Samsung LN26A450C1D No Power
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Samsung LN26A450C1D No Power
    Probably forgot his password.. (?!)
    There's a password revovery function in pretty much every forum. Notice the links below the login field (especially after a failed login attempt).
    • canadapettit
      • Feb 2012
      • 16
      OK I got it firgured out and fixed. Thank you very much Scenic because without that diagram you gave me, and i apoligize for jumping the gun saying it shouldn't work. The problem was the power supply control ic was bad, along with an 18 volt zeiner and an open fuse resistor. $4.00 worth of part and we are going.
      • 23six
        • Aug 2012
        Can u post pics of what u changed plz
        • kymatica101
          • Oct 2012
          I'm having the same problems with the exact model tv, is there anyway you can point out what exactly is needed to be replaced... part numbers (of power supply IC, 18volt zeiner and open fuse resistor) or diagram using a picture if possible. I would appreciate your help very much!
            What is the part number as printed on the board? BN-XXXXXXXX?
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • mrtek
              Samsung UN43NU6950FXZA No power
              by mrtek
              Hi
              Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
              Main fuse = OK
              Back light LED = OK. Power them with aux power source
              LED output = OK 156V
              I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
              Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
              Yesterday, 08:06 PM
            • hill01
              Samsung UE75MU7009TXZG Endless Power Cycle
              by hill01
              Hi everyone and thanks in advance for any help I might get here
              My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
              About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
              Since a few days, the TV won't turn...
              11-17-2021, 02:52 PM
