Toshibia 40rv525u Green Blinking light and questions about Caps!!
    Re: Toshibia 40rv525u Green Blinking light and questions about Caps!!
    Use this mode and retest the diodes.
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      Originally posted by ComputerGeek
      Ok I am not sure how to measure ohms properly, I thought I recall younot being able to hold in onthere for too long
      With power off and device unplugged, you can measure resistance for as long as you want. You never measure resistance with power on. See this thread for why.
      https://www.badcaps.net/forum/showthread.php?p=207859
      If you are measuring amps, some multimeters caution that you can't measure for more than xyz seconds (typically 15 seconds). Some really cheap multimeters don't have fuses on the amps jack. Remember, we typically never require an amps measurement in 99.99% cases.
      The biggest problem newbies have with multimeters is the interpretation of the results. They get confused with "1", "0L", and report "no reading". This is especially apparent when asking them to check for a shorted component.
      tom66 is quick learner wrt to dealing with newbies. He now writes his multimeter responses in similar fashion to mine. I know he participates in other forums where people have more experience and he would never write responses in that fashion.
      --- begin sig file ---
      --- end sig file ---
      • ComputerGeek
        • Oct 2011
        • 262
        I notice though that when I hold the probes on a resistor or something similar the resistance starts going down, I believe because the component gets Saturated with the test voltage, Am I incorrect in thinking this?
        When do I take the reading when the Number stops moving, when I first put it on?
        Thanks!
        So is this what you want me to test?
        So do 12 tests on each one is that correct? Do the 6 I did but then switch leads like
        D203 Top in Picture,
        R1-2B,
        R1-3B,
        R2-1B,
        R2-3B,
        R3-1B,
        R3-2B,
        B1-2R,
        B1-3R,
        B2-1R,
        B2-3R,
        B3-1R,
        B3-2R,
        B=Black Probe, R= Red Probe
        Is That Right?
        • ComputerGeek
          • Oct 2011
          • 262
          Also, when I do keep it on there it goes out of the 2k ohm range what should I do?
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            In circuit readings are not accurate due to other surrounding components. If you take a resistor and measure it out of circuit, a good multimeter will find display a correct and stable reading in about 1 second or less.
            • ComputerGeek
              • Oct 2011
              • 262
              Yeah I usually test out of the circuit, I don't know were I got that info from Probably my uncle. Anyway, I just tried it again and it worked fine.
              ^^^Is the post above correct or my thoughts on testing?
              • retiredcaps
                • Apr 2010
                • 9271
                #47
                For a diode that looks like this -><-, think of two separate diodes in physical package.
                Pin 1 is left, pin 2 is the middle, pin 3 is right. Set your multimeter on diode test. Measure
                Black on pin 1, red on pin 2. Record reading.
                Red on pin 1, black on pin 2. Record reading.
                Black on pin 2, red on pin 3. Record reading.
                Red on pin 2, black on pin 3. Record reading.
                Thus, you will have 4 readings for these types of diodes which makes sense if you think of them as two separate "normal" diodes.
                • ComputerGeek
                  • Oct 2011
                  • 262
                  OK, Here goes,
                  D203
                  b1-r2 1422
                  r1-b2 177
                  b2-r3 177
                  r2-b3 1422
                  D202
                  b1-r2 quick beep then starts at 1000 then climbs out of range
                  r1-b2 230
                  b2-r3 230
                  r2-b3 quick beep then starts at 1000 then climbs out of range
                  D201
                  r1-b2 quick beep then stays at 230
                  b2-r3 quick beep then stays at 230
                  • ComputerGeek
                    • Oct 2011
                    • 262
                    This is the order I did them in.
                    Thanks!
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #50
                      D201, D202, and D203 all test okay according to your measurements.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        In re-reading post @29, tom66 wants pins 1-3 and vice versa 3-1 tested as well.
                        So add the following readings for all 3 diodes.
                        black on pin 1, red on 3
                        red on pin 1, black on 3.
                        • ComputerGeek
                          • Oct 2011
                          • 262
                          Ok here you are,
                          D203
                          b1-r3 Connected Beeps
                          r1-b3 Connected Beeps
                          D202
                          D201
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #53
                            D203
                            What does connected beeps mean? What is the actual reading on the display?
                            • ComputerGeek
                              • Oct 2011
                              • 262
                              Sorry wasn't clear The meter just makes a constant beep like when you touch the probes together. The reading is 001 Thanks!
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #55
                                The reason I'm so picky is that diode/continuity varies greatly on multimeters. Some cheap multimeters will beep "continuous" if the resistance is less than 1800 ohms. Most, however, will beep "continuous" for less than 50 ohms.
                                So reporting a beep leaves us guessing as to what the real measurement is.
                                Same goes for the voltage used on diode testing. Some show "0L" or "1" when voltage goes over 2 V. Others use 3 V for the threshold.
                                • ComputerGeek
                                  • Oct 2011
                                  • 262
                                  Ok No Problem I understand, I have Been using the Craftsman Meter BTW
                                  Now what?
                                  Thanks!
                                  • ComputerGeek
                                    • Oct 2011
                                    • 262
                                    What Should I do now?
                                      The readings you show are most likely good for the PSU.
                                      Post a close up of the connector going from the main board to PSU, on both ends. If there is a label next to the connector, make it easy to see in the picture. We have not established if PSON is good.
                                      • ComputerGeek
                                        • Oct 2011
                                        • 262
                                        Sorry for the delay in Responding, Here are the Pictures the only label is on the power board and the pin out is,
                                        1,2 Gnd
                                        3,4 24v+
                                        5,6,7 Gnd
                                        8,9 12v+
                                        10,11,12 5v+
                                        13 Pwr
                                        14 ACD
                                        15 D1m
                                        16 Inv
                                          Check the Pwr pin.
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first β€˜decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
