LG 42PX5D-EB dead
  • pauldow
    • Oct 2012
    • 92
    • US
    Re: LG 42PX5D-EB dead
    Thanks TW,
    Yes. Those parts labeled FLx are on the YSUS and ZSUS boards, under the heat sink and under the IPM.
    Fusible Link sound appropriate; they do read 0 ohms (or very close) across them.
    I made the mistake of ordering the replacement IPMs before checking for replies back here. D'oh! I paid 17USD for the ZSUS IPM. I didn't realize substitute ZSUS boards were available. I also now see that the original part number is only about 30 USD on eBay too.
    There's that path with found broken TVs that starts with the exploration phase, moves on to the investigation phase. Then the trying different solutions phase, and finally branch of solution phase, or the "get this mess out of the house" phase. I think I'm getting close to that last one.
    • bbjunkie
      • Dec 2011
      • 301
      Hi guys, never did post a follow up to this.. mainly because the set isn't fixed yet! Got a secondhand y-sus board from an online supplier of plasma and LCD spares. Just about to power it up on my next visit to the workshop (it was buried under a ton of other stuff hence taking so long!). Is there any way to protect my new board in case one or both of the buffers is shot ?
      Cheers
      Jim
        Test the buffers beforehand. In general these boards are usually OK with bad buffers. (they can sometimes kill buffers though that is rare.)
        • bbjunkie
          • Dec 2011
          • 301
          Thanks tom66, all ok it seems. However am having trouble remembering where one of the cables goes. There are two cables that look like they are shielded data cables, one goes from the logic board to the very left hand side (marked in green) The other one marked in red, I cant find where it plugs in, one end goes on the logic board, the other - I cant remember! I stripped this set down in early 2012 so cant recall was it even plugged into anything.
          The photo attached is the original I took in Jan. 2012 with arrows pointing to where the cables are. It appears like the cable goes under the logic board, however I can't find a socket for it anywhere!
          Anyone got one of these models or an idea where this second cable goes to?
          Tried it without the cable plugged in and am not getting a picture, so am not sure if its because of the cable or something else. (the screen is black but illuminated as if there is just no video signal to it)
          Jim
          • bbjunkie
            • Dec 2011
            • 301
            Hi again!
            Finally got more time to look at this, turns out the cable plugs in underneath the lower PCB on another board.
            I have just sourced a buffer board and replaced it due to the original getting a bit hot. Now I have nothing but sparklies.
            Is this a board problem or do I need to adjust the tv to suit the new buffer board? (pic was perfect on old board, just a couple of the chips were getting hotter than the others)
            Cheers for now
            /bbj
            • bbjunkie
              • Dec 2011
              • 301
              #26
              Spent another evening at the LG last night, removed the board and re-seated the ribbons. Didn't make any difference.
              Will try swapping the buffer board back to the old one.
              /jim
              • bbjunkie
                • Dec 2011
                • 301
                #27
                Swapped back to old buffer board and picture returned. Assume this was a faulty item(thankfully the ebayer refunded me)
                Will try to find another.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  #28
                  One of the MOSFETS on the buffer-board is short-circuit I expect....
                  Tom66--Whats up with your PC1DA?
                  TELEFIX
                    ...er, I haven't had a PC1DA for over 2 years now. I stay well clear of them for a laundry list of reasons.
                    • Dannyx
                      Line filter question
                      by Dannyx
                      Good day folks. A while back, I started building a bench power supply (long story - see it here ). I noticed something about the pre-built line filter I wanted to use and it got me thinking whether it's a good idea to use it or not, at least in my particular case.
                      If you zoom in and look at the schematic on the label, the potential problem I see is the earth terminal connected to L and N via the 2 Y caps. I've seen this setup in virtually all of these and even some SMPS board may have this arrangement (though I'm not sure about this), so it's probably safe overall and makes perfect...
                      05-08-2022, 04:31 AM
                    • Gootch46
                      Vizio E60-c3 blue vertical line (dead center)
                      by Gootch46
                      My Father called me he has a Vizio E60-c3 that's probably 3-4-5 years old but it has a thin blue line running down the center of the screen (photo) I tried a couple things but I'm sure one of you all have seen this already. Been a while since I've been here hope all is well. Thank you in advance....
                      05-26-2023, 05:42 PM
                    • cubytus
                      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                      by cubytus
                      Hi to all,
                      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                      01-10-2024, 01:26 AM
                    • otaku_nut
                      Vizio E701i-A3 fixed but now has red vertical line
                      by otaku_nut
                      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                      08-19-2025, 06:11 PM
                    • TrueSword88
                      Kogan - KALED65XU9220STB - Blue Vertical Line
                      by TrueSword88
                      Hi all.
                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                      Hoping to fix...
                      05-05-2023, 04:28 PM
