I have a polaroid TDA-03211c LCD TV with an IPOS 150 REV. 1.8 Power Supply board, the LCD is black, the power turns on but I have no backlight, I have replaced the capcitors on the power board with the exception of one, the big filter cap which I have just noticed is domed pretty good. The LED in the lower left corner of the board is flashing when the power is turned on and stays off when the power is off. Anyone have any ideas?
Polaroid TDA-03211c IPOS150 Power Supply Problem
Tags: None
Re: Polaroid TDA-03211c IPOS150 Power Supply Problem
I have a problem with ipos 150 rev 1.8 for my polaroid 26in. I have no power at all, no voltage at standby. When I got it it went into standby. When i powered on the blu light came on for a sec and it shutdown. so i replaced 2 large caps, 2 transistors, and a fuse. after that i decided to check the diode(D10) tested ok so i put it back in. i got everything back together and plugged it in and no front led. a part at loc (Z6) ticks and flashes. also, did i get the diode installed in the right direction. this tv had the dvd removed. It should still work as a tv without it right? theres just a hole where it was.Last edited by ryan74; 10-13-2012, 01:51 AM.Comment
I tried to find a picture of when I had done the repair on a similar tv to show the correct polarity of D10. If installed correctly, I think you should get about 24Vdc on the tab. I cant remember exactly.
As for the flashing part, no parts should be flashing.
Did you check the capacitors undereath the heatsinks?The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Check here for more info on these power supplies. Note - Post 15 will verify the correct polarity of D10.
https://www.badcaps.net/forum/showthread.php?t=12886The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Diode seems to be installed correctly.
I will check the caps under heatsink.
If I understand right I should get a voltage reading off the top of diode where it soldered to heatsink?
Can u identify the part I said was flashing? I have no clue what it is but I might be able to get a part number off it. It looks glass with a rusty color. Tracing backwards from 5vsb to the part that flickers, to capacitors, to diode.Comment
That looks like some type of zenor diode. I've never seen them flash before. That's a new one to me.
I'm not sure what the voltage was off of the heatsink of the diode but I know one is there. I think it might have been about 24VDC.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
It is a zener diode. I guess it doesn't flash, more like a tiny spark inside
I'm pretty sure your right about 24vdc from diode, I think I saw that somewhere else
I'll check back in a few days when I have a chance to test more.
Thanks for the help and quik response so far.Last edited by ryan74; 10-13-2012, 12:23 PM.Comment
If it is flashing, the zener is shorted out, and you are seeing the silicon glow red hot, screaming for mercy.
I suggest you try to figure out what circuit it is on. More than likely, it's some kind of protection for a voltage rail, so you can find a zener with a similar voltage rating (plus a few volts) as the rail it is on.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I suggest you try to figure out what circuit it is on. More than likely, it's some kind of protection for a voltage rail, so you can find a zener with a similar voltage rating (plus a few volts) as the rail it is on.Muh-soggy-kneeComment
ZD6 is a Zener 6.2V Zener diode, it is connected across the 5BSV output and Ground (Anode to Ground, Cathode to 5VSB pin) to clamp it down incase the 5V goes higher than 6.2V.
And Yes, you should have 24VDC on the heat sink of D10, Cathode is pointed up.
http://s807.photobucket.com/albums/y...%20TDA-03211C/Last edited by budm; 10-13-2012, 09:05 PM.Never stop learning
D10 diode tested 18.5-22v. It seemed to spike at the same time the zener diode sparked. I get .185v at the 5vsb con
I went ahead and ordered the whole cage for $40 but I really want to learn about these tv's and fix this board.
I figure I'll replace d10 diode, caps under heatsink, and zener diode but I'm conserned about the voltage going into d10 diode
On the bottom of the board there is a tiny part between 2 capacitor leads. (This cap is under heat sink) should I test this and how? If u need a pic I'll get one.Last edited by ryan74; 10-14-2012, 05:43 PM.Comment
It sounds like you 5V is higher than 6.2V Zener diode is try to clamp down, it is shorted out.Never stop learning
I tested capacitors and transistors out of circuit with multimeter but I'm not sure what acceptable ranges are. Transistors tested .13v and .16v on other.
Tested D10 Diode at .42
Caps tested:
220uf 25v tested 225uf
220uf 25v tested 214uf
220uf 25v tested 220uf
100uf 35v tested 102uf
100uf 35v tested 97uf
1000uf 10v tested 1021uf
1000uf 10v tested 1009uf
1000uf 10v tested 1037uf
470uf 35v tested 462uf
Zener diode tested 0v
I hope this helps, I'm a novice but I'm wondering if zener diode is all that is bad.
If I tested wrong please correct meComment
Can you remove that Zener from the board and use OHM mode (if the diode is shorted out, it will not be reading like diode any more, more likely to be really low Ohm in both directions).
"Transistors tested .13v and .16v" Not sure what you mean from the reading since it has 3 legs.Never stop learning
Zener diode is bad 0.0 ohms (0.0v in diode test mode)
With meter in diode mode and ground lead on center leg of transistor I get .13v on each of the other 2legs. With pos lead on center leg I get .OL on the other 2
In ohm mode testing with ground lead to center leg I get .63kohms on the 2 other legs. With pos lead on center leg the other 2 legs test .OL - 13kohms it bounces back and forth
Hope this helps
Are caps within range.
All my tests are with multimeter but I don't fully understand how it all works. I just follow basic directions for testing resistance, capacitance, continuity and so forthLast edited by ryan74; 10-17-2012, 02:01 AM.Comment
"With meter in diode mode and ground lead on center leg of transistor I get .13v on each of the other 2legs. With pos lead on center leg I get .OL on the other 2"
Can I see the pictures of this TRANSISTOR? The Vf reading of 0.13V sounds more like common cathode diode rectifier.Never stop learning
Hi to all!
Wanted to thank everyone for the sound advice. I replaced the 2 capacitors and my donated tv now works! Sound but no picture...flashing red light on PSB. When the power button was pressed the blue light would come on but no picture. Thanks again!Comment
I just fixed one of these yesterday too. Just the 2 caps needed replaced once again. I bought the set the other day for $20. The only thing that sucks is that the remote didn't come with it. Can someone please tell me the model number of the remote or post a picture of it?The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
