Sharp lc-42sb45u no response... at all.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Just got this TV in as dead... it's mine now, but I need to fix it for it to be worth anything. Caps are CapXon, and I replaced 2 of the 4 on the PSU board, but I didn't have any 680uf 50v caps for the other two.
    The +5v is sitting at 4.4v coming off the PSU board. At the power switch itself, I have 2.7v.
    There are 4 wires going to the board that has all the switches on it. I'm measuring them as such:
    Red - 0.00 v
    Grey - 2.7v
    White - 2.7v
    Black - 0.65v
    When I push the power switch, black drops to 0.00v.
    Is the low +5v the problem here? If so, would I look to the other two capxon caps as the culprit? I'm uploading pics now and will post them shortly.
    Ludicrous gibs!
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Sharp lc-42sb45u no response... at all.
    Here's the power board -
    Ludicrous gibs!
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I've got high-res shots if anyone thinks looking at them would help. I'm not the best at diagnosing circuits... I generally just replace caps and hope for the best.
      Ludicrous gibs!
      • retiredcaps
        • Apr 2010
        • 9271
        That would be my guess. Almost all TVs require a stable 5V standby in order for the main board to work properly.
        --- begin sig file ---
        --- end sig file ---
        • retiredcaps
          • Apr 2010
          • 9271
          It will help. Please use manage attachments for my sake.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            For now, here's cell phone pics on smugmug - http://nadams.smugmug.com/Other/Sharp-TV/
            I'll grab my digi now and get some better shots. I'll upload those here.
            Ludicrous gibs!
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Main power board -
              The output of the power board is labeled as such. Both Power On/Off and +5v measure 4.4v
              The 4-pin connector goes to the switch board-
              Ludicrous gibs!
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Sorry, Power on/off doesn't have any voltage on it. The two lower grey lines do. Is the switch supposed to pass voltage, or short to ground?
                Ludicrous gibs!
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Okay, let's break this down.
                  1) The most important voltage right now is 5V standby just below the power on/off. If it is not steady 5V, the main board will likely not work. 4.4V DC is way too low.
                  2) Power on/off is a pin that is toggled high (> 3V DC) by the main board when it is working properly. It tells the rest of the power supply to turn on.
                  3) Disconnect the main board from the power board. See if 5V standby is a solid steady 5V. If yes, then something on the main board is dragging down the power supply. If no, then something is wrong on the power board.
                  4) I see a lot of Capxon caps. You know what that means.
                  5) The service manual and power board schematic is on page 79. (22MB).
                  6) I snipped out the portion that relates to 5V. Refer to diagram.
                  7) With the main board disconnected, I would check D927 (middle pin or pin 2) and see what the DC voltage is. This should be 5V or more.
                  8) Check the DC voltage across C955 (the new Panasonic cap).
                  9) Check the DC voltage across C934 (47uF 25V) cap.
                  10) Remeasure 5V connector pin.
                  11) Report readings for 7, 8, 9, and 10.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Something strange here. R941, R944, R945 form a voltage divider that sets the output voltage of the supply. Q918 and R947 'tweek' that setting. With Q918 off the outpit voltage should be 2.50 * (1+ 11K/18K) With Q918 on the output voltage should be 2.50 * (1+ 11K/9.9K). You do the math.
                    PlainBill
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      I'll be checking out everything when I get home from work later... I can tell you now that 4.4v is with the power supply board disconnected from everything, so the problem lies in the power supply itself. Also, the reading across C955 is also 4.4v
                      Like I said, I'll get all the info to you when I get home. If need be, the option is always there to just buy a replacement board off eBay and recap it. They're only $40... but I'd rather give fixing this one a shot.
                      Ludicrous gibs!
                        What does the STANDBY logic line measure at?
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          Retiredcaps - 7, 8, 9, and 10 all measure 4.44v
                          Ludicrous gibs!
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            I'm exhausted. I will take a look again when I get some rest and a clear head. I have the feeling the answer is front of me, but right now I can't see it.
                            And yes, I did the math that PlainBill wrote earlier.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              One last thought before I retire for the night.
                              If Q918 (a NPN) isn't turning on, then there are two possibilites.
                              One, R920, a 10K ohm resistor is open. Voltage never gets to the base.
                              Two, Q918, is non functional. It could be shorted? Test all combinations for shorts. That is, base-collector, base-emitter, emitter-collector. Any reading less than 30 ohms suggests it might be shorted and should be desoldered and verified out of circuit.
                              tiredcaps
                              • dood
                                Deputy dood
                                • Mar 2004
                                • 2462
                                tiredcaps
                                R920 measures at 9991ohms
                                Q918 has 2.47v at what I'm assuming is base (the single pin on one side)
                                IC911 has 4.16v at pin 1 and 3.14v at pin 2.
                                IC909 appears to be where the 4.44v is coming from... I get 4.44v on pin 1 and 3.78v on pin 2.
                                What setting should my DMM be on to test the resistance of Q918? Also, if I'm looking at Q918 with two pins at the top and one pin down, Which is base/collector/emitter?
                                Ludicrous gibs!
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  If you have a manual meter, set it to 200 ohms scale.
                                  Emitter is the down arrow, collector is top, base is middle. It really doesn't matter if you just number the pins 1, 2, 3. Measure between 1-2, 1-3, and 2-3. That covers all the bases.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Don't forget to check this as tom66 requested.
                                    • dood
                                      Deputy dood
                                      • Mar 2004
                                      • 2462
                                      Would that be the pin for Power On/Off?
                                      In-circuit, on the 200 ohm scale, Q918 measures open.
                                      Ludicrous gibs!
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        1) Okay, let's assume Q918 is working fine. I neglected to see/spot C942 last night just before the base of Q918.
                                        2) For the standby line, I can't see a test point on the connector so I would suggest measuring on the right side of the R920 or R946 resistor (as per schematic). I suspect that will be 4.4V DC as well.
                                        3) I'm curious, what is the voltage reading on the collector (top) of Q918?
                                        4) What is the voltage reading on the emitter (bottom) of Q918? I suspect I know the answer, but would like confirmation because my schematic interpretation skills aren't the best.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • gavenb
                                          Sharp LC-80LE661U 80 inch
                                          by gavenb
                                          Hi folks!
                                          I have a LC-80LE661U that had some interesting issues.
                                          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                          11-12-2023, 02:05 PM
                                        • SONY_E-WASTER
                                          Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                          by SONY_E-WASTER
                                          Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                          The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                          then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                          does...
                                          12-26-2021, 05:46 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
