LG 42PC3D - Will Not Turn On (Standby Only)
  • marckuh
    • Jul 2011
    • 5
    The other day, we had a big thunderstorm roll through. During that, I had the TV on. I saw some lightning strike close to the house. I thought the power went off because I didnt hear the TV anymore. I go look and the standby light is on. I press the power button and the LED goes to green, blinks 3 times, and then back to standby. When I unplug/plug, I can hear the relay click though.
    I hooked up another TV and found that the HDMI port was bad on my DVR after all of this. The cable was fine.
    I removed the back panel of the TV, checked for any visual signs of damage; didn't see any. I noticed that if I unplug one of the plugs going to 68719MMU20A board, the TV wil turn on, light up (blank), and then eventually turn off. Not sure what that means, if anything.
    I've read a bunch of websites, but this one seems to have the most content and users who know what they are talking about. Any ideas/help would be greatly appreciated. I would like to fix the TV without spending an arm and a leg. I really don't know where to begin.
    Thanks in advance.
    Re: LG 42PC3D - Will Not Turn On (Standby Only)
    Pictures would be very helpful of the power supply and main board.
    Since it is stuck in standby, I'm inclined to think it is a coincidence (the primary side stuff is still good) or related to the HDMI port on your DVR. Does the DVR still work?
    If the set is still under warranty, take that route.
    • mj_ferry
      • Jul 2011
      • 7
      the board you listed that you unplug what board is it? What it sounds like that maybe that board is fried and it causes the power supply to shut down from protection. What you did unplugging the board is the start of troubleshooting. Since the dvr hdmi port is bad maybe you got a surge through your cable tv that went through the hdmi into the video main board in the tv and that could be whats fried. There should be a way to uplug everything from the powersupply board and put the powersupply in service mode and check the power outputs with nothing connected.
      • PlainBill
        • Feb 2009
        • 7034
        A few points.
        The 68719MMU20A is the main board. There are a number of plugs going to it. Which plug was removed is significant.
        The service manual for this set is available on Elektrotanya.
        As others have mentioned, pictures help understand the problem.
        It is very likely the surge from the lightning hit took out the board in the TV and also the HDMI output of the DVR. There may be other damage.
        PlainBill
        • cadillacman
          • Feb 2011
          • 524
          yeah thats scary.
          I do have a working parts set of the same or simular model, ive already robbed one of the sustain boards and this set had the sparkles issue that these all get.
          S if yu want a known wrking power supply and mainboard(may or may not make your set sparkle) lmk.
          I would be very scared that there may be more damage you wont know about untill you replace some other parts.
          • marckuh
            • Jul 2011
            • 5
            I took some pictures last night. Hope they help. If you want to look at the originals, I can email them.
            1. Power Supply
            2. Main Board 1
            3. Main Board 2
            4. TV Overall
            • marckuh
              • Jul 2011
              • 5
              I think I'm just going to take a chance and buy a main board. It seems to be the logical guess, lol, considering I lost the HDMI port on the DVR.
              • cadillacman
                • Feb 2011
                • 524
                oh wow wait nevermind i have 2 of these sets both have blown z-sustain boards and god knows what else.
                Best of luck sir i hope you are able to fix it up.
                Heres my thought.. you have a 50-50 shot here..
                If the lightning came through the power cord, you likely have damage to everything.
                If the lightning hit the cable box or came into the tv from the cable box,then you might get licky with just a mainboard.
                • joste
                  • Aug 2011
                  • 42
                  Wait up!
                  Did you check for bad capacitor on the attached photo? It's hard to tell for sure, but it looks pretty much bulged to me from here. You're aware that their shiny tops should be perfectly flat with no dark stains around.
                  Please, take a look and let us know.
                  Good luck!
                  • cadillacman
                    • Feb 2011
                    • 524
                    wow good catch man
                    • joste
                      • Aug 2011
                      • 42
                      Originally posted by cadillacman
                      wow good catch man
                      Thanks, hope it'll work for our friend Marckuh
                      Waiting for news...
                      • marckuh
                        • Jul 2011
                        • 5
                        Ok, I got home and checked out that cap and you are right, it has bulged. You have a really good eye! So do you think it's not the main board and the power supply or most likely, both boards?
                        • cadillacman
                          • Feb 2011
                          • 524
                          who knows. Jam a cap in there first and see what ya get.
                          *ignore below i couldve sworn you had a bulged cap on a sustain board, but its on the ps. Replace that cap and see what u get mabye youll get lucky!*
                          i seem to remember even if fuses on the sustain were blown, this particular model will still power on and have sound. so you likely still have other issues if you are for sure its stuck in standby.(you can confirm by hooking up a video and audio source to see if you have sound)
                          WHat you could try is to unhook power connectors to both sustain boards(with no ac power!!!) and see if the set then powers up when plugged back in and power button pressed
                          If its now on, power back down, unplug ac power, try one sustain connected at a time untill you find which sustain board is stopping ya from powering up and go from there.
                          if unhooking the sustains still does not allow the set to power up, then you have other issues besides just your sustain boards.
                          • marckuh
                            • Jul 2011
                            • 5
                            Guess who has a working TV!!!!! lol I switched out the main board and it fired right up. One thing that I noticed is that the main board has a green light on it, as well as, S/PDIF light. Those wouldn't light up on the bad board...well, the S/PDIF would light up momentarily. I am so happy...I fixed my TV for $43!!!
                            Thanks again for everyone's help!
                            • cadillacman
                              • Feb 2011
                              • 524
                              congrats man!! frickin awesome!! i love happy endings.
                              Made your tv your bitch for only $43? feek yeah man. beats the hell out of buying a new set doesent it???
                              • rmoody
                                Learning Member
                                • Jul 2011
                                • 262
                                I would have replaced that cap on the power supply too while I was in there. It will likely give you trouble down the road.
                                • madsox
                                  Harman Kardon AVR 171S - standby led lights up, does not turn on
                                  by madsox
                                  Greetings!
                                  Thank you in advance for your understanding, I am writing to you through a translator.
                                  A Harman Kardon AVR171S amplifier was given.
                                  The history of the machine is as follows:
                                  It was faulty when I bought it, I want to fix it.
                                  I replaced the HDMI switch and one of the DAC ICs in it.
                                  After that it worked without a problem.
                                  I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                  The cooling was faulty, I will fix this later.
                                  I switched it to standby mode, waited for...
                                  09-24-2022, 10:46 AM
                                • pajdek
                                  Lenovo Y700-17ISK turn on and off
                                  by pajdek
                                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                  09-20-2023, 02:49 AM
                                • Doodle43
                                  Samsung LN32B540 - won’t turn on but gets standby power
                                  by Doodle43
                                  My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                  It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                  05-26-2020, 12:02 PM
                                • twist3r
                                  Samsung 2693HM - Doesn't turn on (no standby)
                                  by twist3r
                                  Hello everyone!
                                  I'll try not to create big posts this time (though I'm sure I'll fail).
                                  Ok, here we go...
                                  Back in 2017. one capacitor on my monitor power board failed, so I had to replace it. I decided to change all the caps (except the BIG one), and everything was working well. I had a big help from other members, especially from momaka. He had enough patience to give answer to all my questions.
                                  For those interested in reading that topic, here it is: [help required] which capacitor type for monitor power board
                                  10-24-2020, 04:54 PM
                                • Scoff
                                  LG55UB850V no picture or audio - flashing LED's help please?
                                  by Scoff
                                  Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
                                  I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
                                  We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
                                  01-26-2022, 06:13 AM
