Philips 42PF7320 plasma, strange problems
+ More Options
Posts
  • homerging
    • Dec 2011
    • 24
    This TV had two problems. It would intermittently drop into standby mode while operating. And when the entire display area changed between scenes at once, the panel would sometimes blank out for a moment.
    After dropping into standby, the TV would need to be unplugged and replugged before it would turn on again.
    I opened the service menu and an error 11 was registered. The service manual says this is an "I2C error while communicating with the 2D/3D combfilter Columbus". Could that have just been from low voltage?
    Then the TV wouldn't turn on at all - the relays clicked twice, the red LED showed momentarily then it clicked off.
    The front LED never displayed any blink codes except for the second to last time the TV turned on the front green LED blinked infinitely.
    There are no burst capacitors on the power board (a Samsung LJ44-00101B PS-424-PH Rev0.65) nor does anything there look cooked. But about 2/5ths of the caps have subtly rounded quadrants whereas the rest are totally flat on top. Is this some manufacturing variation or the result of pressure buildup? These are Samxon KMOD caps from 2005.
    I tried unplugging everything from the power board except the mains power connector. It still clicked thrice. After that, it won't click at all now. Is this normal behaviour when the PSU is in isolation? Does this indicate blown fuses? Would it be dangerous to the TV to plug everything back in and try again?
    I found a repair tips guide for the power board (search "Philips PS- 424-PH LJ44-00101C PSU.pdf" ) that describes how to provoke the power board to display an error code, but I don't have he necessary shorting jigs and am a bit wary of trying to connect the pins directly as they are so close together.
    Could this all still be consistent with just Samwha C8059/60 failures? The power board does seem to be the root of the problem but this is unlike the difficulties it has given others.
    So I'd be thankful of any tips.
    Re: Philips 42PF7320 plasma, strange problems
    Subtly rounded sounds a lot like bulged to me. If they are not completely flat, they have failed, or are about to. It certainly sounds a lot like a power supply unable to cope with transient or sudden changes in loads, bad caps can cause that.
    • homerging
      • Dec 2011
      • 24
      That would mean up to 15 capacitors in all may need replacing.
      What I would like to know is whether it's worthwhile attempting to replace these caps, that is, what concerns me is what the lack of relay clicks means and whether replacing the capacitors is likely to fix it?
        It's possible you now have a more serious problem. Can you post a picture of the power supply board? Then some tests can be highlighted.
        • homerging
          • Dec 2011
          • 24
          pic attached
            Test these two resistors while the TV is off. I think they should measure 6.8 ohms each.
            Test this fuse also while off. I think it should measure less than 1 ohm.
            Also test the resistance of your meter leads - touch both probes together and note down the measured resistance.
            • homerging
              • Dec 2011
              • 24
              Unfortunately, I do not have a meter, so I would have to get one, but I'm not sure about how to tell the good from the bad in that area over what is needed to test a power board.
                A multimeter is fairly cheap. Whereabouts are you?
                • homerging
                  • Dec 2011
                  • 24
                  The one on the left gives 6.8, the one on the right varies from 6.8 to 7.0. They both have 6.8 written on them.
                  It gives 0.1 to 0.3 if I touch the two points on the back of the PCB, and 1 to 3 if I touch the fuse directly on the front of the PCB.
                  It jumps around alot and comes to zero.
                  • homerging
                    • Dec 2011
                    • 24
                    Ok, so the 8A fuse giving 0.1 to 0.3 probably means it is still working normally? Does the lack of relay clicks specifically mean a fuse or fuseable resistor is blow?
                    If this power supply board is effectively unrepairable, can I swap in any working LJ44-00101B / LJ44-00101C replacement powerboard, or is television model-specific setup required to supply correct and operationally safe voltages?
                    • homerging
                      • Dec 2011
                      • 24
                      The powerboard models for this TV have a cluster of dodgy 680uf 50v Samwha WB capacitors under a heatsink. Any cap that goes under it must be less than 30mm high. The only cap I can see that might be suitable and fits is the Rubycon 50ZLJ680M12.5X25.
                      Is the Rubycon ZLJ's being rated 0.025 for impedance versus 0.020 on the Samwha WB going to be a problem? In other words, is the Rubycon ZLJ an appropriate replacement?
                        Should be fine. Samwha WB are crap caps and never last (possibly they lied on the spec sheet - who knows?), the power supply should work fine with the Rubycons.
                        • homerging
                          • Dec 2011
                          • 24
                          Thanks, I did wonder about the accuracy about the WB specifications because apart from the load life, they're excellent.
                          • homerging
                            • Dec 2011
                            • 24
                            There are number of larger 16mm diam. Samxon KMOD caps that may need replacing (680uf 100v, 47uf 350v, 100uf 160v). What I am not clear on is are there special requirements for "filter" caps or live vs cold (dc?) if these are those? Or are the likes of Rubycon ZLJ or Panasonic EE likely to be fine so long as they match ESR and ripple current specs?
                            • DPark
                              • May 2013
                              • 26
                              Hi there. First off, I've learned a lot from reading these forums and I wanted to to thank all the people who contribute to this site. I'm pretty new to TV repair and have had some luck in finding simple capacitor swap out jobs.
                              Now, here's my problem. I have a Philips 42" with a 5 blink red led code. The TV will power on for about 10 minutes (time varies) and then there will be a crackle and it will shut off with a 5 blink led. If you unplug it and give it some time, it can be reproduced, but not always.
                              I have visually inspected all the caps on the board (ESR meter on the way since I seem to be getting more involved in repair) and have found none to be bulging or domed.
                              After checking some voltages and matching them up with the sticker on the upper right of the chassis, everything seems normal except the Vset reading was 560v instead of the 195v it should be at! Hmm... I have a feeling that this has something to do with the problem.
                              What could be causing this? What is my next course of action in troubleshooting this board at a component level?
                              • DPark
                                • May 2013
                                • 26
                                I forgot to mention that the power supply is the one in this thread. (LJ44-00101B) The TV is a similar model (42 PF 7220A/37B).
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Originally posted by DPark
                                  After checking some voltages and matching them up with the sticker on the upper right of the chassis, everything seems normal except the Vset reading was 560v instead of the 195v it should be at!?
                                  Tom66 is the plasma expert, but I can't ever recall seeing a post where voltage is 560V DC. If that reading is correct, then I would have expected many capacitors to go .
                                  --- begin sig file ---
                                  --- end sig file ---
                                    Vset should be very close to Vs (180~210V), not guaranteed to be exact, but very close.
                                    A 560V Vset would burn your Y-main and buffers, so you're probably measuring it wrong...
                                    • DPark
                                      • May 2013
                                      • 26
                                      I don't think I'm measuring it wrong. I have the black probe touching the chassis and the red wire going to the little solder spot where it says "vset." Then, I turn on the power. What could I be doing wrong?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Show us a picture of your multimeter.
                                        Some multimeters have low batteries and give incorrect readings, but there is no indication of the low battery indicator on the lcd screen.
                                        • celiabrown
                                          Issue with Plasma Philips 37inch chassis FTL2.1
                                          by celiabrown
                                          Hello guys,
                                          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                          Can someone has any symptom like this ?
                                          Thanksโ€‹
                                          05-09-2024, 10:56 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the pรฉripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
