can i test the y-sustain main
  • minnguy32
    • Sep 2011
    Im a DIY working on a 42 philips plasma ... it had the 7 blinking red light...i removed the y-sustain main and the 2 buffers...i have tested the 2 buffers and they are both bad...so how can i test the y-sustain main??? is there a way??? the back of the y-sus main looks discolored a bit but not too sure...i tested the fuse on the y-main but it seems ok...any help would be great thanks PS...the tv model is 42PF7220A/37 the y-sustain main model is LJ92-01200A
  • rayrod81
    • Oct 2010
    • 205
    Re: can i test the y-sustain main
    The main fault on these boards are the FETs under the two heatsinks nearest the buffer connectors. When a buffer shorts it usually take a FET or two with it. The best way to test them is to remove the heatsinks and test for shorts. Most of the time these are the only problems on these boards but other components can go bad and are harder to find.
    • PlainBill
      • Feb 2009
      • 7034
      Search for my recent posts on Coppell TV Repair. One of them includes links to discussions on these boards, and it describes how to identify shorted buffers and the shorted transistor.
      PlainBill
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • chth96
        How Can I test PWM DM0365R?
        by chth96
        Hello
        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
        06-18-2025, 04:14 PM
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
