I have a Vizio VX37LHDTV10A and am experiencing the exact problem showcased in this video. (this video is not my actual TV, but as I mentioned, I am having the exact same issue).
http://www.youtube.com/watch?v=2WbYxkQ32ns
I purchased in 2008 from Sam's Club and it is out of warranty. I have cracked open the back cover/case and visually examined the capacitors (caps). None of which appear to be loose or "domed" as would normally indicate failure. Plus, I am not experiencing the frequent power cycle problems that others experience with capacitor failure.
When the set is plugged in, power is turned on, the TV picture comes on just like in the video … gray bars gradually appear. No function buttons will work on the side of the set or with the remote. Only unplugging the TV will turn it off.
Does this sound like the video board, the control board (I'm not sure if I know the difference.) The control board seems like it would be the board where everything plugs in at the rear of the TV (HDMI, Optical cable, Audio L, Audio R, Video, etc...) It is mounted horizontally.
There is another board on this model, that is long and mounted vertically on the left hand side (when viewed from the rear) and on the same side as the power button. I'm not sure what this board is.
Both board seem like they would be relatively simple to replace, just not sure which one it would be considering the mysterious video.
Any help, suggestions are welcomed.
David
dwsberger
David
dwsberger
