Samsung LCD Power Board turning on and off.
  • adambutt
    • Feb 2013
    • Uk
    #41
    Re: Samsung LCD Power Board turning on and off.
    First of all thanks for all your posts and team work
    I am mobile phone repairer and know a bit about electronics recently my uncles samsung tv got fault . The red light on the front blink 3 or sometime six times and no display . I took the power board out clean it with rubbing alcohol dry it and it start working after few days it again stopped working . I checked few forms and every one was saying change the capacitors but there was no leak or blown caps in my power supply . So what I did re clean the power supply board with rubbing alcohol and re-solder all the ICs , transistors, FETs , inverters and all the main components . After that I turned the tv and it is working fine . I did not have to change and caps or any thing
    I would suggest to every one who is having this blinking light problem and can't see any blown or faulty caps please re heat or re solder your FETs and main components may be there is cold solder or any lose connection
    • adambutt
      • Feb 2013
      • Uk
      #42
      Originally posted by Cessna170
      Hey Guys looking for some help I have a 32' Samsung Model #LN32A450 with a power board Dong Yang MK32P5B, this unit runs for about 30 mins and then shuts off, and it will always restart right away....I replaced all the electrolytic caps 13 of them and I am still having the same issue, can anyone suggest any other component that might causing the issue...Please let me know and Thanks for reading my post.
      • adambutt
        • Feb 2013
        • Uk
        #43
        Hi ,
        I had the same problem and my tv is working perfect now after re soldering all the FETs . I think after few year the soldring gets rough . I did not have to change any capacitors . So thanks for your post
        If anyone can't fix their Tv after changing the capacitors try ro re solder the main ICs , FETs and other components
        It should be fix
        • jsaily
          • Jun 2010
          • 8
          • Finland
          #44
          I worked on a Samsung LE32A465 from my friend which turned on and off randomly. The power board is BN44-00214A and it had one bulging capacitor, the 2200uF / 10V connected to the stand by circuit. Its ESR value was actually not as bad as I thought, about 0.6 ohms. Replaced it with Panasonic low-ESR type. Other caps measured good, close to zero ESR. The TV turned on, and stayed on for a few hours without problems so I gave it back yesterday.
          Today it didn't start again, and I found this thread about the dried up solder joint plague on these boards. I resoldered all MOSFETs, diodes and ICs, and now it's holding up again without problems. Will try again tomorrow morning if the bugger will cold start.
            I would suggest to replace the caps as a set.
            • jsaily
              • Jun 2010
              • 8
              • Finland
              #46
              I would have replaced 'em all but did not have the 3300uF cap. They measured ok though, and the TV boots up nicely this morning too. I have some cap values on order now and will replace the rest if the tv comes back to me :-)
              • mmartell
                • Oct 2013
                • 3189
                I know this is an old thread but wanted to add my appreciation. Resoldering QB802 indeed fixed my startup problem.
                Funny thing is it didn't even look bad under my magnifier but I added solder to all three pins. On one pin I put a fair amount of solder and when I checked my work thwre was still a large part that had no solder. I thought where the hell did it go ? Added more and then all was good. Cheers!
                • Engineer John
                  • May 2014
                  Originally posted by waitery
                  OK guys, we're watching TV! Cold solder joint found on Fairchild Mosfet located at QB802, just a step passed PC802S. I just kept getting these huge voltage swings at PC802, so I started backtracking and when I got to the FET and I touched it with my Fluke probe to get a reading and it was just enough pressure to start the TV without me having to press the on/off switch.....so thrilled! The joint was super weak looking before reworking it and applying three new beads of solder.
                  Looks like she is holding steady, voltages all look good and there seem to be no problems. It fires up perfectly every time I hit the remote and touch the set's power button. I am going to burn test it to make sure that we have the issue buttoned up.
                  Retired and PlainBill, THANK YOU SO MUCH for your help, patience and most of all, YOUR TIME! I would love to sit down and troubleshoot with you guys one on one! I appreciate you both!!
                  Exactly my problem!
                  Checked the QB801 and QB802 and found one tiny circle crack around the pin.
                  It wobbled a bit when I wiggled the transistor. Touched up the solder and perfect operation. It's been going for a week now.
                  Thanks a bunch for posting this, I would have replaced all the caps otherwise and then gotten frustrated by no no success.
                  John
                  • Engineer John
                    • May 2014
                    ....turned on and off randomly. The power board is BN44-00214A and it had no bulging capacitors.
                    John
                    • waitery
                      • Feb 2011
                      • 69
                      #50
                      Originally posted by Engineer John
                      Exactly my problem!
                      John
                      My pleasure....sounds like a common manufacturing defect. Nice work John!!
                      • Vilpo
                        • Jun 2014
                        • Finland
                        #51
                        Hi guys. I just wanted to let you know, had the same issue with Samsung tv, power board bn44-0214a. Tv would turn on/off by itself, and sometimes would not turn on at all..
                        Ordered a cap repair kit on ebay and replacing caps would not fix the problem.
                        Then, i found this topic and more carefully inspected the solder joints.. And what do you know, a bad solder on QB802, one of the legs had a circular crack in the solder.
                        I desoldered, put new solder on the legs and now tv works like normal!
                        Thanks guys for this awesome find!
                        • dcapper
                          • Dec 2013
                          • 496
                          My turn to ask for help. I retouched almost every solder joint. I metered all diodes and caps out of circuit, including the large cap. I metered the transistors as well, no shorts, including QM801 and QM802. No power just a standby light. Has anyone ever had to replace the 817N chips? There is 4 on the board. I had an Emerson power supply that they were blown. Or should I be ordering a repair kit with the MC33067P chip?
                          • Cooperr
                            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                            by Cooperr
                            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                            10-21-2025, 01:11 PM
                          • C152Heavy
                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                            by C152Heavy
                            Summary for TL-DR readers:
                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                            • Have read ALL applicable threads
                            • C1818 and CP820 replaced as low hanging fruit
                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                            • VCC pin (18) of PFC...
                            01-11-2023, 02:53 PM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • Destroyer-Br
                            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                            by Destroyer-Br
                            I'm working on an Acer Nitro 5 unit with the following specs:
                            • Motherboard: LA-J871P Rev: 1B
                            • Model: Acer AN515-55-59MT
                            • S/N: NHQ7JAL00403906A973400
                            • SNID: 03902728734
                            Initial Issue
                            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                            04-17-2025, 08:18 PM
                          • Nicktronic
                            Samsung Power Supply Board BN44-00874F
                            by Nicktronic
                            Hey everyone,
                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                            Anybody...
                            03-17-2025, 06:20 AM
