Panasonic Viera TX-32LXD600a blue screen
  • andy smethurst
    • 49
    Hello: This 32" LCD TV powers up fine, and has sound, but it has no video, but the screen dose come on with a dark blue screen. I cant seem to locate a service manual either. could this be a mainboard problem? or what. Has anyone had experience with this model? Any information or help would be greatly appreciated.
    Regards:Andy.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Panasonic Viera TX-32LXD600a blue screen
    Regards:Andy.
    Service manual is available at Elektrotanya.
    This could be a main board problem, or possibly the tcon.
    PlainBill
    • alexanna
      • Mar 2010
      • 1346
      Regards:Andy.
      If you can get to the T-Con board, there may be a couple of fuses that should be checked.
      • andy smethurst
        • 49
        Thanks again Plain Bill for the service manual site, I removed the T-con board to look for smd fuses, but these (and other) small components are not detailed on the board.I have seen lots of these before,and can usually recognize them. I have found some components that resemble smd capacitors, rectangle and tan colour but have a band around the center and this is also soldered to a track at the base, as well as the usual ends. When I tested these for resistance they seemed like a typical fuse resistance (0.4ohm),except for 1 that measured (3.4ohm) are these fuses, or inductors?. Thanks agai for any help.
        Regards:Andy.
        • PlainBill
          • Feb 2009
          • 7034
          Regards:Andy.
          I've been saying this a lot lately. DAMNIFIKNOW.
          Now, if someone took a picture and attached it using 'Manage attachments' - below the text entry area - I MIGHT have a clue.
          PlainBill
          • andy smethurst
            • 49
            Hello,again. The component was a line filter. Anyway all voltages and test point voltages were fine,except for a pin from the power supply to the Tcon board. this is a stand-by line and should carry 10v stb, and 7v On,I get 5v stb and 4.6v On. When disconected from Tcon board,I get 11v in stb mode from the power board,so looks like a short on the Tcon board.I chased the line using the schematic to no avail.I purchased a Tcon board on Ebay(used), and this didnt fix the problem. I hooked up the Tv to another Tv and the picture shows fine on an external screen.All voltages to display panel are correct,and I checked the panel fuse(ok)also.The inverter board has all correct volts and is working. Where else can I look, or what should I look for? Thanks.
            Andy.
            • PlainBill
              • Feb 2009
              • 7034
              Andy.
              If I understand you, you connected the LVDS cable from this TV to the TCON on another TV, and the picture displayed perfectly. That eliminates the main board and probably the power supply. The remaining suspects are the TCON and the LCD panel.
              You have tried a different tcon, which did not work. Do you get the same incorrect voltages with the replacement tcon? I see two possible causes - a power supply with insufficient current capacity, or a bad panel.
              Ultimately I come back to the same problem - without pictures I can't help you.
              PlainBill
              • Toasty
                • Jul 2007
                • 4171
                >>I hooked up the Tv to another Tv and the picture shows fine on an external screen.<<
                How?
                Any OSD?
                Pictures PLEASE.
                veritas odium parit
                • Toasty
                  • Jul 2007
                  • 4171
                  Try entering Self Check mode. See if you get any display.
                  "Self-check is used to automatically check the bus lines and hexadecimal code of the TV set. To enter Self-Check mode, keep pressing the STATUS button on the remote control and press the down (-/v) button on the TV set. To exit Self Check, switch off the TV set at the power button."
                  Code:
                  MEM  O.K.
                  GC5  O.K.
                  GC3FS O.K.
                  AVSW1 O.K.
                  AVSW2 O.K.
                  TUN1  O.K.
                  VIF  O.K.
                  MSP  O.K.
                  SDM  O.K.
                  IPC  O.K.
                  HDMI  O.K.
                  ADV  O.K.
