Re: Insignia NS-27LCD
Actually you've been dealing with a VERY PATIENT teacher today.
But some people just aren't capable of learning new things.
Insignia NS-27LCD
This conversation is over. I'm clearly dealing with a
bone-head!Leave a comment:
I already explained why that doesn't apply.
Impedance doesn't have anything at all to do with it.
The resistance changes with frequency.
[And I mean resistance, not reactance.]
The resistivity of the electrolyte changes with frequency.
[I already explained how. And you can look it up too. It's easiest to find in Chemistry books.]
So is your contention that the electrolyte is not in series with the leads or that it's resistance is some kind of fake resistance and so not 'actual'?
.Last edited by PCBONEZ; 12-06-2011, 05:01 AM.Leave a comment:
You really are a Grumpy Old Fart, aren't you? haha!
The purely real portion of an impedance is non-frequency
dependent.
Read up on it.....Leave a comment:
If you actually read the description of that factor, and understood capacitors, you would realize immediately that they tagged it with an inappropriate name.
[That's a problem you ran into trying to explain things you don't understand with google.]
It is nothing but the resistance of the metals.
It's ~FAR~ from being the only component of series resistance in a cap.
And all of them are -actual- resistance - and in series.
When I first found this site I had all the same misconceptions you have right now.
But that was 6 years ago.
.Last edited by PCBONEZ; 12-06-2011, 04:42 AM.Leave a comment:
Boy, you are a real numb-nut, aren't you?
Look at the equation you posted: Ras is the actual
series resistance....that doesn't change with frequency!Leave a comment:
Wrong. Again, the actual series resistance in
Fig. 4 does NOT change with frequency.
It's you who does not comprehend.....Leave a comment:
I did look at Fig. 4.
So you don't know how to do that either... Go figger.
They show [Rl] in parallel with [Rd].
Rl is a DC consideration and as your reference says it's around 10 Giga-ohms.
It's not actually applicable to ESR but for your sake I'll go with it.
In combination Rd and Rl are a parallel pair.
They are NOT in parallel with the leads - just each other.
As a unit they are in series with the leads.
They are BOTH part of the series resistance.
They are both 'pure' resistance as you call it.
Either one changing will change the total series resistance.
And YOUR reference says flat out that Rd changes with frequency.
- Thus the actual series resistance changes with frequency.
You obviously don't understand what you are reading.
.Leave a comment:
Look at Fig. 4.
The dielectric loss is modeled as a parallel resistor.
I'm talking about the actual series resistance.
Get over it, you are wrong.Leave a comment:
So now you claim the electrolyte and dielectric are not in series with the leads.
YUP, comprehension issues galore!
Guess what. - They ARE in series with the leads.
And YOUR reference says their resistance changes with frequency.
[Because it does.]
.Last edited by PCBONEZ; 12-06-2011, 03:11 AM.Leave a comment:
Incorrect. My reference says I'm right.
The actual series resistance does not change with frequency.
Get over it, and hit the books more.....Leave a comment:
You are wrong.
I was talking about the actual resistance, which
Hit the books more, son.....Leave a comment:
True ESR is the purely real portion of the impedance (pure resistance),
and should ideally not change with frequency, so that's the measurement error of the technique. But the higher the test frequency, the less you charge
the cap, and the less the capacitive reactance. Too high a test frequency
would also be bad, because then the parasitic inductance of the cap starts to kick in.
[If you are unfamiliar with "variable "pure" resistance" then look up "variable resistor".]
That's how it works. Get over it.
There is also no such animal as: "True ESR" BTW.
"TRUE Equivalent" would be an oxymoron.
Also wrong. Discussed earlier.
Wrong again.
AC doesn't charge caps, DC does.
Xc doesn't have anything to do with the value of ESR.
[In fact you can clearly see that in cap data sheets. ESR varies with the can size and uF [hence Xc] doesn't have squat to do with it.
.Leave a comment:
Wrong. You misunderstood me.
I was talking about the ideal, purely real
portion of the ESR, which does not change
with frequency. That's the actual series
resistance.
You are a confused person....Leave a comment:
That's only -one component- of ESR.
You are ignoring many others.
They are ALL there at the same time.
They are all 'true' parts of 'true' ESR. - Because that's what ESR -IS-.
IOW: You are trying to argue that ESR does not change with Frequency because ONE thing that adds to it doesn't change with Frequency.
You are deliberately [or ignorantly] ignoring things included in ESR that do change with Frequency.
That is EXACTLY like finding the total resistance of a resister network and leaving the values for 1/2 the resistors out of the math.
Thus your argument has no merit.
As even YOUR reference shows that ESR changes with frequency.
.Last edited by PCBONEZ; 12-05-2011, 06:28 PM.Leave a comment:
Wrong. The dielectric loss is modeled as a parallel
resistor. I was talking about the "actual series resistance".
THINK before you assume you understand people....Leave a comment:
I understood you perfectly well.
You claimed ESR does not change due to Frequency.
- It does.
YOUR reference even says so.
Thanks for picking that one BTW. Most don't mention it and I'd have to look somewhere else for a link.
Using "'cos" is even worse than using "get stuck", "clog" or "hang up"
Welcome to the vocabulary club.
.Last edited by PCBONEZ; 12-05-2011, 05:56 PM.Leave a comment:
You never had an argument, 'cos you misunderstood me.....Leave a comment:
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by srsI'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables... -
First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
tried blocking LC lines too, but same results
is it lcd panel issue or tcon board issue?... -
by gpo23Hello,
i order a t-con because i had bad colors on my SONY KDL-40V3000 :
With the new t-con the color are good but there are vertical lines on all the screen :
I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
Is there a way to fix the vertical lines on the new t-con ?
Thank you for your help
gpo23... -
by viking509I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
- Loading...
