my sharp wont power on but red light on wont turn green when powered on
  • JuliusO
    • Jan 2012
    Sharp Aquis LC 30Hv4U problems turning the light on from red to green, is it the power supply.will like to see if any one can help me and telling me if its the power supply board or capasitor or whats need replacement will apriciate any help thank you
  • lcdman
    TinkerTech
    • Nov 2010
    • 232
    • U.S.A.
    Re: my sharp wont power on but red light on wont turn green when powered on
    Hello And Welcome To The Site,
    Without pictures of the circuit boards its kind of hard to say for sure. But would guess its probably capacitor related. Disassemble the unit and take decent pictures. Use the 'Manage Attachments" to post your pictures. And then perhaps someone could try to assist you further.
    Good Luck For Now,
    lcdman
    • selldoor
      Slow Learner
      • 7870
      Hi - Welcome- I do not know much in the way of advising you re the tv but I can help you get help. For a start you have started your thread in the wrong forum, you should be in troubleshooting tv's and video sources.
      You need to do as lcdman suggests but in addition you need to post some information about yourself - electronic knowledge/soldering skills etc. How you came by the set -it makes a difference if you found it in a field or owned it for 2 years. Also what tools you have soldering iron /multimeter etc .Can you update your profile with at least the country you are in so that when it comes to buying parts you can be best advised. Read some of the other longer threads and see what other have done. You need to be accurate in what you tell us e.g. "problems turning the light on from red to green" what does that mean. We need a full story as we cannot see what is happening. When you switch on does it come on red, come on green then turn to red. come on red then turn to green does it flash at all, does the screen flash at all, is there any sound, hum hiss crackle etc - have you tried with any input dvd pc.
      Tell us what you have tried so far. Can you find a schematic for the Tv and or the power supply.
      Have you tried the standard factory reset for Aquis (sic) range of tvs
      Factory Default Reset:
      - Unplug the TV and count to 10 slowly.
      - Hold down the power button on the TV (not the remote.)
      - Plug in the TV while holding power button.
      - Count to 10 and release the power button.
      - Turn it on
      When you have done all these things I suggest you start a new thread in the correct forum and this one will go dormant
      • phmark
        • Jun 2017
        • 3
        • philippines
        I already followed your instruction but still lights blinking green and red. Please help me. Thanks
        • phmark
          • Jun 2017
          • 3
          • philippines
          Selldoor, please help me. Lights till blinking green and red.
          • phmark
            • Jun 2017
            • 3
            • philippines
            Please help me. Still blinking green and red.
            • vdrokko99
              MBP wont turn on Only green light on charger
              by vdrokko99
              I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
              SMBUS_SMC_BSA_SCL 3.5V
              SMBUS_SMC_BSA_SDA 3.5V
              12-01-2024, 12:18 PM
            • jxrepman
              Asus X453MA won't turn on and green led light blinking
              by jxrepman
              Hi there,
              I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
              I have checked the charger and it is giving 19+ V
              I have disconnected the battery and pressed power button for 30 seconds.
              I tried another RAM stick.
              Tried disconnecting the keyboard and touchpad.
              Tried disconnecting the HDD and the wifi adapter.
              The problem persists.
              Hope you could help me out on this one. Thank you.
              12-14-2024, 06:40 AM
            • MOSSEP
              Monitor Audio RSW12 - Green light, but no sound
              by MOSSEP
              Hi
              Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
              Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
              The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
              I have already tried replacing all of the...
              01-26-2025, 08:33 AM
            • MOSSEP
              Monitor Audio RSW12 - Green light but no audio
              by MOSSEP
              Hi
              01-26-2025, 08:18 AM
            • lcdcaps1
              820-2610-A Sys onewire help, no green light. Please help from the gurus
              by lcdcaps1
              Hi
              I have an 820-2610-A motherboard that has no green light.
              I have noticed is when I do a SMC reset the light on the Magsafe blinks.
              From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
              The sys onewire circuit on this model and others is more involved
              I was hoping if anyone knows about this and how it works, can reply and let me know
              I know this is an old model but I am sure there are people who still works on these or knows about them
              I get 1.1v on the C7771 capacitor and will replace...
              11-06-2023, 01:28 PM