                  TX-32LXD600
                  OPTION 1  01
                  OPTION 2  10
                  OPTION 3  28
                  OPTION 4  75
                  OPTION 5  EA
                  OPTION 6  B3
                  OPTION 7  08
                  OPTION 8  80
                  OPTION 9  00
                  OPTION 10 80
                  OPTION 11 C1
                  OPTION 12 A0
                  OPTION 13 30
                  CHECK E4
                  Code:
                  [U]Display[/U] [U]Ref. No.[/U] [U]Description         [/U] [U]P.C.B.[/U]
                  MEM   IC1102  EAROM             DG-Board
                  GC5   IC4037  GLOBAL CORE          DG-Board
                  GC3FS  IC4020  GLOBAL CORE FOR SUB      DG-Board
                  AVSW1  IC3005  AV SWITCH           H-Board
                  AVSW2  IC2105  AV SWITCH           H-Board
                  TUN1   TU3201  MULTISTANDART SOUND PROCESSOR H-Board
                  VIF   TU3201  VIDEO INTERMEDIATE FREQUENCY  H-Board
                  MSP   IC2106  MAIN SOUND PROCESSOR      H-Board
                  SDM   SD-MODULE MPEG/PHOTO VIEW, SD RECORDING SD-MODULE
                  IPC   IC8013  HDSL PEAKS Lite        XV-Board
                  HDMI   IC4026  HDMI I/F RECEIVER       DG-Board
                  ADV   IC4019  A/D CONVERTER         DG-Board
                  If the CCU ports have been checked and found to be incorrect or
                  not located then " - - " will appear in place of "O.K.".
                  veritas odium parit
                  • andy smethurst
                    • 49
                    The TV has AV input and AV output connectors(we use AV not SCART in Australia) on the main board,and I connected the leads from the output of the faulty tv to the input of an older but working TV, and when I set ths TV to AV.1 input, it displays the channel the faulty TV is tuned in to. This at least proves that the tuner is working. I still had the incorrect STB voltages with the new TCON board, but I think the power board is Ok,because when the connector is removed from the Tcon side and measured on the power side it is correct.This is the reason I got another Tcon board as I thought there was a short somewhere pulling the voltage down to this level. Thanks Toasty,I haven't got around to trying the OSD yet,I cant see why this wouldn't be displayed as well. I will try the self check.Oh I dont have the original remote for this set,just a cheap universal one,Ill do some reading of the manual,there may be a way arround this. Thanks for all replies.
                    Regards:Andy.
                    • Toasty
                      • Jul 2007
                      • 4171
                      The lack of blink codes seems to me to mean the power supplies are okay.
                      Verify the voltages on Page 9 of the Service Manual.
                      You do need an original remote to get these to work properly. Especially for the service menus.
                      Part Number: N2QAYB000047
                      They're on eBay for reasonable (<$20) to ridiculous (>$50)
                      Try the SD card input and the VGA (computer) inputs also.
                      There is usually a "Factory Reset" function.
                      See if the Owner's Manual has that noted.
                      The lack of -any- OSD has me thinking the DG board may be bad.
                      Did you have OSD when you tested on the other TV?
                      Was this subjected to a power surge or nearby lightning strike?
                      PS: Please break up your messages into a few paragraphs. All one long one is very hard to read/follow especially when the subject changes.
                      veritas odium parit
                      • andy smethurst
                        • 49
                        Thanks Toasty, I did plan to get a proper remote If I managed to get the set working, anyway I tried the set up as above again,and the picture is quite good.
                        I can change channels and volume,but there is no volume bar displayed when turning the volume up or down.
                        The functions button dosen't display anything, no EPG, no OSD
                        I did the page 9 Tp tests a while back,all tested fine except Tp7201, which is a STB supply and should be 7v+-1v normal mode, and 10v+-2v in STB. I am getting 4.6v and 5.2v respectivly. I had the same results even when I changed the Tcon board.
                        When I remove the connector from the Tcon board I measure 11v in STB on the power supply side. The set wont get out of standby with this connector removed, so cant measure normal mode volts.
                        This supply feeds several Ic's on the Tcon board,and even though the supply is low the output volts are correct, except one,(ic.1109) which is a reset Ic and is only 4v(in)instead of 7v(in) there are no out measurements mentioned.
                        I know this looks like a Tcon fault,thats why I got another one, Can they both have the same fault? I wasn,t expecting the missing OSD as well.
                        I have tried other inputs with DVD, and Set Top Box. I get sound only. I havent tried the SD card or Pc input yet but I will next. Thanks again Toasty
                        Regards:Andy.
                        • Toasty
                          • Jul 2007
                          • 4171
                          PlainBill said a while back this could be an indication of a weak supply line. Track the 7v line back to the source and see if there is a fault.
                          Check FL4047 on the DG board. Page 59 of the schematic, far lower right off of connector DG5. It is -very- tiny maybe 1mm x 1.5mm. It is a filter for incoming 7v STB power and I've had these short before on plasmas. Essentially a pass through filter cap, you should read zero resistance left to right and zero resistance top to bottom. It should show open from left or right -to- top or bottom.
