Have a Phillips 47PFL5704D,,,,the top 1 inch or so displays a perfect picture,,,the rest is different shades of grey,,some vertical lines,,,some horizontal lines.....Suspect a bonding issue with the screen,,,did the pressure testing around edges of screen with no distortion...just wondering if any one has seen this problem before I dissassemble this unit,,usually bonding issues that I have seen run the full vertical of the screen and like I said the top 1 inch or so is perfect thankx gbaum
Phillips 47PFL5704D screen 3/4 white
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Re: Phillips 47PFL5704D screen 3/4 white
Might want to try a replacement T-con first as they are relatively cheap.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
thankx tom,,,,have it apart no noticable bad caps,,,not much in this thing to work on,,,,exposed t-conn board,,,applied pressure ,,,no change,,removed left ribbon cable,,right side of screen now comes alive about half way versis a one inch strip on top guess I'll invest in a t-conn board ...I'll let you know....... gbaumComment
did you remove 1 of the ribbon cables and get the same result that he does? don't you love it when someone starts a thread but then never says whether or not they got it fix or what fixed it? if i was you i would take a shot at replacing the t-con as they aren't that expensive. make sure you replace it with the exact numbers on the board and not just by the tv model cause they may vary.Comment
by harpTo ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by EazyBoneAnother TV topic!!
I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?... -
by hcinneHello,
I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM - Loading...
