Plasma Y-MAIN board LJ92-01200A
  • Cailloux
    • Feb 2012
    • 26
    Hello, I need help to troubleshoot a Y-MAIN board LJ92-01200A (LJ41-02759A) at the component level.
    Prima plasma TV model PH42T7.
    Initially, I found the two Y buffers defective, on the Y main a short circuit mosfet Q5009 (One of these 7 transistors in parallel), and a diode short circuit D5022.
    D5022 is indentifies F6 5L.
    I bought two new Y buffers boards, LJ41-02761A / LJ41-02760A, Q5009 I removed, and installed a 1N4007 diode (1 amp) at D5022.
    I have not replaced Q5009 for now.
    I installed Y upper board, and the Y main.
    Turn on TV for 10 seconds.
    Top side of the picture is good and clear.
    I removed upper Y board, and installed lower Y board.
    Bottom side of the picture is very bad, garbage on screen.
    D5022 diode short circuit again. Something kill it.
    I checked the Y buffers boards, no short circuit on both.
    I tried a second time the same operation with a diode 2 amps, same thing.
    What's going on?? All fuses are good.
    Another component of the Y main is in fault?
    Is it possible that IPM module (the big IC) is defective?
    Thank you for help.
    Re: Plasma Y-MAIN board LJ92-01200A
    You can't replace a high speed surface mount Schottky diode with a general purpose type! No matter how many "amps" it has.
    • Cailloux
      • Feb 2012
      • 26
      Hi Tom,
      You're right, I'll get a Schottky diode, but I do not know the values of amperage and voltage.
      What is strange is that the diode fail only with the lower Y buffer. She has no short circuit.
      I'll keep you informed. Thank you.
      • cmj21973
        • 267
        Originally posted by Cailloux
        Hi Tom,
        http://www.marsport.org.uk/smd/mainframe.htm
        F6 CMOZ3V9 CSC I SOD523 zener 350mW 5% 3.9V
        I'm 80% sure this is what your looking for, but I'd get a second opinion from someone more experience.
        • Cailloux
          • Feb 2012
          • 26
          In my research, I saw this suggestion in another forum. I do not think it is a zener on the board because it is indentifies D5022, not Z5022. It is connected from the anode to a transformer, and the cathode to a capacitor of 100UF-160v. Seems to be a circuit filter.
          • Cailloux
            • Feb 2012
            • 26
            Hi Tom,
            I tried with a Schottky diode 3A 200V on D5022.
            I installed only the lower Y buffer.
            The diode shorted again but this time the lower Y buffer also short.
            Do you think the Y buffer was defective even though she had no short-circuit at the beginning?
            Or is it possible that the bottom screen is defective??
            Have a suggestion?
            • Cailloux
              • Feb 2012
              • 26
              Sorry I do not know how to deleted this post.
                The Y-main sends the same signal to both boards, so it's likely that you got a defective lower buffer.
                • Cailloux
                  • Feb 2012
                  • 26
                  Finally, problem solved.
                  Previously I had bought another used Y buffer $50. It was defective, the seller would not refund my money. I have long questioned, about the Y-sus board.
                  I take a chance, I'm crossing my fingers. I recently bought another used low Y buffer (another $50), and replaced Schottky diode D5022 3A 200V.
                  TV repair, it cost me $300 ($50 purchase of the TV, a new set of Y buffer $150, two Y buffer used low $50 x 2 = $100, and two Schottky diode.
                  I added on the back cover two fans on each side.
                  Tom66 was right, Y-sus was not involved.
                  Thank you for your cooperation.
                  • pchung_94565
                    • Sep 2012
                    • usa
                    Hi, Cailloux,
                    Just wonder is your TV still working, I've same problem as your describle in post#1.
                    • Zalinar
                      Zalinar
                      • Sep 2012
                      • 10
                      Hi there, Does anyone know what ZD5003 is? Mine is shorted
                      • Zalinar
                        Zalinar
                        • Sep 2012
                        • 10
                        I answered my own question after some research.
                        It looks like ZD5003 on the Y board is an RLZ18 Zener that is no longer available.
                        Cross Reference analogue: BZT52C18-7-F 18V 500mW
                        Available both from Mouser and Digi-Key
                        Hope this is helpful.
                        • SevillianSTS
                          • Nov 2013
                          • 31
                          Can anyone run through the common faults on a lj92-01200A I have narrowed my problem down to this board but am unable to find anything wrong with it. No bad caps, and none of my zener diodes appear to be shorted. ?
