Insignia NS-27LCD
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Insignia NS-27LCD
    I already explained why that doesn't apply.
    Impedance doesn't have anything at all to do with it.
    The resistance changes with frequency.
    [And I mean resistance, not reactance.]
    The resistivity of the electrolyte changes with frequency.
    [I already explained how. And you can look it up too. It's easiest to find in Chemistry books.]
    So is your contention that the electrolyte is not in series with the leads or that it's resistance is some kind of fake resistance and so not 'actual'?
    Mann-Made Global Warming.
    - Dr Seuss
    • Paul678
      • Nov 2011
      • 402
      #42
      This conversation is over. I'm clearly dealing with a
      bone-head!
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Actually you've been dealing with a VERY PATIENT teacher today.
        But some people just aren't capable of learning new things.
        - Dr Seuss
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • srs
          Insignia NS-50DR620NA18 w/ large vertical lines & no picture
          by srs
          I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
          A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
          I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
          04-22-2023, 02:40 PM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • viking509
          vizio e65 e3 LED tv color vertical lines center tv only
          by viking509
          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
          03-21-2023, 12:48 AM
        • rfxcasey
          Vertical Lines on Half of LCD Display
          by rfxcasey
          I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
          05-16-2024, 06:52 AM
