will not power up have red light turn on and no light and black screen put in new power board still the same nothing help me
insignia ns-32lcd
Re: insignia ns-32lcd
you need to post this here for best results in getting replies, and the best help
https://www.badcaps.net/forum/forumd...ces y.php?f=31Last edited by trebo; 12-10-2011, 02:33 PM. -
Hi - firstly you need to update your profile to say where you live.
You then need to provide some information about yourself- electronic skills what tools (multimeter/ Soldering iron) you have and your ability to use them
You then need to take the back off your set and provide a clear photo of the general layout. Photos will also be required of the front and back of the individual boards. I see you have replaced the power supply was it guaranteed working?. What else have you tried. Have you searched this forum to see what others have done. Have you read this thread:
https://www.badcaps.net/forum/showth...ignia+ns-32lcd
You should also read :https://www.badcaps.net/forum/showthread.php?t=10419 from about post 18 as it will give you some ideas on what checks /tests will be needed.
Photos should not be posted inline - use the manage attachments. They should be well lit, clear, we should be able to read the part numbers on the boards.Last edited by selldoor; 02-14-2012, 07:17 AM.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
