sharp lc-32gd8e
  • painner
    • Aug 2011
    • 8
    sharp lc-32gd8e
    hello please can anyone advice me what my problem is in the attachment i have uploaded of my sharp lc-32gd8e .i have spent days trying to track down what part has gone or even what board needs replacing .i love bringing tv,s back to life for a hobby but tracking this fault down is like banging my head against the wall . as i cant seem to exsplain the fault properly .many thanks for your time in reading this painner
  • dumpystig
    • Jul 2011
    • 485
    Re: sharp lc-32gd8e
    Jennifer Aniston in a blue movie...?
    Sorry...
    System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
    • PlainBill
      • Feb 2009
      • 7034
      Re: sharp lc-32gd8e
      Sorry...
      No, her blue movie was 'The Break-Up.
      PlainBill
      • Village Electronics
        OldPro
        • 118
        Re: sharp lc-32gd8e
        Maybe the T-Con board
        • dumpystig
          • Jul 2011
          • 485
          Re: sharp lc-32gd8e
          Originally posted by plainbill
          no, her blue movie was 'the break-up.
          Plainbill
          touche
          • painner
            • Aug 2011
            • 8
            Re: sharp lc-32gd8e FIXED
            FIXED
            Unplug the AC power cord of running TV set to force off the power.
            i then pluged it back in macking sure tv is off then
            While holding down the left side of the the “VOL and p keys on the set with one hand i then help down the input button ( the round button ) and then
            pushed the power button holding all 4 buttons down at same time
            The letter “K” appears on the screen.
            and it enterd the service menu ( took me a few attempts but finnaly got it up )
            On the remote you use Cursor (UP / DOWN) to change the pages to 10/11
            look for EEP CLEAR B OFF. Use Program P (up/down) on remote to go up and down pages.
            THIS IS IMPORTED ONLY LINE 2 "EEP CLEAR B".
            Now change OFF to ON with Cursor (LEFT / RIGHT) and then press the OK button.
            After a couple of seconds you got a OK.
            look for the page with Inch Setting. It schould say 32, if not change it to 32
            and finally set Factory Init.which was above inch settings i set my to uk as live in uk
            and OK it after pressing the OK button, turn off the tv.
            Thats it
            • dumpystig
              • Jul 2011
              • 485
              Re: sharp lc-32gd8e
              Nice one! How did you suss the above method?
              • painner
                • Aug 2011
                • 8
                Re: sharp lc-32gd8e
                alot of searching and help from a couple of sites . the advice on how i did it was from another site but i had to change it as couldnt get into service mode there way for some reason as a box came up with public mode where you enter 3 word or number code and didnt know it .so i got into it the way i knew
                • bmmach
                  • Aug 2011
                  • 4
                  Re: sharp lc-32gd8e
                  Wonder if this will resolve my problem which is similar but involves the color green. Any help would be greatly appreciated.
                  • Rictech
                    Panasonic SA-MAX770PU SMPSU board fault....
                    by Rictech
                    Hello everyone. 😀
                    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                    There are no devices that have exploded or otherwise show signs...
                    08-26-2024, 01:05 AM
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    07-19-2025, 10:54 PM
                    ESR meter came to the rescue again today with a PLC I/O card fault
                    by sam_sam_sam
                    I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                    I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                    One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                    12-18-2023, 08:17 PM
                  • CDNBrewer
                    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                    by CDNBrewer
                    Hello Everyone,
                    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                    Symptoms:
                    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                    • I swapped the Left and Right surround
                    08-05-2025, 09:29 PM
                  • Agent24
                    What kind of fault causes this image error?
                    by Agent24
                    I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
                    The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
                    What's the most likely cause of this problem, does anyone know?...
                    09-22-2025, 11:42 PM
