Philips 42PFL7422D/37 Backlight Issue
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Philips 42PFL7422D/37 Backlight Issue
    Okay, let's try this.
    The pins are numbered 1 through 10 on the pcb. Last pin = 10.
    a) black probe on pin 1, red on pin 2 - record ohm
    b) black probe on pin 1, red on pin 3 - record ohm
    c) black probe on pin 1, red on pin 4 - record ohm
    d) etc
    e) black probe on pin 1, red on pin last - record ohm
    f) black probe on pin 2, red on pin 3 - record ohm
    g) black probe on pin 2, red on pin 4 - record ohm
    h) etc
    i) black probe on pin 2, red on pin last - record ohm
    j) black probe on pin 3, red on pin 4 - record ohm
    k) etc
    l) finally, black probe on pin last-1, red on pin last - record ohm
    What we are doing is trying to measure every possible pin combination to find the secondary pins. It shouldn't take more than 10 minutes to do this.
    --- begin sig file ---
    --- end sig file ---
    • jthi
      • Jan 2012
      • 18
      Thanks retirecaps - I think I was typing out my long reply above before I saw your post. The above readings are with S1 and S2 on opposite sides of the transformer. On T1, S1 is the outer most corner pin (where I have the black probe on the Master_old picture above), and S2 is the first pin from the left on the opposite side. I did not grab a picture of me testing like that, but I can if needed.
      • jthi
        • Jan 2012
        • 18
        Thank you for all the newbie patience. I've attached a picture with the pins labled. Here are my combo testing results. All combinations not listed read as open/OOR:
        Old Master T1:
        Pin 2-4: 8.49k Ohms
        Pin 2-5: 8.49k Ohms
        Pin 2-6: 8.47k Ohms
        Pin 2-7: 8.48k Ohms
        Pin 2-8: 23.3 Ohms
        Old Master T2:
        Pin 1-2: 0.3 Ohms
        Pin 1-4: 8.39k Ohms
        Pin 1-5: 8.39k Ohms
        Pin 1-6: 8.38k Ohms
        Pin 1-7: 8.47k Ohms
        Pin 1-8: 23.4 Ohms
        Pin 2-4: 8.45k Ohms
        Pin 2-5: 8.46k Ohms
        Pin 2-6: 8.46k Ohms
        Pin 2-7: 8.45k Ohms
        Pin 2-8: 25.8 Ohms
        Old Slave T1:
        Pin 2-4: 9.07k Ohms
        Pin 2-5: 9.08k Ohms
        Pin 2-6: 9.08k Ohms
        Pin 2-7: 9.07k Ohms
        Pin 2-8: 23.3 Ohms
        Old Slave T2:
        Pin 1-2: 0.3 Ohms
        Pin 1-4: 9.08k Ohms
        Pin 1-5: 9.05k Ohms
        Pin 1-6: 9.06k Ohms
        Pin 1-7: 9.07k Ohms
        Pin 1-8: 25.4 Ohms
        Pin 2-4: 9.07k Ohms
        Pin 2-5: 9.05k Ohms
        Pin 2-6: 9.05k Ohms
        Pin 2-7: 9.04k Ohms
        Pin 2-8: 23.2 Ohms
        I got the same combination of results for the new boards I ordered, except they were in the 7.1k range.
        • jthi
          • Jan 2012
          • 18
          Other Pin combos if needed:
          Old Master T1:
          Pin 4-5,6,7: 0.3 Ohms
          Pin 4-8: 8.39k Ohms
          Pin 5-6,7: 0.3 Ohms
          Pin 5-8: 8.40k Ohms
          Pin 6-7: 0.3 Ohms
          Pin 6-8: 8.37k Ohms
          Pin 7-8: 8.41k Ohms
          Old Master T2:
          Pin 4-8: 8.34k Ohms
          Pin 5-6,7: 0.3 Ohms
          Pin 5-8: 8.37k Ohms
          Pin 6-7: 0.3 Ohms
          Pin 6-8: 8.39k Ohms
          Pin 7-8: 8.35k Ohms
          • retiredcaps
            • Apr 2010
            • 9271
            All those readings are within 3% of each other. The 8K readings are what I expected.
            • jthi
              • Jan 2012
              • 18
              #26
              Thanks Retiredcaps. Does that mean that the inverters sound like they're probably good? I can try and do the rolled up paper test and listen for anything strange out of the transformers.
              I'm guessing these inverters are going into some type of lock down mode and cutting the power off intentionally. After reading that other linked post, my best thought is to try and inspect the ccfl bulbs. I didn't see any results from the previous thread poster on how that turned out for him, but hopefully it will be a clue into my next steps.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Yes, those readings indicate they are likely good. Plus, you already ordered a new master/slave.
                The pwm chip operates on an "all or nothing" premise. All the ccfls work or none at all.
                PlainBill explains constant current AC source with protection on post #113 at
                https://www.badcaps.net/forum/showth...?t=8589&page=6
                BTW, on the same page, if you read the other posts, you will see alexanna talk about the return wiring on the ccfls (for computer monitors, not TVs) breaking down. You could have the same situation on your TV?
                • jthi
                  • Jan 2012
                  • 18
                  #28
                  I manned up and finally took the tv all the way apart, and it looks like I've got 3 ccfls that are bad. I've attached pics. This brings me to my next set of amateur quetions:
                  1) Can I connect back up all the powers (less the tcon and LCD connection) and powe the tv up to see which bulbs will flash on during that initial 2 secs?
