Phillips 50PF7220A/37B - seven red flashing lights.
Re: Phillips 50PF7220A/37B - seven red flashing lights.
See post #5, point 2. Once you find it, list the part number and look for its datasheet for confirmation. The datasheet will say powerfet or something like that.
If you can't find it, provide more pictures of the front side on the board. We may need to see the chips attached to the heatsinks.
PS. The fet will be on the hot side of the board.Last edited by retiredcaps; 01-15-2012, 07:20 PM.--- begin sig file ---
--- end sig file ---Comment
Just noticed on the backside, there are two brown/black spots on these transistors. Is that flux residue or physical damage?
See red circles.Attached Filesif you find these attachements useful please consider making a small donation to the site
Whilst I'm no expert, I can't see any physical damage so I suspect it's flux residue as I can see other components with similar but smaller marks. Most of the marks will rub off with an alcohol swab.Stolen Sig: I want my own Law, like Ohm, Murphy and Cole.Comment
Those are numbered Q8001 and Q8003. The component at Q8001, again cleverly hidden under a heatsink, is numbered DE3523 which Google tells me is a Power MOSFET. How should I test it? Remember I'm new to this so I would appreciate the "idiots" guide.
Thanks.Stolen Sig: I want my own Law, like Ohm, Murphy and Cole.Comment
1) Number the pins 1, 2, and 3.
2) Measure the resistance between pins 1-2, 1-3, and 2-3. You can perform this in circuit.
3) Any reading under 30 ohms suggests a short and requires you to desolder the component and retest out of circuit.--- begin sig file ---
Hello gents. I have a similar issue. The symptoms is that I get the red flashing light. When I unplug and replug the power cord, I can hear a relay or switch inside the TV. The light start off green but it will disappear then the red light comes on without the tv powering up. The funny thing is that unplugging the TV works sometimes. I opened the back of my tv to look for any obvious damage but there isn't any visual damages or burnt smell. I know it has to be a switching device but I haven't troubleshoot a circuit board in many years plus I have no schematic. Just looking for some kind of help. I know has to be a simple fix. Thanks in advance.Comment
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... -
by cymro121Hia, I'm pretty sure am having an issue with an LED driver on my grow lights.
Video's...
https://drive.google.com/file/d/1Odp...ew?usp=sharing
https://drive.google.com/file/d/1OcV...ew?usp=sharing
Photo's of driver circit..
https://drive.google.com/file/d/1OjX...ew?usp=sharing
https://drive.google.com/file/d/1Oj5...ew?usp=sharing
One side of the lights were working correctly at 70v the other day and the other side was... -
by TVAddictHello everyone, so the problem is the tv would seem to power up when i hit the power button as i would hear a relay click, sometimes it may give me a good picture for about 5 secs or so, sometimes i get a black screen, then shortly after it will click back off and i get power and opc lights flashing together twice followed by one flash of the opc light then it repeats.
Please correct me if i'm wrong but i understand the flash sequence indicates a possible power supply problem, can anyone say if this is accurate information? So going on that i went ahead and tried a factory reset, checked... -
by berrmichI have the above TV. Black screen. Power blinks 2 times. OPC blinks once. Plug in with channeldown/volup. Powers up with solid green power but no light. I removed, cleaned and tightened the screwed on the inverters. I tested plug coming from the power supply to the inverter board when unplugged. INV12V shows 7.4 V DC. INV60V shows 0.1 or something like that. After plugging in the cable I don't get meaningful voltage from either one. (I measured after booting the TV with channeldown/volup.)
Is this a bad power supply? Or am I measuring something wrong.
-Mike -
by learnmoreHello Community!
CASE DETAILS
Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
Tried inserting firmware on USB and left it in for a few hours, but no change
... - Loading...