                          • SevillianSTS
                            • Nov 2013
                            • 31
                            The fuse has not blown, and the TV still goes to standby if I install this board without the fuse and no buffers attached.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              When samsung lj41-02761 buffers short *check d5018 d5009 resistors r5090 and r5028 on lj92-01200a ysus board along with mosfets under heat sync.*Also sometimes if sustain pulses like a cycling effect check D5022 near small transformer.******
                              • SevillianSTS
                                • Nov 2013
                                • 31
                                My TV uses LJ92-01203a Y Buffers. Does that make a difference from the 02761 Buffers you mentioned. How do I check the mosfets under the heat sink.
                                Thanks.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  No. That is the same buffer. Samsung uses two part numbers on these boards.
                                  As for the mosfets on the ysus. Look at the wider of the two aluminum heat syncs. They are held on by two posts that solder to the board. Hot one with an iron. Get a wooden dowel and pry the heat sync loose. It will have residential glue like substance thay acts as a heat transfer compound to all the mosfets underneath. This will need to be scraped off later as well as the face of the mosfets and have some new heat transfer paste added to each again upon re installation.
                                  Once the heat sync is off remove one leg from each mosfet from the board on each. Read between the pad and the lifted leg and look for a shorted one. Removing the mosfet is a trick thou. Yo u need plenty of heat. U use a 100 w weller solder gun along.with a 30w iron and solder flux.
                                  installing the new MOSFET is even harder. You need to make sure that when the MOSFET is seated on the board it is flat with all the others because if its not the other mosfets will overheat as the heatsink won't touch the other ones it is a real treat to do.
                                  • SevillianSTS
                                    • Nov 2013
                                    • 31
                                    When you say "wider of the two".... There are 3 heatsinks on this y-sus. A very large one; and two smaller ones... one of which is a little longer than the other; is this the one you are referring too ?
                                    I am measuring .5 ohms across each resistor R5028 and R5090. I see they are in parallel, is this affecting their individual readings ? They are labeled red, black, gold, gold; so they should be 2 ohms and in parallel should = 1 ohm ?
                                    Or should I remove one leg to test these resistors individually ?
                                    With my black probe on the stripe of D5018 and red probe on the other end, my meter beeps when on diode/ohms mode. If i reverse the probes it shows nothing.
                                    D5009 does not beep either way I put the probes on it.
                                    Am I testing these diodes properly, or do I need to remove them from the board first ?
                                    In ohms mode: I get 5.8 ohms across D5018 and 2.2 megaohms across D5009
                                    I feel like I'm slowly getting there, and your help is much appreciated.
                                    • SevillianSTS
                                      • Nov 2013
                                      • 31
                                      In diode test mode for volts; with black on the stripe of D5022 and red on the other side I get .456v and when I turn them around I get nothing.
                                      When on diode test of ohms mode I get no reading; I did notice that if I keep switching the probes back and forth that D5022 causes my meter to beep (very short) and I must keep reversing them back and forth.
                                      Again, I did this with the diode still on the board, should it be removed first ?
                                      • SevillianSTS
                                        • Nov 2013
                                        • 31
                                        Just decided to remove one of those 2 resistors.
                                        They both measure 1 ohm individually, and I guess it is brown instead of red, so they appear to be ok.
                                        What are you thoughts on the diodes questioned above ?
                                        Thanks.
                                        • asr
                                          Finding replacement diode iPad Pro 3rd gen A1701
                                          by asr
                                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                          07-09-2024, 06:24 PM
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
                                        • NicRac
                                          monowheel repair,Is the diode the problem?
                                          by NicRac
                                          Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                          First of all, I am new here. Therefore I will shortly introduce myself.
                                          I am Nico and currently I study Physics.
                                          In my freetime I like to build and repair stuff. Especially big battery's.
                                          A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                          The battery bms was broken so I replaced and resolder that. Nothing big.
                                          I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                          07-26-2024, 06:13 AM
                                        • dennis_elx33
                                          NO BODY MARKING Diode
                                          by dennis_elx33
                                          Hello Everyone,
                                          I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                                          While compared to the reading of another diode from the next channel it won't read at reverse bias.
                                          Now the problem is; it does not have any body marking.
                                          So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                                          What do you think is this diode?
                                          Can you please suggest what part number can i use to replace this faulty diode instead?
                                          Hoping that you...
                                          06-14-2024, 12:36 AM
                                        • eccerr0r
                                          Electric lawnmower...purpose of diode...
                                          by eccerr0r
                                          I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
                                          The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
                                          08-27-2022, 12:54 PM