                  2) Does anyone know a good place to find replacement bulbs? From what I've googled, I can't easily find a part number, just sites with sizes listed. These are 4mm diameter, and I'm not sure on the length since these don't have to be soldered and I don't know where to stop the measurement. They look to be between 940-950mm.
                  Thank you guys for this forum! I'm feel like I'm learning a ton.
                    1.) Yes, but be careful not to touch either end of the bulbs as they are energised with high voltage (around 3kV, each.)
                    2.) ccflwarehouse.com gets tossed around a lot. Also ebay. Also a broken screen TV of the same size can be a good source of bulbs. I've got a collection of bulbs from a 32" Philips (about 20) should a faulty backlight TV come in.
                    • jthi
                      • Jan 2012
                      • 18
                      #30
                      Thank you Tom. I'll work on getting it half together and testing. I've been keeping my eyes open on craigslist, but so far, no luck with and broken 42" tvs.
                      • jthi
                        • Jan 2012
                        • 18
                        #31
                        Ding Ding. Four bad bulbs - wish it was less, but at least I know what to look for.
                        Tom - any tips on unseating these bulbs from their holders? The don't seem to want to pop out by hand easily.
                        • jthi
                          • Jan 2012
                          • 18
                          #32
                          Pic
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            For the ones that are bad, carefully check the soldering on the ccfl bulb ends and the caps that are attached to it.
                            Check for poor solder joints with power off and TV unplugged!
                            • PhilipsKSI
                              • Oct 2013
                              • 13
                              I had a similar issue and while searching on google ended up joining this forum. What was the conclusion for this issue?
                              Everything, including my Philips TVs, are subject to birth, disease, old age, and finally death.
                              • PhilipsKSI
                                • Oct 2013
                                • 13
                                If anyone wants a 42PFL7422D/37 Philips TV for cheap, drop me a line. I found this one too difficult to open what to speak of repairing. It's working fine under HDMI, A/V, component, and side A/V. But for coaxial you have to first start up in one of the other input modes and switch after it powers up.
                                It has a couple of burnt out backlights so picture is overall slightly dimmer than it should be.
                                • 120volts
                                  • Oct 2013
                                  • 57
                                  I just fixed two of the 42PFL7422D/37 with the same (No back-light) about six weeks ago.
                                  Both had shorted transistors on the slave inverter board.
                                  I first tried replacing the shorted transistors, the back-light then turned on but the transformers were getting very hot.
                                  I ended up replacing both master and slave boards in both TVs.
                                  $49 for the set of boards on eBay.
                                  They're both working well now.
                                  Dan "TV Tinkerer"
                                  • PhilipsKSI
                                    • Oct 2013
                                    • 13
                                    Too many screws to just open this unit and some of these screws are inaccessible with the tools I have since there's a metal plate that's obscuring some screws. So I haven't yet opened up the unit yet although I do have the T10 Torx screwdriver for most of the screws.
                                    • Zoli77
                                      • Dec 2017
                                      • Hungary
                                      #38
                                      Hi everybody,
                                      I read this blog and I have a problem with LCD TV a 42LG2000. This TV similar to the Philips 42PFL7422D/37. I can turn On the TV, after the backlight turn On approximately 5 secundum then the backlight turn Off. I checked the power supply, it is OK. I checked inverter voltage they are OK. On the inverter Backlight On voltege is OK until the TV On. I changed the elektrolit capacitor on the inverter but the problen remains.
                                      On the master inverter at trafo keramic capacitor (red circle) was carbonised. I changed it but the problen remains.
                                      I checked inverter transformators (T51.0166.211)
                                      Master inverter
                                      Primer side
                                      T1: 29,3 Ohms
                                      T2: 29,3 Ohms
                                      Secondary side
                                      T1: 0,3 Ohms
                                      T2: 0,3Ohms
                                      Slave inverter
                                      Primer side
                                      T1: 29,3 Ohms
                                      T2: 29,3 Ohms
                                      Secondary side
                                      T1: 0,3 Ohms
                                      T2: 0,3Ohms
                                      Master inverter: VIT71053.54
                                      Slave inverter: VIT71053.55
                                      I checked CCFL lamp in the LCD sreen, all CCFL lamp operating full white light
                                      Can I check anything
                                      • ovrax
                                        Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                        by ovrax
                                        First of all, please excuse me as I'm quite new to this field.
                                        I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                        I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                        The Ambilight works perfectly and stays on.
                                        No sounds.
                                        Thanks in advance.
                                        08-25-2024, 04:33 AM
                                      • Cornito
                                        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                        by Cornito
                                        Hello Team,
                                        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                        08-08-2024, 08:09 AM
                                      • cheebster
                                        iPad Pro 12.9 5th Gen Backlight Issue
                                        by cheebster
                                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                        Anyone...
                                        05-20-2025, 09:17 AM
                                      • DoOm86
                                        philips 55pft5500/12 Backlight issue. What am I doing wrong?
                                        by DoOm86
                                        TV philips 55'' no backlight (image ok).
                                        I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
                                        What am I missing?
                                        And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
                                        04-16-2024, 03:47 PM
                                      • Acnologia
                                        Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
                                        by Acnologia
                                        Hello to all members of badcaps.
                                        Another brainstorming that i have been messing with for months as a side project.
                                        Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
                                        I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
                                        Step 1.
                                        Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
                                        Machine > Doesn't give display it's really dim.
                                        Step 2.
                                        Use the same...
                                        11-05-2025, 04:02 AM
