LG 42LC46 problem
+ More Options
Latest Activity
    replied
    Re: LG 42LC46 problem
    Originally posted by sienoki
    I,ve borrowed a Fluke 77 series II multimeter will this be better in testing than mine..thx
    It would be better if you could borrow an oscilloscope... even a basic 20 MHz analogue one will be able to do a go/no-go on the LVDS waveforms. (I've used one before to check if they were present and they appear as a sine wave.)
  • sienoki
    replied
    I tried reflowing on both boards too no avail againthe original board had the best results as it only flickered for a few mins the replacement board board no change..
    With the back off & the tv on for a while i put my hand near the heat sinks on power supply to feel how warm they where and got a shockafter your advice and reading graham01 expereince dont think reflow is working although the original board had good results
    Any chance of you looking at the main board maybe a reball if i posted to you..ive fixed numerous xboxes & ps3s with reflows but never a reball..i wish i could afford the equipment..maybe when kids have grown up..ha
  • sienoki
    replied
    Originally posted by tom66
    Well, I'm not sure any more.
    There are really no other boards that could cause this problem. You can reflow the board safely as long as temperature is kept around 230°C with a ramp rate of at most 4°C/second. This may or may not work. I'm not holding out hope.
    You could also have a bad panel, but I've never seen that pattern appear with a bad panel.
    Maybe the power supply is bad but it's showing itself in an obscure fashion. Check for cold solder joints.
    I wish I could be more help.
    I'm guessing you don't have a scope?
    replied
  • sienoki
    replied
    Oh dear, another reflow problem. Graham01 had a plasma with this problem and he reflowed the board about 10 times in all, every time it would fix it but it then died after 30 mins or so, unfortunately oven reflows don't always work and eventually the board died completely...
    Try applying pressure to the large processors and see which one restores the picture.
    I bought another main board not from ebay but from EMO,s tv..he said the board had been fully tested so thought id give it a go..
    Same results 10mins good picture then 10mins flickering then good picture all day..the only part ive not changed as yet is LDVS connector..
    Can i be 100% sure its heat related with cold solder joints with it being non lead..i want to try and bake the main board in oven but with both sides of the board being covered with smd,s am a little worried about parts dropping off from underneath..
    Since ive now 2 main boards & 2 t-cons boards im pushing myself to put them in the oven and would really appreciate on the correct way of doing this..thx
    replied
    Has any1 tried an oven bake with a main board?..if so what would be the correct way of doing this...thx
  • sienoki
    replied
    i had nowt to lose so i thought id do a full reflow of main board both sides..after 15mins the screen flickered for about 5mins then picture has been great for over 1hr so farit didnt lose picture like before after 10mins..
    To get rid of that flicker all together does any1 know at what temperature the board would be needed to do a reflow..as i just used my heatgun for approx 2mins either side..doing 1 side then let cool down for 10mins before doing the other..thx
  • sienoki
    replied
    Thx tom for help and patience in my matter...its just a shame as ive found the promatic area with ur help and been stuck there for further testing..
    This site is awsome for helping diagnose etc and without help from urself and others there would be more tv sets a local dump..once again thx for all ur help fella..
  • sienoki
    replied
    Try offering the seller a lower price, many would rather sell a board for half price than none at all.
    I would sell the TV as is, then look at the council dump for another one (a great source of my TVs, and they're often only bad caps at fault.) I got the LG 42LC46 in my living room from there, for just £20.
    replied
    Theres a board on ebay 56quid all in..i dont want to spend that much more on it..that will be 145quid for a 42" lcd not bad i suppose but without schematics my testings ends here as havnt got a clue what to do now..thx
  • sienoki
    replied
    Hi tom..ive searched in vain for a service manual but to no avail..i heard somewhere about a german site who might have 1..but stuck on that 1..
    These are markings on board
    CHASSIS:LD/PD73/75A
    EAX35231403(0)..thx
  • sienoki
    replied
    I don't think the capacitor is faulty. Rather, what is feeding it is faulty.
    I can't find the service manual, unfortunately. Are there any part #s on the motherboard?
    CHASSIS:LD/PD73/75A
    EAX35231403(0)..thx
    replied
  • sienoki
    replied
    I have to go to work now..bus driver crap hrs..ive 6days off next week so i will report bk with that part no and other voltage readings..thx
    6 days off nowso hopefully i can try and get this tv fixed..fingers crossed anyways
    That part no for LDO is EH14A-647J22 and the readings where 0.00..2.48..4.83
    I tested 10 small caps..5 where marked 72k-100-16v..the other 5 are k6p-22-16v..(G)when picture good(B)when picture bad
    C975-100-16v=(G)1.77(B)1.54
    C959-100-16v=4.83/4.83
    C971-100-16v=2.49/2.49
    C852-100-16v=2.49/2.49
    C853-100-16v=1.24/1.24
    C1708-22-16v=1.77/1.53
    C803-22-16v=2.49/2.49
    C796-22-16v=2.49/2.49
    C822-22-16v=2.49/2.49
    C727-22-16v=2.49/2.49
    I resoldered all the caps to make sure and the only 2 that are dropping are C975 and C1708..will these 2 caps need replacing? if so can any1 reccomend which 1s to get..thx
  • sienoki
    replied
    Is that 2.48V? What is the device part #?
    You could reflow it, try and see, but I don't think that's the problem. But just to confirm, probe the voltages on the nearby caps around that regulator, and see they change, some should be 4.38V and some should be 2.48V, if the voltage disappears suspect a bad joint.
    replied
    The readings are left leg 0..middle leg 248..right leg..483
    these readings are the same after screen failure..can a reflow of that area be done..i have non clean flux and a heat gun..thx
  • sienoki
    replied
    Check the regulator before & after failure, looks like you have found the suspect component. These LDOs, when they fail, can become temperature sensitive.
    replied
  • sienoki
    replied
    Hi tom..i did another hair dryer test as i feel its heat related now..after picture goes off i warmed up main board and in 1 area BINGO the picture re-appears..
    Is this a failing element or solder issues..im borrowing a descent camera later so i can zoom close in and send pictures..thx
    Hi these r the close ups..its the area around the IC902..thx
  • Paul678
    replied
    I would try re-soldering all the pads around that
    one problem area....
  • THXFX
    samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
    by THXFX
    Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
    I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
    When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
    What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
    I check capacitors and diodes and didn't find any short IN MAINBOARD.
    Measured all power supply...
    03-20-2024, 03:21 AM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • Zeonalbasta
    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
    by Zeonalbasta
    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
    09-13-2024, 01:17 PM
