VZ42L No Amber light, no stand by 5v
  • windfreik
    • Sep 2011
    • 18
    I am trying to troubleshoot a vizio that does not go to AMBER or WHITE no sounds/relays, etc. dead.
    I want to send the power board or the control board to a shop that will bench test it all and fix for a decent price. If you had to send a board, which board to send first?? I cannot get power to any of the 24v or 5v standby pins on the power board when plugged in. I pushed the reset button on the control board and nothing. Without posting pics and checking all the resistances/etc which board would you send? I realize that i might end up sending both but maybe i will get lucky with the first board I send...
    thanks for any opinion or insight
    Brett
    Re: VZ42L No Amber light, no stand by 5v
    Check the fuse... both on the power supply and in the plug.
    • PlainBill
      • Feb 2009
      • 7034
      If the fuse is good, disconnect the output connectors from the power supply and see what happens. You should ALWAYS get 5VSB if the supply is getting power.
      PlainBill
      • windfreik
        • Sep 2011
        • 18
        Ok, let's do this. I should have tried the fuse originally. It was bad. I replaced with new one and now I have SB 5.1v but no 24 volt, still no AMBER, Does not turn on. No sounds, no clicks. I disconnected the power board outputs and still same result. nothing except sb 5.1v. I will get some HD pics uploaded soon, but what can I try next to eliminate the control board?
        Thanks.
        Brett
        • retiredcaps
          • Apr 2010
          • 9271
          A lot of these Vizios have bad voltage regulators on the main board. U33 seems to be a popular one that goes bad. Either Vizio underspeced this component or got a bad batch.
          If that regulator and/or others are bad, the main board will not toggle PS_ON high and the power supply will never start.
          PS. HD pics means 2000 x 2000 maximum resolution here and more than sufficient. Note the instructions below and follow them exactly.
          --- begin sig file ---
          --- end sig file ---
          • windfreik
            • Sep 2011
            • 18
            Here are some pics of the power board. Let me know if i should re-take some, or different angles... Thanks for the help
            • retiredcaps
              • Apr 2010
              • 9271
              Those are excellent focused pics. Now we also need pics of the main/logic board. This is the board where your HDMI, component cables, etc plug into.
              PS. This is one of the few TV/models to use name brand japanese quality caps on the power board (Nichicon, United Chemi-con, and Rubycon). Having said that, I have seen the same United Chemi-con cap bloated KY bloat underneath the heatsink by the connector) at least twice in other threads.
              • windfreik
                • Sep 2011
                • 18
                Here is the main board, bottom and top. I see U33, remind me how to check with multimeter, I am a novice with it, but have tested continuity and volts, but how to check this U33?
                Thanks again for any assist\
                Brett
                • retiredcaps
                  • Apr 2010
                  • 9271
                  In the picture below,
                  1) the ground screw circled in black is where your black probe will go. For all voltage measurements, this will be your ground.
                  2) put your multimeter to 20V DC if it is manual range.
                  3) With power on, lcd plugged in, and boards connected, you are going to measure all the components circled in blue.
                  4) The fat tab will be "up" or "north". The left most pin will be pin 1 with respect to "up". Number the pins 1, 2, and 3 (ignore numbering the fat tab).
                  5) With your black probe on the ground screw (see #1), put your red probe on each voltage regulator starting with pin 1, then 2, and finally 3.
                  6) Record the pcb designation, part number, and pin voltages. For example, we want to see
                  U33
                  part number AS1117-33
                  pin 1 = 0
                  pin 2 = 3.3
                  pin 3 = 5.0
                  7) Power off and unplug lcd. Wait 3 minutes. Then put your multimeter to 200 ohms and measure the resistance of the 2 fuses circled in red. If they are good, both some measure less than 1.0 ohms.
                  • windfreik
                    • Sep 2011
                    • 18
                    tried all of the tabs you suggested and nothing all zero. Then I unplugged and tried the 2 fuses and only the far left one (vertical) registered (.9). The right one (horizontal) 0. What ya think?
                      "0" as in "OL" or "1" on left hand side? Same reading when your probes are not touching?
                      • windfreik
                        • Sep 2011
                        • 18
                        it shows a 1 on the left hand side.... Same as when probes are not touching on that horizontal fuse.
                          So, that fuse has failed. You can replace it and if it blows again you will need to locate the fault on the board (or replace the entire board). Those fuses tend to fail randomly, without apparent cause.
                          Are there any markings on the fuse?
                          • windfreik
                            • Sep 2011
                            • 18
                            Re: VX42L No Amber light, no stand by 5v
                            no visible markings. Is that a fuse I can easily find at radioshack? Or ebay
                            Also, check out the pins on the far left large voltage regulator.. one of the pins seems to be missing, or designed that way?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              What do you mean no visible markings? It says LF 3A. It is a littlefuse 3A fuse.
                              Designed that way.
                              • windfreik
                                • Sep 2011
                                • 18
                                Sorry, I thought you meant marks that would indicate scorch or damage...
                                I will try and replace and report back.
                                Thanks again!!
                                • windfreik
                                  • Sep 2011
                                  • 18
                                  will this type of fuse work? http://www.ebay.com/itm/LITTLEFUSE-L...9#ht_500wt_969 or any suggestions off ebay?
                                  thanks
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Get the fuse from digikey.com. Shipping will be around $2.75 USD and you will get it in roughly 2 days with USPS 1st class mail.
                                    Measure your fuse and then search for
                                    littlefuse 3a
                                    on digikey's website. Then pick the right size.
                                    edit: PS. You might want to think about ordering a replacement for U33 at the same time since it has been problematic for others. It should be less than $1 for that part. Until that fuse is replaced, you will get 0.0V DC voltages on all the regulators.
                                    • windfreik
                                      • Sep 2011
                                      • 18
                                      parts ordered, will report back!! thanks team!
                                      • Bigredram87
                                        • Sep 2013
                                        • 88
                                        U33
                                        pin 1 = 0
                                        pin 2 = 3.3
                                        pin 3 = 5.0
                                        Hi this is my first thread and I figured I should just tag onto someone with similar problems. I have same tv no backlight but my Visio led does goes from amber to white . I have no voltage from 12v or 24v pins on the power supply board. I have done measurements on the above components.
                                        Fuses good
                                        U33
                                        1:2.03v
                                        2:3.28v
                                        3:5.10v
                                        U7
                                        1:0v
                                        2:1.27v
                                        3:3.28v
                                        U9
                                        1:0v
                                        2:1.51v
                                        3:3.28v
                                        U8
                                        1:2.07v
                                        2:3.32v
                                        3:5.14v
                                        U10
                                        1:0
                                        2:0
                                        3:0
                                        U3
                                        1:1.35v
                                        2:2.60v
                                        3:5.09v
                                        U2
                                        1:2.07v
                                        2:3.32v
                                        3:5.11v
                                        I appreciate any input on what to do next thank you guys so much. I am an apprentice electronics technician and would love any help
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
