Sanyo lcd-37xr9da picture negative, abnormal display
  • pigdaddy
    • Oct 2011
    • 5
    Re: Sanyo lcd-37xr9da picture negative, abnormal display
    Hi mate. just heard back and for me it was a faulty tcon. haven't viewed the unit yet. just got the call. hope this helps in some way, apparently the part was about $150 from Sanyo. maybe u can source a new unit from them?
    • tw2005
      • Oct 2011
      • 6458
      Cheers, Thanks. That's what I heard too so at least their pricing is consistent(Sydney).
      what I ended up with was viewable. I've just offloaded it but it appears to me this is what goes on these sets and around the 2 year mark.
      I'm just glad my diagnosis was correct, good learning experience.
      Thanks.
      • Tech Pal
        • Dec 2011
        i have the same problem too with my Sanyo LCD 37xr9da and im hoping that i can fix it.
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • shelby5041
          Samsung LCD TV no picture backlight on no 12v at tcon
          by shelby5041
          hi
          i have a samsung lcd tv
          it powers on with sound and backlight but no picture
          all voltages from PS are good 12v 3.3v and 5v
          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
          no 12v at the tcon fuse
          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
          the odds of having 2...
          10-08-2021, 08:21 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
