A year ago I worked on this tv and the inverter board had obvious damage to an IC chip and two bloated caps. I went ahead and bought another board instead of trying to change the tiny smd IC. It had been working fine.
Today, I get the tv back. The symptoms are: when you turn the tv on, the screen will flash on then off ( you can see words), flash on then off ( you can see words) then go black. The power light stays green. After about a minute, it will power down.
I looked at the black screen with a flashlight, and I can see the words, so I feel I have another inverter problem.
I removed the inverter to see no obvious defects.
If it is an inverter problem, why does the tv power down after a minute?