                          Look at this as a pinout of one of them.
                          ┌─3─┐
                          1░░░2
                          └─4─┘
                          1 & 2 are power through.
                          3 & 4 are ground.
                          See attached image from another thread for size relationship.
                          veritas odium parit
                          • Toasty
                            • Jul 2007
                            • 4171
                            The STB7V affects or is associated with IC1107, 1108, 1109. All on the DG board.
                            Check the resistor R1251 (100Ω) near Q1148 (DG Board).
                            Check C7101 on the AP board. 4700uF @ 16v.
                            The STB7V is a linear supply, not SMPS. It is mains transformer fed (T7101), so if it's low, something is dragging it down. Read voltage from D7103/D7105 anode to D7102/D7104 cathode. What voltage?
                            veritas odium parit
                            • rmoody
                              Learning Member
                              • Jul 2011
                              • 262
                              Sounds like a bad tcon really. Remember it's always possible that the one you bought from fleabay could have been bad. It's happened to me.
                              • andy smethurst
                                • 49
                                I tested FL4047 line filter = 0.ohm. and C7101 checked Ok. R1251(100.Ohm) and Q1148,and IC1107, are not fitted on original board, but are on the one I got from the UK.
                                This could be because we(Australia) use RCA connectors on the main board, and UK use Scart? I don't know.
                                The voltages for the diodes read, STB=5v and ON=4.6v. If I remove the AP5 connector from the DG board,the STB=12v on the diodes.
                                I did all AP board TP. tests, and all Normal tests were great except for the low STB point,
                                but tests in the STB mode, some of them (tp7301, tp7303, tp7601) read the same as the Normal (on) test. Full volts instead of a trickle voltage.?
                                Is this a problem or an error in the service manual?
                                Thanks again for any more clues.
                                Regards:Andy.
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  That's not the answer I wanted for the FL4047. I want to know if you are getting a resistance reading between the ground (3 & 4) and the through line (1 & 2) indicating a short.
                                  I'm fairly convinced the DG board has a problem because the STB7V only feeds to that board and not out to the panel. All the other resistors feeding the components attached to the 7V line are in the 10k and up range, not enough to pull it down to 5 volts from 12v that you measured unloaded. The 100Ω resistor (if it was the feed to the overload) would be smoking.
                                  The other thing that may be worth checking are the 4 diodes that make up the bridge rectifier for the 7V.
                                  veritas odium parit
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    >>This could be because we(Australia) use RCA connectors on the main board, and UK use Scart? I don't know.<<
                                    Main board? You mean H board. DG is the main board.
                                    Have a number or pic of the original T-con?
                                    Have an adjustable bench power supply?
                                    >>R1251(100.Ohm) and Q1148,and IC1107, are not fitted on original board, but are on the one I got from the UK.<<
                                    That's very odd. You've a replacement DG? I thought you only had a T-con replacement.
                                    These are on the DG board. Q1148 acts as a 5v regulator feeding the IC's and draws its' power from the STB7V.
                                    veritas odium parit
                                    • andy smethurst
                                      • 49
                                      sorry. I meant the H board for the RCA connectors. The DG board is what I have a replacement for, and the numbers (TNPA3863 1 DG) are identical,and so was the model TV. It has the vacant pads and labelng for the omited parts.
                                      The resistance for FL4047, from through to ground,(1 to Gnd,and 2 to Gnd)= 202k Ohm.
                                      I removed all of the rectifier diodes to test properly, and they were good. I did the same with the surounding diodes just to make sure.
                                      I do have a variable bench power supply? Thanks again for the help.
                                      Regards:Andy.
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        Put the original DG back in. I see no point in testing with missing components. There is no call out in the schematic or parts list that those parts were in one version of the board and not another. Something's weird...?
                                        So you did -not- replace the T-con then, correct?
                                        I would try "helping" the 7V line with the bench power supply. I hope it has current limiting of some type. If not, try using an auto light bulb (parking) to help keep the current down and put an ammeter (DMM) in series. If the bulb starts glowing, something's wrong...
                                        veritas odium parit
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • jean luc ferre
                                          acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
                                          by jean luc ferre
                                          on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
                                          i tried the hard reset, cmos reset, changing the ram without results.
                                          in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
                                          The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
                                          but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
                                          11-22-2025, 03:54 PM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
