Samsung LE32R88BD/ BN44-00155A
--- begin sig file ---
--- end sig file --- -
Re: Samsung LE32R88BD/ BN44-00155A
Hi All,
This is my first post. My name is Clayton and I am located in Ormond Beach, Florida, U.S.A.. I have an A.S. in electronics engineering technology which I received in the fall of 2011.
I found this thread while searching for the value of rm801. Thank you bornintheuk for linking the schematic or I would have most likely missed the carbon trace at cm810 and thanks to retiredcaps for pointing out the bad glue. I will be removing this glue from all of my future repairs.
Its funny the glue issue never came up in any of my college courses. Just goes to show that years of field experience is far superior to a college degree. And is most likely why I have yet to find a company willing to hire someone fresh out of school.
Thanks agian to all who contributed to this thread. You have saved me time and parts on this repair. I will look here first for all my tech questions in the future.
ClaytonComment
I wouldn't say the above is 100% true. People with experience also need to keep their skills current by constantly learning otherwise the new guys pass them by.
Keep plugging away. Good luck in the job hunt.And is most likely why I have yet to find a company willing to hire someone fresh out of school.--- begin sig file ---
--- end sig file ---Comment
I look at my SCH , RM801 on page 2 is 0.22 Ohm 1Watt resistor.Attached Filesif you find these attachements useful please consider making a small donation to the site
hello I'm new in forum
I'have nearly the same trouble, the red light of my samsung 32" flash while power in but the sceen remain black. I have swaped a PS pannel with the one of my brother TV the trouble was fixed. I have changed several capacitor out of order on my PS pannel but the TV still doesn't fix. I have just removed the glue, and no shurt cut observed and the TV is stil unfixed. So any other idea?Comment
Post clear focused pictures of your power board following my sig file instructions below exactly (see post #21).
Do you have a multimeter and know how to measure DC voltage?--- begin sig file ---
hey all
I need help
my samsung LE32R86BD with the same power board BN44-00155A. my problem is that the screen is black but still sounds in the speekers.
my question is -will it help me too replace the power board or can there be any orther problems then the power board ????
pleace help soo i can do the tv done for the christmas..... I hopeComment
Hi there!
I am the very new user here, but I managed to find the thread I was about to create.
I have BN44-00155A power supply board in Samsung LCD TV. Same problem as everybody mentioning.
As you can see from the picture, RM801 is burnt, and some of the glue are really dark brown, which should be removed (as i understood from the posts).
I can't see any of physically damaged caps.
Could someone give some hints if they understand what could be wrong with the board that caused RM801 failure. Thank you in advance!Attached Filesif you find these attachements useful please consider making a small donation to the site
@APKIS, RM801 fusible resistor is blown is more likely due to shorted out MOSFETs, see the attached diagram.
Make sure to remove all the yellow/brown glue.Attached Filesif you find these attachements useful please consider making a small donation to the site
@speedypro, check to see if you have either 5V or 12V at both ends of the SMD fuse on the T-CON board. The buttons on the TV works, you can turn the TV on and Off?Never stop learning
I'have nearly the same trouble, the red light of my samsung 32" flash while power in but the sceen remain black and never turn on. There si not sound.
I have not replace any part yet because i dont see any component damaged o burn out.Attached Filesif you find these attachements useful please consider making a small donation to the site
Next to each connectors there are labels telling you what the voltages should be. Reports the voltage readings/name of the pins.Never stop learning
I'm sorry, i'm not an expert...so let me ask you, Do i have to energizer the board and with the tester read the voltage in the connectors? what connectors are you talking about?. Sorry again and thank you.
Do i should removed the all the glue in the board? what is the best way to do it?
There is other pictures ...Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes you have to have the boards all hook up and power applied. If you look at the multi-pin white connectors on the power board, you will see voltage labels next to the pins. We need to know what you are getting or not getting at those connectors, by the way, those yellow glue must be removed.
Warning! do not touch any heatsink or anything in the hot side (line side) of the board, it is fatal.Last edited by budm; 05-08-2013, 09:28 AM.Never stop learning
Hi
My rm801 resistor keeps exploading. Like it exploads with visible light flairs and crack noise, BAM with smoke afterwards. It happens with no cables connected except for the power cable. I've replaced CM810 and the two mosfets QM801 / QM802.
Any idea?
None of the capacitors have visible damage or look blown.Comment
Replace with a higher wattage resistor of the same value maybe...
I mean, it's not the ideal fix but... I'd hope it would at least work to find out where the main problem is and why more current is running through that resistor. If and when you do this, try to measure the voltage across the resistor once replaced and report back.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
What resistance do you read on the output side of the fusible resistor that feeds the MOSFET's and Primary Ground ref point (Source pin of QM802)?Never stop learning
Hi Guys,
I have a BN44-00155A fitted to a LE32R88BD for a neighbour, basically it swtiches on and off by itself. I had seen on line a company selling a kit of three caps to repair it CM851, CM852, CM860. I basically bought some replacement caps from a quality shop on ebay, fitted them and all seemed well it ran for 5 hours no problems. I left it for a day turned it on and after about 1 hour is did it once, left it again and tried it again today and after about 20 mins is switched on and off about 5 times vary close together. Help!
I am very competent at soldering and using a meter.
AndyComment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
