LG 42LC46 problem
  • sienoki
    replied
    Re: LG 42LC46 problem
    If you unplug the LVDS cable, or wiggle it slightly (try on both ends), does the fault appear immediately?
    Hi tom..i did another hair dryer test as i feel its heat related now..after picture goes off i warmed up main board and in 1 area BINGO the picture re-appears..
    Is this a failing element or solder issues..im borrowing a descent camera later so i can zoom close in and send pictures..thx
    replied
  • sienoki
    replied
    The fault has not been fixed..after 10mins when the picture goes the back of the set is not warm..it only starts to get warm at about 40mins..then if i turn off and on with remote the picture great for as long as the set is on..
    What other tests can be done?
    Im thinking solder joints but ive got a jewelers eye and had a really good look..cant see anything obvious..when i borrow a descent camera i will post some close ups of all the boards underneath..thx
  • bbjunkie
    replied
    Aren't intermittent faults so much fun?
    It's doubtful the fault has been fixed. I hope it has though. However in the last week I have had 2 tv's and a car heater fan all with intermittent problems that have magically started working again.. go figure!
    Jim
  • sienoki
    replied
    Since i replaced the bulged caps the set has never been on for longer than 40mins..ive now left if for 1hr with the picture like in quote 14..had 10 cups of coffee cos im dont like getting beat..especially with 90quid in it..anyways after 1hr i turned the set off by the remote(standby)and then turned it straight back on with remote and have been watching a crappy army film with patrick swayze for over 1hr..ehh
    So my question is did something on the boards?just need a good charging or something???
  • sienoki
    replied
    Originally posted by sienoki View Post
    I dont have an oscilloscope(have you seen state of my multimeter)i dont know of any1 i could borrow off.That bloke at farnells said he was a moderator on this site but i didnt get his num or name
    anways i will do 1st test again
    Done 1st test again with replacement t-con just same results so i tried the original t-con board..left ribbon in place i could see some of the picture but the background was white not greyed out like the replacement?right ribbon in place it was trying for a picture but not white background..weird
    I wont beable to get my hands on any advanced testing equipment so it looks like im stuck with a dead set
  • sienoki
    replied
    The fault in the pics doesn't look like a screen fault, as the noise is random like digital noise - screen faults cause bands of failure (e.g. horizontal/vertical lines, missing parts of picture, slow updating on one half, etc...)
    Can you repeat the first test after the set cools down?
    Do you have an oscilloscope, or can you borrow one?
    replied
    I asked the lad at work today what the faults where..he said he was having screen problems going shaded then flickering..after that then the start up issues(bad caps)he never told me about the screen issue when i bought it.
    Do you reckon the screen itself is on its way out.
  • sienoki
    replied
    Just done your second test had to wait to get a good picture to start with..anyways had good picture for about 8mins pulled LVDS cable waited 30secs then plugged back in but no picture m8..sound remains
  • sienoki
    replied
    Do you want me to do your 1st test again when the set is cold..cos i only get a good picture for 10mins from cold and when picture goes bad i would have to wait till set cooled down again to get good picture back
    I did your 1st test as soon as picture went so that is probably why half of screen had no picture..there was sound during failure
  • sienoki
    replied
    Strange, never seen that behaviour before, okay that means my test there won't work. (Some t-cons work with half the display, due to marginal components...)
    Next test is to leave the set on with ribbons connected until problem occurs, then unplug the LVDS cable, leave T-con for 30 seconds, and plug the LVDS back in, seeing if you get a picture.
    Also, do you get sound during failure?
    replied
    with left ribbon off left is white and right no picture just flickering dark grey screen vice versa
  • sienoki
    replied
    Okay so the regulator is fine.
    Next step:
    - turn TV off at wall
    - disconnect left ribbon connector (for left side of screen)
    - turn back on you should have picture on right but not on left (left hand might be random noise, or just white or black.)
    - wait 10 mins does problem occur?
    - turn back off, plug left in and repeat with right.
    replied
    no change in them readings after picture gone
    Next step:
  • sienoki
    replied
    them readings where when picture good..them readings didnt change when picture gone
  • sienoki
    replied
    the middle leg is1.49
    the left 1 is 0.00
    the right 1 is 3.25
    replied
    the left 1 is 0.00
    the right 1 is 3.25
    That's fine. Was that during failure or normal operation?
  • sienoki
    replied
    the regulator markings are rt9164a..15pg9fr0z
    the left 1 is 0.00
    the right 1 is 3.25
    replied
    Datasheet: http://pdf1.alldatasheet.com/datashe...K/RT9164A.html
    "15" indicates 1.5V output, so we should see 1.5V on one pin.
  • sienoki
    replied
    heres another
