TS15P06G Rectifier
  • uberplasma
    • Oct 2011
    • 85
    TS15P06G Rectifier
    Hi all
    I have a question about a TS15P06G rectifier in a Philips 37" LCD TV - I have 120VAC in and 173 V DC out, is this a normal output? I can not find any info on the spec sheets as to what this should put out. It is a Philips 37PFL5332D37, I am fixing a cap/fuse problem to the inverter board and all other boards have good LED status lights and there is picture and sound, just the invertor is not working. If anyone knows a link to the power board schematics that would be great too!!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: TS15P06G Rectifier
    Originally posted by uberplasma
    Hi all
    Yes. AC is rectified (AC x 1.414) into DC. So 120 x 1.414 = 169.68 DC volts.
    --- begin sig file ---
    --- end sig file ---
    • uberplasma
      • Oct 2011
      • 85
      Thank you fellow Canuck!!
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • Steph.hen
        Bridge rectifier identification part number KPB305G
        by Steph.hen
        Hi all, a newby question about a bridge rectifier I'm trying to identify.
        I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
        08-29-2024, 09:52 AM
      • double_DD
        Philips curling iron - is this a common AC cable?
        by double_DD
        Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
        As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
        Not sure if this is something Philips proprietary, or a standard, but the cable plug...
        08-18-2025, 10:04 AM
      • janos6662000
        Philips 47PFS7509/12 LCD TV problem
        by janos6662000
        Hi
        I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
        When i applied cable signal to check image, i had normal picture, but TV was restarting.
        I downloaded original firmware and applied the update, but the problem remained.
        From a colleague i received a "factory package software" which is a lot bigger.
        I made another firmware update, but still did not solve the problem.
        Somewhere on the way the error got worse, because at the moment the...
        08-12-2025, 12:54 PM
