfet?Leave a comment:
As for the pfc chip on the back. I uploaded the datasheet. Ground and ZCD are the 2 corner pins. So atleast try the other 3 corners. If its under 30 ohms then its bad but i'm leaning towards the one mosfet (blue)Attached FilesLeave a comment:
here are the results from mosfet circled in blue
positive on pin 1 to 2= .003
positive on pin 1 to 3= .003
positive on pin 2 to 1= .003
positive on pin 2 to 3= .000
positive on pin 3 to 1= .002
positive on pin 3 to 2= .000Leave a comment:
removed mosfet you circled in red test results
with positive on pin 1 to pin 2 =no change or 1.
positive on pin 1 to 3 =no change or 1.
positive on pin 2 to 1= no change or 1.
positive on pin2 to 3 = no change or 1.
positive on pin 3 to 1 = no change or 1.
positive on pin 3 to 2 = .514
all under 2k. i tried to use 200 setting but the number goes away too fast and is never the same
Now, the chip on the back. With positive on pin 8 to 6 is no change or 1.
positive on pin 6 to 8 is .651 did i do this correctly or did you need me to test all combinations? just trying to be thorough.Leave a comment:
the diode that was circled in green for me by retiredcaps is reading .454 and no reading the other way this means that the diode is still good and can be soldered right?
the bridge rectifier readings are
pin 1 and 2 .548 ,reverse is no reading
pin 2 and 3 no reading either way
pin 3 and 4 .566 ,reverse is no reading
so according to the video this should be good.
also @ mr.bill the chip#is sg6961sz b1aa1720713e
thanks everybody for the time you are using to help i really appreciate thisLeave a comment:
No blown fuses yet but I did have the same bad caps. At first I only replaced the bad ones but the PSU was making a considerably loud, high-pitched chirping. (buzzing, humming,...whatever you want to call it.)
Then I replaced the remaining caps. Since doing that, the sound is now almost completely gone and it doesn't seem to run quite as hot. But now I'm getting some sort of surge on the T-conn board that blew a small SMD capacitor. The TV seems to work fine without it. I tried replacing the T-conn board but the picture fades to black. Put the old one on without that capacitor and it works. I'd prefer not to run it like that, but...Leave a comment:
ok here we go,
W26NM60 (red) & W18NK802 (blue) are your power mosfets. Check them for shorts (under 30 ohms). I clipped a pic on your photo to help you. Check pins 1-2, 1-3, 2-3
IC902 on the back of the power supply is your Power Factor Controller (PFC). Assuming the dot on the chip is pin #1, check between pin 6 & 8.
Both above check with meter on the ohms setting (Ω). The 200 scale will work fine. Anything under 30 ohms will need to be removed from the board and checked again. If they are good the meter is going to display either 1 or OL because its going to be in the (k) or (m) range and thats well above 200.
I had a bad pfc controller that shorted out and took the fuse with it. Let us know the results.
Lobo, is your tv doing the same as m1dp? (blowing fuse)Leave a comment:
I have the exact same TV and PSU and the best I can make out on the chip is
SG6961S7
B1AG2897728E
Hard to tell if the first digit in the second row is a "B" or an "8", I just guessed B.
Also, the "mosfet" is actually a diode.
STTH8L06FP
GK0G7 VU
CHN 725
The chip behind it in the picture is a mosfet.
W26NM60
CC126 V3
MAR 719
The one next to it (not in the pic)
W18NK80Z
CC099 VW
MAR Z25
Hope that helpsLast edited by Lobo; 03-14-2012, 07:41 AM.Leave a comment:
I now removed the bridge rectifier and like the mosfet am getting jumpy readings do thes indicate shorts?
i've tried every pin combination. some do stay at, 1. ,with no change and others jump high then back to 1. on the 200 ohms setting. the only results i am getting that stay steady on are when i change the meter to 2k voltage drop. anyway you can clear this up for me so i can get the proper results you need
https://cdn.badcaps-static.com/pdfs/...8a934e8c25.pdf
The ??mosfet?? you removed actaully looks like a diode (marking on board) The mosfets might be the 2 chips behind that one with the 2 bands clipped on them. Can you get a photo of the 2 chips?
Also, I circled a chip on the backside of the power supply, can you make out the numbers on it. Its a real pain but sometimes you get lucky, a magnifying glass helps.Leave a comment:
https://cdn.badcaps-static.com/pdfs/...8a934e8c25.pdfLeave a comment:
i removed the power mosfet you circled in green and was getting jumpy readings with the 200 ohms setting. I noticed on the pcb in front of the chip is a voltage drop sign so i adjusted to the 2k ohms with voltage drop setting and got no change one way and a reading of .454 ohms the other.Leave a comment:
1) In purple, I think that is the bridge rectifier.
2) In green, I think that is the power mosfet.
3) Set your multimeter to 200 (two hundred) ohms.
See the section on multimeter below
https://www.badcaps.net/forum/showpo...4&postcount=19
and mistakes
https://www.badcaps.net/forum/showpo...2&postcount=31Last edited by retiredcaps; 03-11-2012, 08:13 PM.Leave a comment:
I think the one in RED circle is the Bridge rectifier (4 pins), and the blue with 2 pins is the AC line filter cap.Leave a comment:
the power mosfet you circled is 4 pins, the bridge rectifier is two pins.
will you please tell me what setting to use for ohms? i am only getting results from the continuty beep setting. also notice the smudge on the big brown lelon does it look bad to you and can that be the fuse popper?Leave a comment:
The cap is the one that was originally on the board. It's the only one I haven't replaced yet. I've tested it and it seems good to me. At least I think I'm reading the Lelon datasheet right. (google translator doesn't really do a good job with their website) It's just that the size and uF don't match up with what's on the schematic.Leave a comment:
@Lobo - I wouldnt have thought so- in any case there may have been revisions since the schematic was produced. - Was the Lelon in from new?
You could change it and see if it helps?Leave a comment:
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by Ifixstuff9I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector... -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug... -
by aidanmoHello,
I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
I thought maybe the speakers got damaged, so I replaced them - no dice.- Using the internal speakers, it always happens.
- Using the headphone jack, it never happens.
- Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
by CornitoHello Team,
New issue on LCD panel where I need to find out the cause and the potential solution.
This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
I've checked voltages, no issue found comparing right and left side of the panel driver.
VHG VGL CKV... are the sames on... - Loading...
