Re: LG 42LC46 problem
I see at least one regulator on the board.
Get out your multimeter. Set it to 20VDC. Place the black probe on the metal chassis; for example, a part of the metal frame like a spare screw hole. Then, turn the TV on (and make sure the picture is good.) Measure the voltage on each pin (using the red probe) - for the middle pin, measure the tab as they are connected to each other and it's easier to measure, and report the readings. Then, wait for the picture to go bad, and measure again.
Use a loupe to read the part number and report that back.
LG 42LC46 problem
Even a crap picture might be enough to identify regulators on the T-con...
Here are what regulators look like. The three leg + large tab black devices are LDOs. In this set they are adjustable regulators, all of which are set to 2.5V.
The bottom one on this T-con failed, causing various colour lines on the screen + no visible image.Last edited by tom66; 01-07-2012, 04:45 PM.Leave a comment:
I have a Samsung that has a strange picture occasionally, caused by a dodgy LDO (voltage regulator.)Leave a comment:
The replacement t-con arrived today..installed it but still no joy
I wont pretend i know what im doing cos i dont..i feel im learning quite abit from other threads and definateley apreciate your help so far.
Now its time to start with my multimeter..on my psu there are 3 pin outs together..2 with the block wires going to the main board and 1 not in use..is that the test pin out..if it is i took readings when the unit is powered on(scary)as i dont to blow myself up..anyways readings are as followed
3.4v=3.47
GND=0.00
6.5=6.33
GND=0.00
12v=12.25
GND=0.00Leave a comment:
3.4v=3.47
GND=0.00
6.5=6.33
GND=0.00
12v=12.25
3.4v=3.47
GND=0.00
6.5=6.33
GND=0.00
12v=12.25
Okay, those caps are fine.
Set the multimeter to the 20V range and measure all the outputs on the power supply.Leave a comment:
ZL series of rubycon-ultra low impedance 5x10v-2200uf
the others are rubycon aswell apart from 2 panasonics 10v-470uf and 25v-47ufLeave a comment:
What capacitors did you use to replace the originals?
It could be a T-con fault. I've got a Samsung on my hands at the moment that has lines on the screen with no image visible, but sometimes after it warms up the picture comes back. I suspect the T-con is bad. It's possible, although unlikely, that bad caps could damage the T-con.
Can you list the ranges/settings your meter has - does it have a 20V or 40V range?Leave a comment:
I checked the solder joints and they are all good..i tried the hairdryer on t-con and main board with no results..ive changed 9 caps on psu from 35v downwards..would you also reccomend replacing the smaller caps on psu that are above 35v they also them crap named 1s..can t-con boards work for 10mins and just fail..thx
I bought a cap..diode tester from farnells on clearance shelf but dosent even work..i have a standard multimeter..thx
sos for crappy pics..Leave a comment:
I bought a cap..diode tester from farnells on clearance shelf but dosent even work..i have a standard multimeter..thxLeave a comment:
Get out the hairdryer, heat up individual areas around the capacitors, T-con and main board, if the fault shows then turn it off and test again, if it shows again then you have found the suspect area. Good for finding cold joints and bad capacitors (which don't always bulge.)Leave a comment:
Hi tom thx for answering back..am fairly sure solder joints are good i will check them again..yes i get a good picture for 10mins at a time..the LVDS is seated firmly in..Im totally new to electronics but have repaired 3 lcds been lucky they where only bad caps..think im gonna order a t-con board..theres only 1 on ebay thats from a smashed screen and he dosnt state thats it been tested so might take a chance on it..How would i use the hairdryer to localise the fault..thxLeave a comment:
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by THXFXHi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
I check capacitors and diodes and didn't find any short IN MAINBOARD.
Measured all power supply... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... - Loading...
