Sony KDL-46V5100
    • 12330
    • U.S.
    Re: Sony KDL-46V5100
    when you hit a button on the remote or button board, does the green light respond by dimming a little or no response?
      • 12330
      • U.S.
      I would try the update, usb method, make sure to follow it to the letter: https://www.sony.com/electronics/sup...loads/W0006532
      • diif
        • Feb 2014
        • 6978
        • England
        Originally posted by dxucam
        Thanks, will do... though my current multimeter doesn't have a 'continuity' test setting.
        You can use the resistance setting.
        • dxucam
          • Nov 2022
          • 14
          I did the 'hail Mary' software update, a good idea but it didn't seem to help.
          Thanks for rec on using the resistance setting, I ended up getting a better meter that is auto-ranging and also has an audible continuity tone - which is much easier than trying to read the resistance on my old meter.
          I tested all the fuses I could find, and they did have continuity, including the big one on the power board. Some of the FXXXX numbers have an arrow that pointed to largely empty areas on the board, for example the attached image for F5505.
          Thanks to all for your help, but I suspect I'm not going to get a definitive answer as to which bit of hardware is causing the problem. And new TVs are so darn cheap...
            • 12330
            • U.S.
            you can test pin 4 of CN6154, neg probe on chassis ground, pos probe just put it in where the wire goes into connector with connector left in place, check with tv off but plugged in [standby] take note of voltage, then leaving it where it is hit power, there should be a voltage change, if it doesn't, then the mainboard doesnt seem to be sending the bl-on signal, probably a mainboard problem, like you said new tvs are pretty reasonable. I would probably give the old one to a friend who likes to fix stuff.
            • Diah
              • Feb 2013
              • 6560
              its T-CON suspected naked it and show us what it had and where the 12V got lost at it.
                • 12330
                • U.S.
                #27
                sure, can see if voltage is getting in and out of tcon.
                • dxucam
                  • Nov 2022
                  • 14
                  The new multimeter gives much better readings, so I'm pretty confident of these. I tested all 5 CN6154 pins that are wired, in both standby and 'on' modes. Pin 4 seems pretty much dead.
                  Pin Standby On
                  1 0 mV* .5 V
                  2 148 mV 1.15 V
                  3 108 mV 1.9 V
                  4 0 mV 0 mV
                  * pin 1 reads a voltage after TV turned off, but it drains to zero.
                  • dxucam
                    • Nov 2022
                    • 14
                    How do I see where the voltage was lost?
                    • Diah
                      • Feb 2013
                      • 6560
                      you wrote before... TV turn on and the front LED indicator lid green.. but no BL no screen. so when you turn it on need to follow the T_CON if it had 12V and there will be test pints VGH..etc.. need to check after you remove the heat sink of T-CON
                      • dxucam
                        • Nov 2022
                        • 14
                        Thanks for the feedback. Since the device is also lacking sound I thought that it was less likely to be the T_CON, but rather either a power issue or a MOBO issue.
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
                        • Destroyer-Br
                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                          by Destroyer-Br
                          I'm working on an Acer Nitro 5 unit with the following specs:
                          • Motherboard: LA-J871P Rev: 1B
                          • Model: Acer AN515-55-59MT
                          • S/N: NHQ7JAL00403906A973400
                          • SNID: 03902728734
                          Initial Issue
                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                          04-17-2025, 08:18 PM
                        • gersrt
                          Ordered Wrong TCON Board For Sony TV, Can I flash Epprom
                          by gersrt
                          HI
                          Made a mistake and ordered the wrong TCON board to replace in my KDL-46HX823, the board I ordered was Sony PLY 1-883-893-11 which is sort of correct.
                          But later realized this board is used in 4 or 5 models, any way the one i got sent was for KDL-55HX820.
                          Physically these boards are identical, everything on the board is the same. I havent put this board into the TV yet, but am I right in saying all i would have to do is copy the Epprom from my faulty board and transfere it on to the new board, or is there still something else that may stop this working....
                          01-27-2021, 05:49 PM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
