insignia ns-32lcd
  • pawel
    • Nov 2011
    insignia ns-32lcd
    will not power up have red light turn on and no light and black screen put in new power board still the same nothing help me
  • trebo
    • 514
    • Wales, UK
    Re: insignia ns-32lcd
    you need to post this here for best results in getting replies, and the best help
    https://www.badcaps.net/forum/forumd...ces y.php?f=31
    • mr.sky
      • Sep 2011
      • 54
      Check the Nano Fuse, it is very tiny, black with a marking 20.
      It is located on the Inverter Board.
      • pawel
        • Nov 2011
        ok bought new power supply and inverter board found for 28.00 and still nothing any idea's I am goin nut's.
        • selldoor
          Slow Learner
          • 7870
          Hi - firstly you need to update your profile to say where you live.
          You then need to provide some information about yourself- electronic skills what tools (multimeter/ Soldering iron) you have and your ability to use them
          You then need to take the back off your set and provide a clear photo of the general layout. Photos will also be required of the front and back of the individual boards. I see you have replaced the power supply was it guaranteed working?. What else have you tried. Have you searched this forum to see what others have done. Have you read this thread:
          https://www.badcaps.net/forum/showth...ignia+ns-32lcd
          You should also read :https://www.badcaps.net/forum/showthread.php?t=10419 from about post 18 as it will give you some ideas on what checks /tests will be needed.
          Photos should not be posted inline - use the manage attachments. They should be well lit, clear, we should be able to read the part numbers on the boards.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
