Toshibia 40rv525u Green Blinking light and questions about Caps!!
  • ComputerGeek
    • Oct 2011
    • 262
    Re: Toshibia 40rv525u Green Blinking light and questions about Caps!!
    OK I it is Pulsing at the same speed as the Lcd, Highest Pulse was 2.73v but it is just on for a brief second. Thanks!
      Can you also check the ACD pin?
      Can you get hold of a 2.2k resistor? (1/4W, Carbon Film, 5% - should be available at Radio Shack.)
      The clues point to a main board problem right now, as the Pwr voltage should be stable to turn the supply on.
      • ComputerGeek
        • Oct 2011
        • 262
        Acd is about 2v and the pulse is Synced with the Pwr pin using both multimeters.
        Does it have to be a 1/4w? Or that exact Value? I have a "ton" literally of old boards that I might be able to find this on.
        Also, just two other questions,
        Does the polarity Matter on film caps? And what does happen if you don't put a low esr cap in?
        • ComputerGeek
          • Oct 2011
          • 262
          I addition to the post above, Is there a way to test just the power board? Like Jump It? Or would that be a bad idea if there is a short or something turning it off?
          • retiredcaps
            • Apr 2010
            • 9271
            #65
            Originally posted by ComputerGeek
            Like Jump It?
            I never had too, but you could hookup fresh 2 AA batteries in series to get 3V DC and connect that to the PWR pin? If the voltages come up stable (5V, 12V, 24V, etc) on the power board then you know the problem lies somewhere on the main/logic board.
            Something like this
            http://www.ebay.ca/itm/320562976160
            or you can just make it at home with electrical tape and wire?
            3V DC or higher is usually the threshold for PSON or similar type pin (PWR) from the main to the power board.
            PS. I don't know the ramifications of doing this, so caveat emptor. Some power supplies may not operate properly without a load?
            PPS. I have jumped a few ATX power supplies (short green to black), but they were given to me for free and I was trying to repair and troubleshoot them. So if anything went wrong, there was no real loss (I always wore safety glasses, you never know with free stuff).
            --- begin sig file ---
            --- end sig file ---
            • retiredcaps
              • Apr 2010
              • 9271
              #66
              Actually, I could be wrong about the above statement. The power board alone without load could display the proper voltages, but fail under load (i.e. when main board is connected).
              I have one lcd monitor where the power board has stable and correct voltages, but would drop everytime the logic board was connected. I haven't solved it yet. A slip of the probe shorted out some diodes on the power board and I haven't replaced them yet.
                Okay, that might be okay. The pulse might just be interference from the rest of the supply.
                No, any value would probably do, just ideally with long leads so you can plug it into the right pins.
                Not as far as I'm aware. Electrolytics, tantalums, niobium and a few other types of capacitors are polarised, but others are nonpolar.
                The supply works intermittently or not at all. Or it works for a month or two, then dies. Or, the caps go really bad and kill something on the main board. (Samsung LCD TVs are notorious for corrupting the EEPROM when capacitors go bad inside them. The EEPROM stores settings so the TV gets very confused and it needs resetting.)
                • ComputerGeek
                  • Oct 2011
                  • 262
                  Ok It's been a day or two since I worked on this anyway, I removed both boards and had a stable 5v line, No pulsing.
                  Should I do the jump will that even prove anything? If I do where do I connect the negative terminal of the battery?
                  What should I do from here?
                  Also, I am going to look for that resistor. Thanks!
                  • ComputerGeek
                    • Oct 2011
                    • 262
                    ^^^In addition to this post, I found a 2700k is this OK? I can look again, I literally have tons of boards to pull stuff from.
                    I think it is a quarter watt how do you tell that? Just the Size?
                    Whats the plan? I can solder a pair of jumpers on to get to the pins.
                    Thanks!
                      Thanks!
                      You ideally need close to 2.2k - 4.7k. 2700k is 2.7 meg ohms so 1000x out of spec.
                      • ComputerGeek
                        • Oct 2011
                        • 262
                        LoL or I'm just really out of spec on typing I meant 2.7k how do you tell if its a 1/4w?
                        Its red violet red that is 2.7k right?
                          Any old resistor would do... most likely one with leads will be at least 1/8w which is more than enough...
                          • ComputerGeek
                            • Oct 2011
                            • 262
                            Now I'm second guessing my self, red violet red that is 2.7k right?
                            • ComputerGeek
                              • Oct 2011
                              • 262
                              What do I do now? I soldered a couple jumpers on it.
                              • ComputerGeek
                                • Oct 2011
                                • 262
                                Where should I connect the resistor? Should I try to jump the power board? If so where do I connect the Negative terminal of the 9v Battery? To Ground?
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Tom66 is rather busy with exams at this time. I would connect one end of the resistor to the standby output of the power supply (5VSB?) and the other to the PS_ON input. Then when you apply AC power, the entire power supply should start.
                                  PlainBill
                                  • ComputerGeek
                                    • Oct 2011
                                    • 262
                                    OK, no problem. OK I think those two pins are +5v and PWR, is that correct? DO you know what the ACD is for? Also what Boards should I leave connected if any?
                                    Thanks!
                                    Good luck with the exams tom66!!
                                      Thanks!
                                      ACD tells the TV the power cable is still plugged in. (AC Detect.) If the power cable is unplugged (or the supply drops out), the TV gets about 50 milliseconds to save all settings to memory and perform a controlled shut down.
                                      I expect connecting it between 5V and PWR will be sufficient. You could even solder it in place, to make it easier to test it, and remove it later.
                                      For the initial test, disconnect all boards as it's only the output voltages we are concerned about. Then the other boards can be connected and further tests can be performed.
                                      • ComputerGeek
                                        • Oct 2011
                                        • 262
                                        OK, Hooked it up, and nothing all voltages were the same as before nothing except the +5v line well I didn't actually measure all of them but the main lines for the inv and main boards had nothing.
                                        I actually have a little trick so you don't have to solder doesn't work if you have the connector on though, but if you solder the ends to some insulated wire (I used old Christmas Light Wire) and cut the other ends off clean you usually can just slip the sleeved wire over the pins the insulation of the wire will hold the copper on the pin and then you can test away!
                                        Thanks!
                                        Also, What else can I test at this point? I am still have a feeling that it might be the Caps, could you circle which ones you think I should try replacing, and then I'll get Numbers for those so you can recommend replacements.
                                          What voltage did the PWR line measure when you were using a resistor to pull it up?
                                          Bad capacitors could cause this but the power supply uses very high quality capacitors, which rarely (but not never) fail.
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first β€˜decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
