VIZO HELP - Model: VO420E - Black Screen, No Sound (No Anything)
  • Tayninh55
    • Sep 2011
    • 153
    Re: VIZO HELP - Model: VO420E - Black Screen, No Sound (No Anything)
    I know what you mean,,,,,,,,,I'm using my wife's table in her sunroom! If I knew for sure that there WEREN'T any other boards, I would jump on it I think I'll wait and see if Bill agrees with you about there being no other boards! Another opinion can't hurt,,,,although I do appreciate your help too!
    • Tayninh55
      • Sep 2011
      • 153
      Sorry,,,,,,,,,,,I double posted!! Bill's gonna' kill me if I don't get it off there!
      • Tayninh55
        • Sep 2011
        • 153
        Bill and Tom, Would you please look at this posting on ebay:
        http://cgi.ebay.com/ws/eBayISAPI.dll...m=320634040846
        This is the exact model number and part number on the Inverter/PS Board on my TV. Included with the Inverter/PS Board are two other boards (pictured on the Ebay ad) that MUST BE the Inverter Slave Boards. But can't find either on on the back of my tv.
        Other ads have shown the Inverter/Power Supply Board by itself (on one board) like mine..........................but most done show the other two boards with it.
        Please give me an opinion on this! Thanks!
        • rmoody
          Learning Member
          • Jul 2011
          • 262
          what's wrong with the 40 dollar board?
          • Tayninh55
            • Sep 2011
            • 153
            There is nothing wrong with the forty board!!! You obviously didn't look at the pictures in the Ebay ad! If you had, you'd have seen that in addition to that Forty dollar board (The Inverter/Power Supply Combination) on the this ad, there were TWO (or maybe just one with dark line in the middle) GREEN BOARDS,,,,,,,,,,,,,,,,that I suspect might be the Inverter Slave Boards. It sure DOESN'T LOOK like my green main board!!!! They are all listed under THAT ONE NUMBER on the board,,,,,,,,MEANING THEY ALL WORK TOGETHER IN THE INVERTER PROCESS?????????
            THE FORTY DOLLAR BOARD would work to swap out the Inverter/Power Supply Board,,,,,,,,,,,,,,,,,,,,,,,,,,,,but IS THERE A SLAVE BOARD that I haven't found.
            THAT WAS MY QUESTION, IS THE GREEN BOARD LISTED ON THIS EBAY AD, THE INVERTER'S SLAVE BOARD THAT I HAVE BEEN ASKING ABOUT?? Do you understand what I meant now?
            • PlainBill
              • Feb 2009
              • 7034
              OK, it's time for a reality check.
              1. The auction is for a single board. One picture is of the top of the board. Another is of the bottom side of the board. The other three pictures are of various labels on the board and the TV.
              2. The seller is listing this as New, but it was "PULLED FROM WORKING 42" VIZIO LCD, MODEL # VIZIO VO420E". In my book, that is USED.
              3. The seller's feedback rating is dubious, at best.
              In my opinion, this is NOT a power supply issue.
              PlainBill
                Before changing the inverters, have you checked the secondaries of the transformers to verify if they are good or bad?
                • Tayninh55
                  • Sep 2011
                  • 153
                  Bill,,,,,,Thank you very much, you were correct, it was the bottom of the "same" board.
                  • Tayninh55
                    • Sep 2011
                    • 153
                    RMOODY, I think now, that you were also right, in your 9/8 posting, when you said the inverter might be "built into" the Power Supply Board. Bill stated that he didn't think the power supply was bad and I agree with him now, but since I now believe the inverter IS built into the PS Board, in order to swap out boards, you get the Inverter/Power Supply all in one board. SO,,,,,I ordered the board from the TMS, Inc. website. I just hope this is the right move and I'll let you know if it works or not, for your future reference. I almost didn't post on this forum, because of the reference to mainly "Bad Capacitors", but am glad I did because you were basically the ONLY people who tried to help me (even though I started sounding like a "pain in the butt"), but I was just trying to be as sure as I could be! (I think it's pretty bad when a company (VIZO) that sells you merchandise and takes your money, refuses to even lift a finger to help you solve the problem when THEIR product is not reliable! Thanks again to all that helped!
                    • rmoody
                      Learning Member
                      • Jul 2011
                      • 262
                      #30
                      ok
                      • Tayninh55
                        • Sep 2011
                        • 153
                        UPDATE ON VIZIO - Model: VO420E - Black Screen, No Sound (No Anything)
                        Hi all!!! Good things to report. Received my combination Inverter/Power Supply from TMS this morning,,,,,,,installed it, and ALL IS WELL. As Bill said and I had surmised, it was not a power supply issue BUT, I had to replace the power supply as well as the Inverter since they were both located on the same board. There were "no other" inverters or slave inverter boards on this model TV.
                        So, as I was told "off the record" by a "tech" that does repair work for VIZIO, as well as one of the people that sell the boards, I HAD A INVERTER BOARD PROBLEM!!!
                        THEY BOTH SAID:
                        When I had a completely BLACK SCREEN (no light anywhere) and NO SOUND when the tv was PLUGGED IN and the Vizio logo showed up ORANGE. When I hit the power button on the remote,,,,or the button on the side of the tv, the Vizio logo turned WHITE, but still BLACK SCREEN AND NO SOUND that it was an Inverter Board problem. Hope this helps someone!
                        If it had been a Vizio model with a separate Inverter board, I would have just replaced that board, and not the power supply, but on this model they were on the same board.
                        I still don't understand why I had some of the weird voltage readings on the main board....................but I did absolutely nothing to that board.....and the TV works fine after replacing the Inverter. Many thanks to Bill, Tom, and RMoody for their input!
                        BUT BEWARE,,,,,,,,HE'S GIVING ME A MAGNAVOX WHEN HE PICKS UP THE VIZIO,,,,,,,,,,SO YOU'RE NOT "RID OF ME" YET!! I don't know what the symptoms were on his Magnavox,,,,,,,,,,but you'll probably be hearing from me soon again!
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Re: UPDATE ON VIZIO - Model: VO420E - Black Screen, No Sound (No Anything)
                          Thanks for the warning. I'm going to tear down my computer and clean the dust off the main board, polish the caps or something.
                          PlainBill
                          • Tayninh55
                            • Sep 2011
                            • 153
                            hahahahaha,,,,,,,,,,,,,,,,,,,,,,,yeah make sure that computer can "stay cool" under duress!!!!!! By the way, you put up some good "smilies" too!
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
                            • jb_Bak
                              by jb_Bak
                              CN6401
                              Pin 01 NC
                              Pin 02 NC
                              Pin 03 "BL_ON": 0V
                              Pin 04 "N/C"
                              Pin 05 "STBY 3.3V": 3.5V
                              Pin 06 "GND": N/C
                              Pin 07 "AC_OFF"...
                              09-27-2021, 04:52 PM
                            • canadaboy25
                              Panasonic TC-P54VT25 No image. A or D board?
                              by canadaboy25
                              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                              The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                              01-17-2021, 01:06 AM
